My sky remote wont work my sky box - Televison & Video
4 Suggested Answers
SkyGuy08
  • 27 Answers
SOURCE: new sky hd remote will not operate sky+ box
The HD remote LED will not work with Sky+ boxes, so the guy has mis-informed you, althought they may have been confused as the Sky+ remote will work the HD Box.
Sorry but you need a new Sky+ remote.
Posted on Apr 04, 2009
  • 325 Answers
SOURCE: conect sky remote to sky+ box
Hello Jolene725,
If you are using a standard remote / HD remote for a sky + then you will have to press the following buttons:
TV
SELECT + i (flashes twice)
SELECT
You now should be able to use the standard remote with the Sky+ box.
Just bare in mind that using the standard remote you dont have the buttons to pause, record, etc.
Hope this has helped you out. If so then please leave a thumbs up
Cheers Little Dish Fitter
Posted on Oct 10, 2009
ercupa190
  • 12223 Answers
SOURCE: my sky remote control does not work with a secondhand skyplus box. what is wrong
see the diagram attached:
1) retight the spring contacts batteries with pliers for good contact
2) clean the contacts batteries with contact cleaner
3) resolder the wires contact batterires
4) open the r.control for clean the contacts for dirty, corrrosion, oxide, test with continuity, remember they send infrared signal to the microcontroller receiver.
5) if you can do it, go to the repair shop TV for fix it.
God bless you
Posted on Jul 17, 2012
Tuning bush tv
Because you haven't programmed the Sky remote correctly.
Put the TV and Sky box on, and put the telly on the Sky channel. Press Interactive on the Sky remote. Choose "Program my remote" from the menu list. Follow the onscreen guide. The pages take a bit to update so be pationent
Sep 07, 2014 | Televison & Video
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
I have got a new sky+box and remote. can i use a previous sky remote with my new sky+box and if so, how do i sync it? thanks.
you can only use a previous remote if it is a sky+ remote, original sky remotes will not work with the sky+ box. vice versa
Nov 13, 2009 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Sky + remote rev 8 works tv but will not work
TV
0
job done
Cheers
Little Dish Fitter
Aug 29, 2009 | Star Manufacturing International R/C Sky...
My sky remote control has stopped working..i have rebooted the sky box and it still and put new batteries in and it still wont work
an easy way to check if a signal is coming out of your handset is to look at the end that you normally point to the sky box through a video camera or a mobile phone camera. these devices can view a much greater range of frequencies than the human eye so when trying to view infrared it looks like a normal white light through a camera. view the end of the remote thru the video camera and press a button like the volume on the remote as this will give a constant stream of data out of the handset. if no light is seen the remote is goosed. hope this helps
Aug 08, 2009 | Sky Toys
TV locks up the SKYdigibox
unplug tv for 1 mins,re-plug it back in!
Feb 26, 2009 | Televison & Video
New sky hd remote will not operate sky+ box
Dont think so
Try resetting it by this method,it might work
To perform a RESET press [TV] and then hold [select] and [red button] together for around two seconds (until the red light blinks twice). Now press 999 (red light blinks once for a long time and then twice quickly).
Please let me know if this helps
JonnieC
Jan 18, 2009 | Directed 434MHZ Remote Control
Sky box wont work
try taking the plug out and waiting for 5 mins before plugging it in again.
Also are you pressing the button itself or just the remote control? The batteries in your remote might need replacing
Oct 27, 2008 | Audio Players & Recorders
Can't get sky remote control to work
i have a amstrad sky box the remote has the record button on it.
i did not change the batteries in it now it wont work the sky box at all.
HELP PLEASE....
Oct 08, 2008 | Televison & Video
Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Jan 19, 2008 | Televison & Video
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
