Question about Video Game Consoles & Games
Im stuck in the temple where u have to spin 4 diff things to get out of the room but i cnt get the combo correct
Uncharted 2 the temple
    New Friend:
Google it it will help you
Posted on Feb 13, 2014
Was stuck using 4 lo. Had 3 wheels spinning except l/rear,just sat doing nothing.
4 wheel drive is unfortunately a bit of a myth as in 4 wd any two wheels with no traction will not move you any where
so if you have both rh side wheels slipping,
go no where
left front right rear ,
going no where
the wheel that was not turning was the only wheel that had traction but through the differential action the other wheel spun faster
now with limited slip diff centers , both wheels have to turn as the differential action locks up so yes you would be going some where.
posi traction is the same idea
vehicles that have limited slip diffs are Toyota and Nissan as standard with some Nissans having limited slip diffs in the front drive axle as well
now if you are doing a lot of 4wd driving in adverse conditions , you need to have locker diff centers ( available from off road shops ) as they physically lock the diff actions ( with the flick of a switch) with the result if all 4 wheels are spinning and you are not moving , your stuck but if one wheel has traction you keep moving
Nov 12, 2015 | Cars & Trucks
4x4 stuck in 4x4 left tire turns when in gaure
check actuator for the 4wd action (vacuum lines and switch operation ) remember that 4wd only occurs when all 4 wheels have traction so if you jack up one wheel then it will spin because of the differential action . Basically if you have a normal 4wd vehicle with out LSD diffs or diff lockers then if you have both drivers wheels in the bog you will not be going any where as they will spin because of the diff action. The same is for when you have say a right front and left rear wheel off the ground then you will go nowhere as they will be spinning.
Jul 20, 2014 | 1999 Ford Expedition
Four wheel drive
wow no year stated, you do make this hard.
no
your not correct.
why not say what surface you are on?? ice, dirt? what?
AWD means car can drive on dry pavement as the AWD has a
center differential, (a very nice option)
ok, there are 2 axles. open and closed
or open diffs and locking LSD
open diffs suck but wait, not really.
if your car has LSD all wheels, turn buy LSD actions.....
if fully open, then 1 lose wheel spins and the traction tire dies.
(sucks, huh, but.... look here.)
so all savvy 4wd drivers drag the foot brakes and get poor mans 4wd.
try it , on ice and be AMAZED,, it does work.
then... about 2007?
on my 2008 jeep JK, it has software 4wd locks, it does the above
drag trick with software, (amazing huh) using the ABS Pump.
it sees the ABS sensors go nuts and corrects it with the pump.
a nice feature,. for sure. and free. totally free, no LSD hardware.
I dont know the year of your car so can say. what it really has.
there are many 4wd setups. im used to ww2 jeeps and part time.
im on my 5th jeep and not one GC. (its too heavy for serious 4wd off road)
The FSM covers this magic, you can get a real FSM for small cash
i recommend it, on all cars.
Feb 14, 2014 | Jeep Grand Cherokee Cars & Trucks
2002 Chevy 4wd
maby im wrong but if you rev up and only rear wheels spin that means that it might be 4 wheel drive but not constant 4 wheel drive or diff lock system ,,,, ,, in 4 wheel drive all wheells will turn together but if pressure of slip is bad enough or torque high enough only 2 wheels will drive ,,, thats why diff lock locks wheels together in each axle to over come this ,,, all wheel drive like in landrover locks all 4 wheels together to ensure all wheels rotate to give best grip
Feb 13, 2012 | 2002 Chevrolet Suburban
Exactley the same
Firmware 3.0 has been causing problems for Uncharted. Go to [Settings] and download the firmware 3.01 to fix the issue. The update is optional so you may not have known about it.
Sep 18, 2009 | Sony Uncharted: Drake's Fortune
4 statues
Point the statues in the correct direction according to the Journal.
Sep 13, 2009 | Sony Uncharted: Drake's Fortune
Uncharted Loading
If you are using firmware 3.00, there is a issue with Uncharted. Update for firmware 3.01 to resolve the issue.
Aug 30, 2009 | Sony Uncharted: Drake's Fortune
My daughter has the Bolt Game for PS2. She is in
I think this is the same problem my son had. Do the enemies just keep coming?
Here's the solution.
After building up enough combos you get a lightning bolt in a yellow circle on the screen. Press down the top of both the analog sticks and before the countdown runs out do a superbark (L2) while facing the far wall. the wall collapses and you can progress!
Mar 02, 2009 | Dmm Disney's Bolt PS2 for PlayStation 2
Help!?!!?
when you draw the island it is a whale, when you draw the island the riddle makes sense. 1 is at the bottom 2 is the top left 3 is the top right and 4 is in the middle
Jan 14, 2009 | Nintendo The Legend of Zelda: Phantom...
Howsit dude im stuck
I think i can help go to cheetcc.com and then strategy guide it is free and well be of help for the hole game. please rate me and let me know if i helped.
Nov 29, 2008 | Konami Silent Hill 4: The Room for...
Video Game Consoles & Games Logo
46 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
