Question about Hitachi 53FDX20B 53" Rear Projection Television
Hitachi 53FDX20B Convergence Repair Kit - Hitachi 53FDX20B 53" Rear Projection Television
SOURCE: HITACHI Projection TV 53FDX20B having too much red color
my hitachi projection big screen tv 57SWX20B has a draping affect across top of screen why?
Posted on Dec 31, 2007
  • 927 Answers
SOURCE: Hitachi 53FDX20B
Good Day;
Take off grill, take off panel, on left side on front of circuits you will see a small switch. Push button. Remember to save data after adjustments are done via TV's remote.
Good Luck!
Posted on Jun 13, 2008
  • 927 Answers
SOURCE: Hitachi 53FDX20B Manual Convergence
I'm sorry I didn't make it clear, but you could do both. The front approach is easier.
Good Luck.
Posted on Jun 16, 2008
Slinteriors
  • 8617 Answers
SOURCE: Hitachi 50FX20B convergence problem
RK42 is 2.7 ohm 1watt
RK46 &RK54 are both 2.2 ohm 1watt
RK50 & RK62 are both 3.3 ohm 1watt
RK58 is 3.9 ohm 1watt
They are all metal film (flameproof) 5% resistors
Posted on Jul 20, 2009
  • 1779 Answers
SOURCE: I have a Hitachi 53FDX20B and the picture is looks stramge
It is not your Picture tubes that are bad, it is your Convergence IC's. The IC # to use is STK392-180. These are better than the originals, also invest in these resistors: 1.5 ohm 1w,,,1.8 ohm 1w,,,2.2 ohm 1w. (watt). I would by 4 each. Your soldering skills will come into play so roll up your sleeves and go to work.....Good luck ! and let me know how you do.
Posted on Aug 26, 2009
Testimonial: "I was ready to purchase brand new lamps, and thanks to the expert, fix is much easier, and alot cheaper."
I have a Hitachi 53FDX20B projection TV. The Red color seems to bow. I have tried to perform MAGIC FOCUS to no avail. Additionally, I took the front panel off to manipulate the adjustable knobs. What I...
problem will be either Bad resistors ,in front of the Convergence ICs or ICs and resistors need to be replaced. ICs are big black ICs and will have part number on them STK392-110 use 120s or 150s
Mats Electronics has Parts ask for Convergence repair Kit. 1-800-628-1118
Mar 01, 2011 | Hitachi 53FDX20B 53" Rear Projection...
Error code 5 after magic focus
Convergence is dead.Must replace the 2 convergence ICS,and some or all the resistors.Know how to solders?Buy a convergence kit at these websites at Tv Repair World.com,Tvrepairkit.com to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 16, 2010 | Hitachi 53FDX20B 53" Rear Projection...
I have a double screen , bended on the sides what is the fix??? red kind of 3 D. It is a Hitachi 52 in projection hdtv model # 53fdx20b. Aprox how much will it cost to fix? Can I fix it myself?
You can fix it yourself but it involves two things--being able to get at the convergence chips and being able to solder etc....
Not a difficult repair and total parts cost should be under 30 dollars.
Let me know if you need help as I am here to help.
I will give help and options if you ask.
IF THIS HELPED YOU rate this solution as I do this here for free.
SD TECH
Jan 30, 2010 | Hitachi 53FDX20B 53" Rear Projection...
I have a hitachi 53fdx20b and the red and green colors line up fine, but the blue is droopy at the top and doesnt line up elsewhere, any help?? :)
Ur convergence is dead.U know how to solders?Try this website,Tv repair World.com.to buy a convergence kit,replace what in that kit.
Oct 20, 2009 | Hitachi 53UWX10B 53" Rear Projection...
No remote with this set anymore
You can rent the original remotes from www.tvrepairkits.com
Sep 21, 2009 | Philips 51PP9100D 51 in. Television
When i turn on tv the screen is turning green
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Dec 11, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi Tv
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 22, 2007 | Hitachi 53FDX20B 53" Rear Projection...
53fdx20b double vision?
KIT10 $29.50
Oct 18, 2007 | Hitachi 53FDX20B 53" Rear Projection...
53FDX018
KIT10 $29.50
http://www.eserviceinfo.com/
http://www.digitalhome.ca/forum/search.php
Jul 27, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 53FDX20B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
