Question about Epson Perfection 4990 Flatbed Scanner
Copies of printed material no longer sharp. Can this be adjusted?
I lay a page of print from a book, scan it in the auto mode and the print is not as sharp as it formerly was. It seems to be slightly out of focus. Is there some way to adjust this?
    Top Expert:
  • Epson Master
  • 34,207 Answers
The printer may have adjusted itself to print in grayscale instead of black and white. Check the print settings.
Posted on Feb 13, 2014
4 Suggested Answers
  • 139 Answers
SOURCE: Gray backround
Does your scanner software give the option to choose different modes...grayscale, color, black & white?? This sounds like it's scanning in grayscale....if you can change it to black & white, the background should remain white.
Posted on Jan 24, 2008
SOURCE: scanning red and green over
Had the same on my Epson Perfection 1650. I was about to throw it out but decided to take a look inside. Unscrewed and took the top off (with glass bed), then unscrewed the area that houses the scanner light and a set of three mirrors, cleaned with a lens brush the mirrors although did not see any more than one spec. Put it all back together and now it works great. not sure what I fixed, but it IS fixed. may have been put together badly in the factory as this problem happened soon after purchase. I may have knock something out of place at some point. Anyway you may be lucky too!
Posted on Jan 01, 2009
SOURCE: Epson V200 scanner
Epson V200 Copy Utility Problem with Incorrect Margin Output
I had the same problem forever and i just sat down today to fix it.
I have a Konica Minolta PagePro 1350w for my printer. The resolution
is set default at 600x1200 when in the Output Paper - Paper setting.
Change the resolution for your printer if you can to 1200x 1200 in the output paper - paper setting in the copy utility software, and
that should solve your problem with this half page copies. It might
still cut off some margins at the very edge, but most of the time they're just
plain paper margin. Hope this helps you out.
Posted on Jan 14, 2009
I MAKE A COPY AND I GET MY COPY BUT I ALSO GET A BLANK SHEET.
See if your copier has "Book mode" if so it's scanning you original and looking and scanning for an open book, i.e. page left on glass and page Right (two) on glass. Like you had a book flattened out on the glass. Make any since? #2 possible malfunction in print button. #3. Are sheets coming out stuck together or do they appear to be two separate scans?
Feb 04, 2016 | Cannon Office Equipment & Supplies
How do you copy a book on a Sharp MX-503N Copier
Hi
If you go here:- MX M503N MXM503N Digital Copier Printer Archive Sharp you will get to a page with a list of manuals etc which you can download in pdf formet and which you will be able to use to find out how to do what you want. If you search "book", then there are a variety of options that are described.
I think you should be aware that copying a book in this way is subject to copyright laws.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 11, 2015 | Sharp Office Equipment & Supplies
Copy Output all black
Janson; does this problem only occur if you're doing copying via the auto feeder, or also if you lay the paper in manually? The auto feeder uses a small glass opening to the front (or left) of the main flatbed scan area; if there is an issue with that area letting in light, an all black page would result. If you get all black with either type of scan, but regular printing still works, then you may have a dead scan element. Try scanning something to your computer or to an email account to see if normal scanning still works.
Apr 04, 2014 | Dell 2135cn All-In-One Laser Printer
Sharp MX 2300n - When I print or copy color, the whole page has a pink hue to it. Not there when printing or copying black/white. I have cleaned the laser holes and pulled the corona knobs several times,...
PRESS #*c* in your control console respectively then you will get a service mode,Check to confirm that there is A3 paper in the paper feed tray. If paper is insufficient, supply it, will ask for main code press 67 then press Start and machine will ask for a sub code press 24, then machine will give you another display press execute on that one, you will get a pattern print out. After completion of self-printing, the display is shifted to the output patch scan start standby screen. Make sure toplace the printed test pattern on the glass pointing the light side of the pattern towards the left hand side that is to place the light side coinsiding with the arrow marking on the glass table, place some white A3 sheet above this to correct the white value, press service and then press execute then machine will give you another print out then on that you press ok on that one and wait for the below display message.
PRINTER ENGINE HALFTONE AUTO ADJUSTMENT MODE
COMPLETED THIS PROCEDURE.
PLEASE QUIT THIS MODE.
After this press CA button on your console and check the copy, repeat the same procedure for 4 or 5 times if the copy quality needs to be get improved. Rate this and vote for this
May 13, 2011 | Sharp MX-2300N Color Copier
Sharp Al 1631 prints half a page
Sometimes the originals hesitate using the document feeder, which can cause the problem you are describing. Do you get the same rsults if you lay the original on the glass?
Apr 29, 2009 | Sharp AL 1631 Copier
Toshiba eStudio 210c grey background on copies
U need to check your developer material. How many copiers has been made?
U can also perform 05-200 for the auto toner adjustment. The value should be in the range of 235-245% ( 2.35v - 2.45v )
Mar 26, 2009 | Toshiba e-Studio 232 Black and White...
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
Sharp arm355N/fx/srg
When you select double sided printing in the printing options, there are two choices--book mode or tablet mode. I think you want book mode.
Aug 28, 2008 | Sharp AL-1655CS Laser Printer
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Jun 24, 2008 | Xerox DocuColor 3535 Copier
Photocopying a book
yes, there is a button for book form.
it will either be in additional functions or duplex mode.
when copying leave book open on glass it will scan the first page then scan the other page. you can have it on two different sheets or one double sided sheet.
Good luck.
p.s.: it should be in the user manual also if you have it.
Nov 15, 2007 | Canon imageRUNNER 5000 Copier
Epson Perfection 4990 Flatbed Scanner Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
