Question about Rocktron Patch Mate Loop 8 Multi Loop Rack Switcher Silver
How do i reset the rocktron loop 8 to factory settings to conect to the midi mate floor controller
2 Suggested Answers
  • 5603 Answers
SOURCE: My Rocktron Utopia G200 displays
The symptoms indicate either the WRONG power adapter is being used or the adapter is failing. This unit uses a 9VAC (not DC adapter like many pedals) adpater. If you are trying to use a DC adapter or a multiple pedal power supply that is your problem. Use ONLY the correct power supply with this unit.
Posted on Jun 17, 2011
I connect the piano to midi and them the speakers stopped sounding, the phones plug too. how can i do the reset factory for the privia px 120?? thanks!
You don't need to reset factory.
You just need to change the setting of LOCAL CONTROL.
Lets start :::
While holding TONE / SETTING button,press key D#7 at 7th octave (highest octave on the right hand). Then release. That's all.
Then the sound must be heard..
Mar 11, 2015 | Casio PX120 Privia KEy ESSENTIALS BUNDLE
Patchmate 8 is suddenly losing half it's level, is it fried?
Without knowing your complete setup it is hard to know the source of the problem... HOWEVER... One problem I see is that if you are using certain types of external effects, this device does NOT use balanced lines (TRS cables) and some of the effects units do use balanced. That, depending on your cables can cost 6DB of gain... and MAY be intermitent depending on whether your cables contact the ring of the TRS connector in the effects unit. This is not normally a problem if you are only using pedal type effects units. Most rack mounted effects are another story. If you need to go between balanaced and unbalanced you may need to use DI boxes. Since this device uses relays, if a relay isn't conducting fully it would distort the sound terribly passing mostly high frequencies.
Sep 09, 2011 | Rocktron Patchmate Loop 8 Floor Switcher
My Rocktron Utopia G200 displays DSP RESETTING, no sound, no controlls possible... What can I do?
Jun 17, 2011 | Rocktron Utopia G200 Guitar Multi Effects...
When I connect my midi cables to my PC and use Fruity Loops or Mixcraft and I play notes on the Roland Juno D keyboard, some of the notes stick and dont stop playing once released and others are played...
The name for the notes that don't stop playing is "Dreaded MIDI Drone". It is caused by multiple note on commands and lost "mating" note off commands.
Also read "c." on page 80 regarding buffer length and "choppy" sounds.
Feb 05, 2011 | Roland Juno-D
I have the yamaha dtexpress and a midifase conect but cant get anny sound to the computer??????????????
try a midi loopback device or a viruual midi cable such as sonys virtual midi cable: http://www.johnrofrano.com/tutorials/virtualmidirouter.htm
i dont know if this one will work, you could also search for loopb1 and hubi's midi loopback device, one of these should work.
what you have to do is use one of these programs, or something similar, to connect your midi input to the soundcard's midi wavetable or to your midi/synth/sequencing software's midi input.
also, the drum machine should be set to output to midi channel 10. make sure that your software is set to recieve on midi channel 10, if applicable.
Nov 29, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
I have yamaha PSR-i425 keyboard.can i conect it with my pc to play midi files stored in computer memory?
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
Sep 08, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Casio Privia PX-120 cannot be connected to Reason or FL
When you are using midi the sounds from your keyboard aren't sent anywhere. What happens is control messages are sent over the midi cable from midi out to midi in on the other device which must have midi sounds on it (in your case the sound card) to make any sounds. The messages can be things like note on/of or pitch bend etc. If you want to send messages to produce a result on your laptop and still here something you can loop the messages by running from midi out on the device end ( your laptop) back to midi in on your keyboard. A much better explanation is available here:http://www.indiana.edu/~emusic/etext/MIDI/chapter3_MIDI.shtml I also signed up to this site (its free) that has great people and lots of info:http://www.recordingreview.com/ I recommend downloading Killer Home Recording setting up which at this time is also free and has the best advice you could want in it. I'd also recommend checking out Reaper which is comparable to Reason, Cubase or Protools. If this helps please let me know.
Jan 21, 2010 | Casio Privia Keyboard Case
Casio ctk 700 Fl studio 8 connectivity
Fruity Loops version 4 requires Windows up to version XP.
If you happen to have Vista on your PC, you should probably retrofit to XP as there are MANY compatibility problems with Vista and a lot of the special purpose software.
First thing is to COMPARE the PC requirements against what Fruity Loops says it requires.
Oct 06, 2009 | Casio Music
My casio 496 cannot connect to fruity loops
Unfortunately your model of Casio only has midi in and not midi out. You will be able to use it as an external sound module but not to input notes into Fruity Loops. In other words midi out of your computer to midi in of the Casio with the proper settings will play your Fruity Loops sequences through the Casio.
Jun 18, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Rocktron Patch Mate Loop 8 Multi Loop Rack Switcher Silver Logo
80 people viewed this question
Top Rocktron Music Experts
rhodesworks
James Kovacs
James Kovacs
Are you a Rocktron Music Expert? Answer questions, earn points and help others
