Question about RCA 25252 - Visys Cordless Expandable Phone/ans System - Telephones - Rca25252
RCA Visys Headset not registering and pairing with base
Old handset got wet no response to base new handset does same thing?
Good afternoon Solomon
This type of phone needs to have the handset registered to the base unit. It's kind of like pairing a bluetooth headset to your phone. Your symptoms sound like this may be the issue.
A soft copy of the manual can be found here:
http://service.us.panasonic.com/OPERMANPDF/KXTG2740S.PDF
If you scroll back to pages 104 and 105, it will show you how to register a handset to the base unit, or to un-register a unit (the latter may be useful to start from a clean slate with nothing paired to the base). It's a bit too wordy to summarize here, but it looks like it's very straightforward.
Hoping this helps.
Good Luck!
D
Nov 24, 2015 | Panasonic KX-TG2740S Digital Answering...
Instruction manual for RCA visys 6.0
Good morning,
How do I retrieve voicemail messages on this system?
Sep 08, 2014 | RCA ViSYS 25255RE2 2-Line DECT 6.0 Digital...
At&t model dect6 troubleshooting
You probably just need to Pair the handset with the base again.
So, you have to set the phone in the main base, not just a charging base.
Some of the AT&T phones need you to disconnect the battery for about a minute to reset (this will not lose you stored numbers). Then pair the phone and base again.
Some models have a PAIR button on the bottom of the base.
Press and hold the PAIR button until the MUTE light on the headset base turns on (about four seconds) and release the button.
Return the headset to the headset base for registration.
Registration may take about 30 seconds to complete. The MUTE light on the headset base turns off. The headset ON/OFF light turns blue
on the first headset registered. The headset ON/OFF light turns orange on the second headset registered.
You should be good to go!
All the best to you,
Kerry Hostetter
May 11, 2014 | Computers & Internet
TL7600 Headset will not pair with TL8802 base
*** How to Pair AT&T TL7600 with AT&T 86103 or 86109/TL88002 !!!
If you have been going nuts on how to pair TL7600 with TL86103 or TL86109 Deskphone, here is a detailed answer.
First of all TL7600 does not need pairing, it is a passive wireless i.e it remains in hunt mode till a deskphone actually pairs with it.
First things first - Charge the Dect Headset TL7600 for 1-2 hours. Press the On/Off button once and you will see a blue/red light that will keep blinking every 2-3 seconds. This shows that the headset is unregistered with the Deskphone. When the headset becomes properly paired and placed on the charger, it will show steady blue light.
Okie, now to registering the headset.
a) First, lets reset the TL7600 just incase it was paired to another phone. Even if it is not, lets just do a reset to avoid some problem.
Push these buttons in the following order one by one :
Push these buttons in the following order:
vol+mutevol-mutevol+vol-mute
b) Go to the TL86103 and keep TL7600 very close to it. Lift off the TL7600 off the charger and then put it back in.
*** FOR TL86103, do the below (See below for other models)
c) Press "MENU" on telephone mode with phone handset on the phone and the phone in Idle Mode.
c) Scroll to "Settings" and then scroll to "Register"
d) All this while, the TL7600 should be on the charger. If you remove it from the charger, it will not register.
e) Within 90 seconds to 2 minutes, the headset will be registered and you will see the handset will be assigned a name on the phone.
f) Pick up the headset, switch it on and you will hear a dial tone.
g) If this doesnt work, try to first press hold for 10 seconds till it says "Unregister All Devices', Click Yes and go through the process again.
j) If you want to know how to make a call, please note that the call will have to made first on the deskphone, then switch on the headset and there you go. Either lift the reciever and make a call or press Speaker and make a call and then switch on the headset, put the deskphone handset down or switch off the speaker and your TL7600 will be connected.
FOR TL86106, 86109 and 88002, do the below steps.
*** For TL86106, everything is same till (b). After that, press HOLD Button on the phone for 4-5 seconds till you see "Registering". Within 90 seconds to 2 minutes, the device will register the TL7600.
Aug 06, 2013 | AT&T TL7600 Wireless Headset
Connecting to base
read the user manual as the handsets have to be registered by the base unit to be connected
the main base is the operational unit
the other bases are just cradles to hold the phone while it is being charged
May 03, 2017 | GE / Rca Visys 25424re1 4- Line Corded...
Need to set time & date on the cordless. RCA Model No. H5401RE1-A
From page 14 of the manual: "The time cannot be set manually in the handset, only at the base. Any update to the base time will be automatically sent to the handset."
Apr 08, 2010 | RCA ViSYS 2-Line Speakerphone
How do you turn the bluetooth on on a ps3 cause i cant get my bluetooth headset to pair
Turn on your Playstation 3, and from the main menu go to Settings - Accessory Settings - Register Bluetooth Device
You will be presented with two options:
Register BD Remote Control
Register Headset/Microphone/Headphones
Select Register Headset... and put your Bluetooth headset into pairing mode. On your PS3 select Start Scanning
Select your device and enter your pairing code. In most cases for audio devices the default pairing code is "0000"
Now on your PS3, go to Audio Device Settings and change your "Input Device" and "Output Device" to your Bluetooth headset name. Try speaking and watch your "Mic Level" move!
This might help you as well:)
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=898874
Dec 22, 2009 | Sony PlayStation® 3 (80GB) Console
RCA 25252 - Visys Cordless Expandable Phone/ans System - Telephones - Rca25252 Logo
88 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
