Question about Chevrolet 1997 Chevrolet K1500 1500 4WD
Replaced intake gasket.run hot with therm state with out runes cool
  • Chevrolet Master
  • 16,406 Answers
Define hot!
Posted on Feb 13, 2014
I have a 2000 Oldsmobile silhouette mini van done replaced the thermostat but its still running hot
Your engine is notorious for having the intake manifold and gaskets go bad. If you are loosing water pull the #3 spark plug in the morning, when the engine is cool and see if there is moisture on the plug. If so you will need to have the top of the engine torn down, and at the least, change the intake gaskets.
Jun 30, 2015 | Oldsmobile Cars & Trucks
Car is running hot and I put a new thermostat in and water bump
make sure the radiator cooling fans are coming on. GM has also had major problems with the lower intake gaskets leaking on the V-6 engines. sometimes when refilling the cooling systems air lock can occur. run the engine until it warms up and then turn off and let it cool down, if coolant level goes down repeat this process two or three times. other causes could be clogged radiator, or worse case scenario blown head gaskets. also i have on occasion got bad thermostats from the parts store. the upper radiator hose will get very hot when the thermostat opens. run the engine and hold the upper hose and when the t-stat opens the hose will get hot. then when the cooling fan comes on hot air will rush from from the fans. if the fans come on and the air is cool then there is a circulation problem. t-stat, clogged radiator, low coolant, head gaskets. good luck.
Jul 14, 2012 | 2000 Chevrolet Malibu
My Grand Prix stared running hot. We replaced head gaskets and intake gaskets, replaced water pump, thermostat, and flushed radiator. My car is still running hot. The heat not blowing hot even after new...
are you sure that the radiator is not clog ,also check the cap for broken gasket also check the hoses for stiffness i would also wanna run it without thermostat to see what happens ,some times they come defected from manufacturer good luck
Mar 30, 2011 | Pontiac Grand Prix Cars & Trucks
1994 ford tours runing hot.replaced water
If you had a crack in your head you should be losing water inside/outside the engine, the same with a head gasket, check for water running down the outside of block and the exhast for excess water discharge, I know will sould stupid but did you insert the thermostat in the correct way? spring facing downwards?. The only other thing i can think of is if you have a collapsed rubber hose somewhere.
Feb 06, 2010 | 1994 Ford Taurus
2000 Malibu keeps running hot.
is the electric cooling fan operating properly.
Nov 21, 2009 | 2000 Chevrolet Malibu
The cooling fans on my Grand Am GT1 do not go on causing the car to run hot.
You can start by checking the fuse for the cooling fans, the relay and the coolant sensor. If you turn on your AC, the fan should come on automatically. If the fan comes on when the AC is on, the problem isn't in the cooling fan. Then it may be the intake gasket or a head gasket problem. The red antifreeze used in these models tend to eat away the plastic intake gaskets.
Apr 10, 2009 | 2004 Pontiac Grand Am
1996 CHEVY 5.7 VORTEC RUNNING HOT 245*
you need to change the clutch fan and flush the radiator.
Mar 13, 2009 | 1996 Chevrolet C1500
2000 Pontaic Montana
I have a 2000 montana and mine was doing the same thing. I replaced intake manifold gaskets, thremostat, and water pump. Turns out it my heads were warped. I had them taken to a machine shop and it has seemed to fix my overheating problems.
Oct 21, 2008 | 1999 Pontiac Montana
Overheating 1993 Buick Skylark
it could be a fuse or fan relay, or a stuck thermostat, i will recomend to aply stright power to radiator fan to see if works, if don't replace fan and fuse, but if does, then it might be the thermostat, one very easy way to test the cooling fan system is by unpluging the coolant sensor with the car runing, if fan come on whit car runing and sensor disconected, the the system is ok, and might be a bad sensor, or stuck closed or open thermostat. please leave feedback if this take care of your problem
Jul 15, 2008 | 1993 Buick Skylark
AC wont shut off
while unit is running tap control to see if it shuts off or turn therm. up to 80 if still runs replace control (warranty)
Dec 14, 2007 | Fedders AEQ07FBG Air Conditioner
Chevrolet 1997 Chevrolet K1500 1500 4WD Logo
Top Chevrolet Radio Communications Experts
terry stevens
Mike Charette
Are you a Chevrolet Radio Communication Expert? Answer questions, earn points and help others
