Question about RCA 25252 - Visys Cordless Expandable Phone/ans System - Telephones - Rca25252
Not pairing with Dect 6.0 Accessory Handset - RCA 25252 - Visys Cordless Expandable Phone/ans System - Telephones - Rca25252
Why do I see Base no power on display which also shows Charging?
Your phone is trying to connect via radio to a "base station". If you don't have one, your handset cannot work.
If you have a base station, your handset may need to be "registered" to it.
Apr 12, 2016 | Panasonic KX TGA680B DECT Accessory...
All of a sudden screen went blank charger is plugged in not charging.please help me
Most likely, your rechargeable battery went dead. Replace the battery, charge it fully overnight, and the phone should be fine again.
May 14, 2015 | Uniden DWX337 DECT 6.0 Waterproof...
Can't register handset.
Well I bet its because of the stand your using sometimes :P
I hoped i helped you! :D
Feb 13, 2014 | Uniden DRX332 Multirange DECT 6.0 Digital...
Uniden Dect 6.0 d1384-2 display says searching
I have the uniden 3005 accessory handset that pairs with the uniden 3015. I tried all the above holding down of buttons etc. none of that worked. I finally rang uniden and the technician said to put the accessory phone on the base unit where it's connected to the phone line. This worked and the phone registered, then I returned it to its own base that it came with. Uniden need to amend their manual wording so that it reflects the above steps.
May 02, 2012 | Uniden DECT 6.0 Cordless Phone ID
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
Purchased addt'l handset to work with my CEZAI2998. It has a corded handset in the base and an accessory handset with charger. Needed another accessory handset; purchased EZX290 but can't get it to...
The CEZAI2998 does allow up to a total of 6 handsets, but your issue is that the EZX290 handset is not one that will function with that system. I have listed below the compatible handset models for that Uniden unit and as you can see the EZX290 is not supported. Sorry to be the bearer of bad news, hopefully you can exchange it for a compatible handset. Good luck!!
EJ
Compatible with select Uniden handsets
Including models DCX150, DCX200, DCX210, DCX290, DCX300 and DWX207 for wide-ranging compatibility.
Apr 10, 2010 | Uniden DECT 6.0 Cordless Telephone...
RCA 25252 - Visys Cordless Expandable Phone/ans System - Telephones - Rca25252 Logo
29 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
