Question about NetGear WGR614 Wireless Router
How to enable icmp on netgear router wgr614 - NetGear WGR614 Wireless Router
  • NetGear Master
  • 2,219 Answers
Look on Page 49 under services blocking/unblocking.
ICMP is a service.
http://www.downloads.netgear.com/files/wgr614_ref_manual.pdf
Posted on Mar 08, 2015
SOURCE: Can't connect to XBOX Live because of Strict Nat settings Netgear router WGR614
I tried to find this "Access Point Mode" on the WBR 1310 as suggested above and I couldn't. I spent hours on the phone with support from Xbox, D link, and my ISP Bell Sympatico's technical support trying to get my Strict NAT to Open. I finally got everything working and if you follow the instructions below in order, you will too. Here's what you should know if you have the D Link WBR 1310 and Bell Sympatico Internet.
1. Log into the router and under the Setup tab click on "Setup Wizard" then on the next page click on "Launch Internet Connection Setup Wizard" In step 1 leave the password unchanged and click next. On step 2 select your timezone. On step 3 this is important, select PPPOE setting. On the 4th step leave the Address Mode in Dynamic and enter the Username and password supplied to you by Sympatico.
Once you have configured your Router to work with the PPPOE settings that Bell uses (Most DSL providers use this setting) you should now get a Moderate reading when you do the Network test in the Xbox dashboard.
2. Now go here http://www.portforward.com/networking/static-xp.htm and follow the instructions to setting up a static IP address on your computer.
3. After setting up a static IP address on your computer, go here http://www.portforward.com/english/routers/port_forwarding/Dlink/WBR-1310/Xbox_Live_360.htm and follow the instructions. Something you should keep in mind which isn't mensioned on this page is for each port you forward under the box that says "IP Address" do not put the IP address of your computer. You put in the new IP address of the Xbox 360 which was one of the 5 that was generated on the previous link. What you are doing is giving the Xbox 360 a new IP address and that new IP address needs to forward these port numbers to the Router.
4. Go into the Xbox dashboard and edit the Network settings. Under Basic Settings click on IP address and set it to manual. Now enter in the new IP address you chose for the Xbox 360. The subnet mask and the gateway is the same as your computer. (You can find these by clicking start, run, type in cmd then when the box comes up type in ipconfig/all
Under the DNS Settings it should be set to automatic and under Additional Settings leave them empty. Run the test in the dashboard and it should now be Open!
Also after reading several forums you don't need to enable DMZ host and leave the UPnP enabled. By default they are set this way anyway. Hope that helps.
Posted on Jan 05, 2008
Mole72
  • 30 Answers
SOURCE: connection settings for a ps3 via netgear WGR614
you need to check your routers firewall setting by accessing your router through the pc and make sure your plug and play settings are enabled. all can be found on the router setup page. the playstation only requires you to enter the WPSK or WPA wireless encryption key to log on so the problem is usually with the router....hope this helps.
Posted on Dec 13, 2008
  • 20 Answers
SOURCE: NETGEAR WGR614 Wireless Router keeps beeping
try by upgrading the latest firmware version from netgear website
Posted on Dec 16, 2008
2Gigs
  • 141 Answers
SOURCE: how to add a netgear wgr614 router to dsl modem
The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
crapiemael
  • 241 Answers
SOURCE: Netgear WGR614 Router won't configure to 64 bit Vista
If it's a new router read the book with it and it will tell you how to access the router via internet explorer. Something like this, on the address line of IE enter //192.168.0.1 and type enter. You will need the default login and password from the manual.
Posted on May 26, 2009
How do I enable the security on my wireless network?
REGARDING THIS ONE, I will be sending you the link. THe link provides a step by step instructions. Just click on the instruction below:
http://computer-hardware.helium.com/how-to/12791-how-to-enable-security-on-a-netgear-wgr614-wireless-router
May 28, 2011 | NetGear WGR614 Wireless Router
Hi there, where could I get a setup cd for netgear WGR614 router?
You don't really need the CD.
Use an Ethernet cable to connect your computer to one of the LAN ports on the router.
Connect from your web-browser to the web-server "inside" the router.
If it asks for ID or for password, try a "blank", or try 'admin'.
Once connected, you can run a "Wizard" to configure your wireless network, i.e., pick an SSID, and pick a password or pass-phrase, and enable encryption.
Apr 08, 2010 | NetGear WGR614 Wireless Router
Can't install netgear router WGR614 IN AN DELL INSPIRON1594 LAPTOP
The laptop/computer's wireless card may not have the latest wireless card driver installed or it is not enabled and working. Check Device Manager to see if is is working and enabled. I suggest you install the latest wireless card driver.
Next check the wireless card configuration, it needs to have the wireless router's settings, ie SSID and encryption etc.
For instructions on securing and configuring the wireless router and wireless card please click in this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 23, 2009 | NetGear WGR614 Wireless Router
Wgr614 ho to enable upnp
Open the router page(www.routerlogin.com).It will ask for username:admin and password:password(default) and in the netgear smart wizard page left side blue screen click on upnp under advanced menu and check mark to turn it on and click apply.Hope this helps you and vote for me if have hepled you.
Oct 01, 2009 | NetGear WGR614 Router
Xbox360/netgear WGR614 V9 connection issue
Do you have encryption enabled on your router? If so you will need to enter the encryption key of the passphrase in the network setup of the xbox 360
Sep 19, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Connection settings for a ps3 via netgear WGR614
Dec 12, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
NETGEAR wgr614 instalation
They don't seem to offer a download for the CD, but it's not really necessary.
Go to http://www.netgear.com/ and download the manual, which gives very clear instructions. This might take a little longer, but you'll have a much better understanding of routers when you're finished.
FWIW, most routers will work without any set up at all.
To enable encryption, you'll need to review the instructions.
Dec 22, 2007 | NetGear WGR614 Wireless Router
try using "admin" for the user and "password" for the password. I have this very same router and that was the default settings for me.
Nov 19, 2007 | NetGear WGR614 Wireless Router
NAT set to strict
upgrade your router to the latest firmware that can be found here:
http://kbserver.netgear.com/products/WGR614.asp
after upgrading the firmware, press the reset button for 30 seconds, then reconfigure the router. you will need to re-enable upnp if it is disabled, and open up ports UDP 88 UDP 3074 TCP 3074. i would also reserve the ip for the xbox and if all else fails set the xbox as the dmz host.
hope this helps,
trin
Nov 16, 2007 | NetGear WGR614 Wireless Router
Having trouble with my wgr614 v6 router
Your router should have UPNP in the settings, make sure this is enabled and the port will be automatically opened by the router for your xbox.
Oct 16, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
89 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
