Question about Aztech Computers & Internet
Modem dsl 1016 aztech DMZ
Hi, i wanted to open the port for avtech dvr.i selected dmz mode chosen the ip add for the dvr. when i reset both the modem and dvr. the Ip address at the dvr did not change to public IP. and the host name was empty under the dmz column but the ip address of the dvr still remain.... DNS hostnamr was setup using no-ip.biz. anyone please....
2 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Port forwording
ok port forward if any has router this is easy ill get too others in momment
routers port forwarding features type in ip address in internet explorer search bar at top
router ip's start like this 192. type the whole ip in
this will ask you for password and that usually is the word "password" or "admin" threw that you can set the router port forward by going down the list
now for comps with out routers
goto control panel
then network connections
right click on your connection
goto properties
goto advanced
goto settings
you will be directed to windows fire wall
goto exceptions add program or port you want to forward
basically port forwarding is a program that keeps 2 comps from having conflict with each other running the same program and helps in monitoring ports for intrussions
Posted on May 09, 2008
I have a newer newer belkin router but i hope you can still help me out,okay when i try to play a game on xbox live it won't let me because it says my NAT rating is closed,how do i set it to open?
Hello your Belkin Routers has a Firewall Feature on it which might be blocking you to Play games on your Xbox.
To Solve this Issue you Just have to open Ports on the Router For your Routers Ip Address or Enable DMZ ( De-militarized zone). Which will Open all the Ports on the router for an Ip address.
---> Steps to Enable DMZ on the Belkin Router
- Connect your Computer to the Router using an Ethernet Cable.
- Open Internet Browser & Goto 192.168.2.1 it will take you to Router Setup Page
- Towards your Left Pane Click DMZ Under Firewall
- Leave the Password Box Blank & Click Submit
- Check the Enable Box
- In the Private Ip Box Type in any Numbers in range of 2 - 254. EG: 192.168.2.9
- Click Apply Changes
- Unplug the Power Cable From the Router & Plug it back After 15 seconds
> Now Let us Assign the Ip Address on your Xbox
- In the Xbox Dashboard
- Go to My Xbox and Open System Settings
- Select Network Settings, Configure Network.
- On the Basic Settings tab, select IP Settings, then select Manual.
- Select IP Address, enter your chosen IP address EG: 192.168.2.9, and select Done.
- Select Subnet Mask, enter the Subnet mask 255.255.255.0, and select Done.
- Select Gateway, enter the Default gateway 192.168.2.1, and select Done.
- Select Done to save your settings.
- Go Ahead & Test your Connection.
Mar 13, 2011 | Belkin (F5D8231-4) Wireless Router...
NAT type is set to strict, I would like it set to open. Modem is a NETGEAR DM111P
What you have to do is go to your router settings!! You need to find DMZ settings !! DMZ Server allows you to set up a computer or server that is available to anyone on the Internet for services that you haven't defined. There are security issues with doing this, so only do this if you're willing to risk open access. If you do not assign a Default DMZ Server, the Router discards any incoming service requests which are undefined. This can be a security problem. You shouldn't check this box unless you have a specific reason to do so. Thats enough **** of that !! Then you need your xbox IP address and add that to the DMZ setting this will set your NAT to open!! Just be careful if not using a static IP address with your xbox that if router is turned off the xbox will asign a new one and you will have to re-enter the DMZ. Hope this helps
Feb 22, 2011 | Video Game Consoles & Games
Belkin surf router F7D3302 setup for port forwarding problem to a Qsee security dvr
PORT FORWARDING
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the DVR
Step 7: Get the IP Address of the DVR
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the DVR in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Dec 08, 2010 | Belkin Wireless Surf Router (F7D2301)
Modem reboots starting voice chat in 3d platforms
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Enabling DMZ:
1. On the left side of the setup page, click on the WAN Setup under Advanced tab.
2. Check the Default DMZ Server and specify the IP address of your computer.
3. Click on the Apply button.
May 27, 2009 | NetGear DG834G Router
Security First SDVS-1904 Setup (Not D-Link) Needing help with this. We installed the 4 cameras and the DVR. They're working fine. Now I'm trying to get it to come up on the computer so we can see the...
I'm not sure if you are still looking for the answer, but I think the problem may be that you need to enter the PUBLIC IP address of the modem at the remote end instead of the PRIVATE (ie. 192.168.1.x) IP that was actually assigned to the DVR. It works best if you assign a static IP to the DVR on the remote end and enter that IP into the router's DMZ. You might also want to get a free account at dyndns.net and setup a FQDN for your business router/modem. That way you can connect to it using something like "mybusiness.homeip.net" instead of an IP address, and if the IP changes it will still find it. You will also have to configure your modem at the business to automatically update the dyndns server when the IP changes.
Mar 04, 2009 | D-Link Securicam Network DCS-950G Wireless...
How To Make a DMZ
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding, as described in How is Port Forwarding Configured? However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
Feb 19, 2006 | NetGear RO318 Router
How To Make a DMZ
Feb 19, 2006 | NetGear MR314 (MR314NA) Wireless Router
How To Make a DMZ
Feb 19, 2006 | NetGear MR314 802.11b
How To Make a DMZ?
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding. However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
Feb 19, 2006 | NetGear RP114 Router
Configure DMZ Host
enter username admin and password blank (nothing), i got 401 Unauthorized messege 3 times reset the routher DI-524
Feb 16, 2006 | D-Link DI-704P Router
Computers & Internet Logo
222 people viewed this question
Top Aztech Computers & Internet Experts
Ali Reza
Level 1 Expert
James Van Damme
James Van Damme
Are you an Aztech Computer and Internet Expert? Answer questions, earn points and help others
