Question about Dyson DC25 Bagless Upright Vacuum
No suction after assembly
No dirt goes into the canister. No suction from the hose either. Loud noise when turned on.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Sounds like you have a tube misaligned. Take the tubes that lead to the filter off and put back on. Most likely the solution
Posted on May 06, 2014
  • 25 Answers
SOURCE: Dyson DC07 vacuum.
you have to remove the hose and wand then you can get to the clip that holds the canister on the machine and with a screw driver gently prise it of the machine
Posted on Sep 05, 2008
chrispurs1
  • 372 Answers
SOURCE: Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
Posted on Oct 16, 2008
blueextc3221
  • 15935 Answers
SOURCE: Dyson Animal
Obstruction in the hose?
Your vac has developed a hairball possibly.... when a piece of flexible media ie.... cardboard, plastic etc... gets lodged in the hose, and begins collecting hair & dust to the point it no longer has enough draft to pull debris from the floor.
Here is a video that you may find useful
http://video.aol.com/video-detail/dyson-not-picking-up-dirt-no-suction-how-to-repair/2334249387
PS I Thought DYSONS were guranteed to NOT lose suction? What a RIP!
Posted on Jan 06, 2009
SOURCE: Dyson has lost suction and loud noise from base(?),
I had the same problem, from right out of the box. Now that I just threw mine out, I see this site that indicates there's a fix for it:
http://ths.gardenweb.com/forums/load/cleaning/msg0415060828462.html
And search for other sites isung "dyson grinding" or similar.
Since I was an early adopter (had one as soon as they came stateside), I did not have the benefit of countless others having the same problem, I just attributed it to a junky design, since so much else about this vacuum was poorly designed, like the seals, hoses, etc.
Give them a call, and good luck! I might rescue mine from the heap and do the same.
Posted on Apr 08, 2009
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: My dyson DC24 makes a loud noise when turned on. The air flow seems to be going out another another end on the vaccum kind of by the on switch.
    I'm sorry to hear you're having difficulty with your DC24. If the relief valve is activating, you may have a blockage somewhere in the machine, and the filters may also need a wash.
    To locate and remove any blockages, please follow the steps shown in our online Support guide:
    http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
    In normal use, the filters need to be washed at least once a month, as shown in the video below. We'd recommend using cold water without detergent, and allowing at least 24 hours for the filters to dry completely before replacing them in the machine. It may help to leave the filters somewhere warm, such as beside a radiator, or in an airing cupboard.
    This should resolve the issue, but if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    Posted on May 03, 2012
    Why doesn't my dirt devil vision turbo have any suction through the hose yet there's good suction at the hose connection to the canister?
    The hose is probably blocked. If possible reverse it (put the intake of the hose on the canister connection) that should suck out the obstruction. If that fails try to carefully push a broom handle into the hose, preferably from the end that connects to the canister. Put the hose back on normally and see what happens.
    May 22, 2015 | Dirt Devil Vision Turbo W/Bonus Upright...
    Nothing going into dirt canister
    Is there suction at the hose? If not it is either blocked or the suction fan is broken. If there is, then there is a blockage in the pickup section, something is lodged across the channel after the brushes and before the place where the hose plugs in.
    I think there is a safety switch to prevent it from running with the canister out so hard to check for suction at the top of the motor/suction fan. Make sure nothing is over that part under the canister too! If you can figure out how to bypass the safety switch (if there is one), you should have good suction where the canister sets on top of the motor base.
    Oct 06, 2012 | Dirt Devil UD40270RM Quick Power Compact...
    Hi, i've had my dirt devil for a couple years now and till a month ago its held up well. we have wood floors in our house and only use it on the scatter rugs but last week it stopped picking up debris. i...
    Detach the hose at both ends. Drop a coin or marble down one end. If it rolls free, the hose is okay. If not, the hose is clogged. To clear it hold the wrong end of the hose to the tank and turn on. The reverse suction should clear the blockage. If not, try pushing it clear with a broom stick.
    Check the power head where the hose attaches. Drop a coin down from the top. If it gets stuck, there's a blockage there. Try to clear it by pushing the handle of a wooden spoon or similar dull item down to push it clear.
    Depending on the noise the vacuum is making, it's also possible some dust/debris got into the motor, causing problems.
    Jan 12, 2011 | Dirt Devil Featherlite Bagless Vacuum...
    Loss of suction
    very simple fix. took me a good hour to figure this out but... first take off your brushhead. via popping the clip so all u have is the circle showing then turn on the vacum using the hose. put the hose over the hole where the brush head goes.. and give it a shake etc to losen up whatever it is u got stuck up in that hose. mine was xmas tree/cat hair mix. which is the death of any vacum lol.. but that noise on the top of the can is cause by suction loss. just use the hose to **** out whatever u got jammed in there and use your finger if u need too. and then no more canister noise.
    Jan 06, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
    Vacuum cleaner does not pick up dirt
    check belt.if making a loud noise then you might want to check the impeller
    Oct 16, 2009 | Vacuums
    My vacuum comes on and make loud noise but will not **** anything up
    the vacuum is clogged either the hose or the canister. turn it upside down to unclog it if its in the hose, take the hose off and turn it around and put it back until your hear the suction sound like a big thump, then put your hand to cover the hose and feel if the suction got stronger, then replace the hose, if rhat doesnt work find something to push the clog thru the hose and periodically put the hose in to suction the clog out.
    Sep 26, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
    Loud noise from Kenmore Progressive Bagless Inteli-Clean
    Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk.
    Jul 04, 2009 | Kenmore Progressive Bagless Upright with...
    Vacum won't ****
    Do you have good suction right out of the canister without the hose attached? If so, AND your hose isn't plugged, you must have a pretty good sized hole somewhere in the hose. If you don't have suction at the canister, pull the filter cover off the top-back of the machine and remove the filter. This is where all of the air that the machine pulls in is exhausted. If something is plugged here, it will greatly reduce your suction. If you still haven't found the problem, you could have a problem with the fan assembly on the motor. But usually this is accompanied by some noise from the motor, but not always. Good Luck!!
    Jan 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
    Hi.
    Oct 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Hi, my sanyo pulse 1500 bagless vacuum has very little suction.
    If the vacuum will run without the hose attached, does the suction seem ok at the opening where the hose goes into? If so, then you have a clog in the hose or down below where the dirt is first sucked up. If suction is poor at the vacuum, then check the filters, they go bad after awhile.
    Feb 24, 2008 | Sanyo Bag-Free SC-240 Canister Vacuum
    Dyson DC25 Bagless Upright Vacuum Logo
    26 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
