Question about Hitachi Vacuums
How to open dust portion of CV-BL16 - Hitachi Vacuums
2 Suggested Answers
chilli1327
  • 174 Answers
SOURCE: Looking for dust collector Hitachi Vacuum Cleaner CV-BL16
Go to their website, look for your model and see if they have replacement parts.
Posted on Feb 18, 2015
Feb 18, 2015 | Vacuums
Tip
How to diagnose a clog in your Central Vac and how to remove it
Symptoms of a clog
Low Suction/No Suction
No suction at Inlet
Tools required
Wet/Dry Vac or vacuum with decent suction and a hose
Phillips Head Screw Driver
Metal Coat hanger (straightened out)
Flashlight
First things, first, make sure your canister is empty at the unit. I know, most people would have already checked this but I have been to a lot of client's homes and this was the issue. They were full or almost full. So just check it before you go to do anymore diagnosing. I suggest emptying it anyways, this way you can see what you clogged in your unit
Now if your machine has a utility valve on the unit turn on the manual over ride switch on and lift the utility valve and if you have suction your machine is fine, you have a clog. If you have no suction or poor suction
-Canister not attached properly
-Filter clogged
-There is a disconnect of pipe within your walls (I've seen it and it renders your system useless and is going to be expensive to repair the system)
-Your motor is going in your system (Your vacuum should sound like grinding metal and chances are it's throwing sparks and smells of burning electrical, turn the unit off immediately and unplug power cord) Your unit will need a new motor or you will need to replaced the whole unit. Sometimes can be cheaper to replace the unit.
So now back on track here, we are going to say the vacuum has great suction and is running smoothly.
Check your hose for clogs, easiest ways are to plug the hose into the utility valve and turn on the machine manually at the switch.
If you do not have a utility valve on your unit (this is where the other vacuum comes into play) plug your central vacuum hose on the end of the shop vac hose. Most hoses are standard and slip right on over the end of a shop vac's hose end (1 1/4 inch end). Turn on your shop vac and feel the suction at the end. It may not be as powerful as your CV but it should be comparable.
If the hose checks out to be free and clear we have a clogged system.
Now lets move to the inlets throwout your home, first we are going to plug our hose into the inlet that is nearest to the unit. If there is little or no suction we know there is an issue either in the distance between the nearest inlet or there is an open/broken valve.
Open/Broken valve (CV will not provide optimum suction with a open/broken valve)
-Plug the hose in and activate unit
-Check all inlets for proper seal, you will hear an annoying whistle or you will hear a gust of air from an improper inlet door closure. (Do this as quick as possible, if it is a clog you are putting strain on your motor, but if you vacuum on a regular basis chances are you know if there are whistling noises or missing pieces of an inlet. If you are missing an inlet door, replace the inlet. If all is checked out to be good, lets go back to unclogging again.
If there is suction at this inlet you know there is no clog between this inlet in the unit, try all inlets from nearest to farthest away. If you try your next inlet and have weak to no suction you found your point of a clog. This is where you will start to unclog your unit.
Take the hose end of your shop vac and insert it into your inlet. Turn the shop vac on and remove the hose quickly to create a seal and lose a seal. You should start to hear items moving through the line.
Now take your CV hose and insert it into this inlet, activate your CV and check suction if there is more suction, your slowly making progress.
Take a flashlight and look into the inlet to see if you can now see the obstruction. If you can, get your coat hanger out and go fishing. It may be easier to remove the inlet from the wall. Your basic valve is safe to remove. If you have a supervalve, do not remove, there is high current installed in the upper portion of the inlet for your power nozzle.
Repeat the Shop Vac suction and stop and the CV suction and stop until you clear your items.
This is going to take a few minutes of tugging between two vacuums. Eventually it will free if it went in, it has to come out. At the end of the day your basically playing tug of war between your Shop Vac and CV. But if all goes to plan, the clog will end up in your shop vac or in your CV unit.
Good Luck!
on May 13, 2014 | Vacuums
My Riccar Upright leave lines of debris when I use it. Can you help?
Inspect the filter.Open the secondary filter on the base of the vacuum to ensure that dirt and debris have not collected on the filter, as this will limit motor performance. Remove the filter from the dust compartment and rinse with water to clean. Allow it to dry completely and return to the dust compartment.--------
Also check if dust bag is got over full and that is causing the problem.Open the dust compartment, take the old dust bag out of the bag holder and discard. Open the end of a new dust bag and attach to the dust bag holder. Close the dust compartment and tighten the dust cover.Also check properly that dust compartment is not got loose. Open cleaning attachment and check the hoses and nozzles on the frequently to ensure that they are free of dirt, obstruction or hair.Also inspect the brushes, if there is already dirt got stuck in the brushes and that is causing the problem.Clean the brushed.---------- This will help, to confirm where the problem is and to resolve the dirt /debris issue.----- Thanks.Helpmech.
Sep 06, 2011 | Vacuums
How to empty
for this unit, you want to start by removing the hand vac portion.
along the side of the clear chamber towards the nozzle opening is 2 clips on either side of the unit.
Squeeze these clips together and the clear plastic chamber should come off. Pull the filter out of the chamber and dump out.
At this point too, you can choose to clean the dust cup, (soap and water) and the cloth filter in there (again soap and water). However if you do that, please make sure that the filter is 100% dry before putting it back into the unit.
Good luck,
Mark
Nov 10, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Is their maintenance I need to do on my H702 central Vacumn?
H702 appears to be a Honeywell heavier duty for mid to large floor areas.I have not seen them but internally most Central vacs are VERY similar.
Most central vacs have an exposed filter which should be inspected periodically for damage or cleaning and replacement. A hanging cloth filter is normally fine for 7- 10 years with periodic inspection by the homeowner. Look for tears, never pick up wet stuff. very simple. You can clean a cloth filter prior to inspecting with the round brush from another vac or a soft paint brush.
I found internet reference to an H702 bag but it may be an option for your vac.
Some cv's have an additional or optional paper bag for allergy sufferers or removable cartridge filter which would be visible when removing the dust pail. regardless, the filter protects the motor from damage, periodically inspect when emptying. If dust gets through a damged filter it can leak into and blow a motor. As an cv ages a small degree of fine dust gets in no matter the brand, but most are fine for 10-12 years with no service.
If you see dust in the air exhausting or puffing from the vac, have the unit checked as this indicates dust which has run completely through the motor. If you see a small amount of black dust exhausting along your wall, it is normal from internal brush wear. Turn the vac on and off and listen to the motor as it winds down. If it growls or sounds scratchy or is squealing, that is an indication it needs to be serviced. Clean and inspect you pwer head every 4-6 months and change a smooth drive belt twice a year, broken or not as it will be stretched.
o
If this helps please post a response
Sep 25, 2009 | Vacuums
Motor noise CV 353
its not that bad to take apart and blow out the motor with a compressor, but if that dust got into the bearings of the motor it could be ruined.
Apr 19, 2009 | Broan-NuTone CV353 Central Vacuum
I sucked up a sock in my powermate, and can't get it opened to see what the problem is. It won't work.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=820548
Generic problem for all Vacuums
I sucked up a sock
Posted by DFundis on July 22, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best thing to do is to see if you can open the power mate or powerhead, the sock is jammed in there and blocking the path of the dust and dirt. There should be some screws on the bottom to release the bottom plate or the top cover will come off, it would be one or the other It probably is stick in the gooseneck the swivel neck portion of the vacuum and or the wands or hose. If you need further help look in the owner’s manual or contact your local vacuum cleaner dealer in your area or call Sears cust serv listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 22, 2008 | Vacuums
On my Sebo Airbelt C3, I can't open the dust bag compartment. It's jammed shut. The handle doesn't seem to be able to shift the mechanism inside.
Try spraying some furniture polish into the release handle. maybe just dust preventing it from opening and the wax and get in there and clean out the dust. Other then that, you will have to just keep working it until it opens.
Apr 20, 2008 | Vacuums
Eureka Capture Vacuum
Either the filters are clogged, the hose has a clog in it, or the dirt inlet down by the brush roll is clogged. Pull the hose off and see if you have suction at the end of the hose, that will tell you which way to look for a clog.
Feb 18, 2008 | Eureka Capture Upright Vacuum Vacuum
Vacuums Logo
43 people viewed this question
Top Hitachi Vacuums Experts
JoeVacs
Are you a Hitachi Vacuum Expert? Answer questions, earn points and help others
