Question about Brother 1034D Mechanical Sewing Machine
Second needle thread isn't catching when i serge.
    New Friend:
Try retreading the machine. The order is usually in the manual. It may be that the lower and upper looper are threaded out of order.
Posted on Feb 15, 2014
  • 33 Answers
SOURCE: I cannot get the needle to catch the bobbin thread
sounds like your keeping the upper thread too tight when you drop your needle down to catch the bobbin or the bobbin thread that you left hang out is too short, let me know if it works amy
Posted on Sep 04, 2008
  • 5 Answers
SOURCE: Sewing Machine (brother XL 3200)
You may have the bobbin case in wrong.  I have this machine, and I know that it is really easy to put the bobbin case in wrong.  Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth.  My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works.  Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right.  In other words, it has always been my fault.
Posted on May 25, 2009
SOURCE: Lower Bobbin not threading
the thread will not catch the bobbin and the feeder will not turn
Posted on Jun 21, 2009
yeroc
  • 397 Answers
SOURCE: bobbin thread won't catch after changing needle in stylist 457. also what tool to use to change needle in serger
machine needs to be timed,,usually a 30-50 repair, could try dropping a needle just a tad bit to see if it catches
Posted on Nov 28, 2009
SOURCE: The bobbin thread is not
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Posted on Aug 02, 2010
Second Needle thread isn't stitching
change the second needle
rethread the second needle & every thread guide
see if that helps & if it doesn't then the machine needs to be checked
Aug 13, 2012 | PfaFF Sewing Machines
The manual says the top thread should catch th bobbin in a loop but mine won't. what can i do ?
Make sure your needle is fully inserted into the needle bar and isn't bent or blunted.
Jul 19, 2012 | Brother Sewing Machines
I have threaded up my machine and have started to sew. The thread on the back of the fabric keeps catching and bunches up. What's going wrong?
try a new needle
keep a check on the thread take up lever that the thread doesn't come off of it
rethread the machine to make sure that the thread isn't catching on anything
clean under the needle plate for loose thread or lint & in the bobbin area also
make sure the bobbin is inserted correctly
Aug 04, 2011 | Bernina 1008
My machine is new and worked briefly but now . . . . the machine is threaded correctly and the bobbin is placed correctly. When turning the knob for the initial pick up of the bobbin thread, it does not...
You have described your problem just fine. Have you just changed the needle in your machine? If so, check it is in the right way, you want the flat shank to the back.
The needle has a scarf (scoop out) at the back - if it is facing to the front then the rotary hook (bit that goes around the bobbin and catches the top thread) can't catch the needle thread behind the needle.
Also check needle is fully up into the housing, this could also cause problem.
I'd suggest that you visit www.sewingabout.com and check out the pages on general sewing machine use, care and threading up, lots of helpful pictures and information which may be of assistance to you.
If it isn't your needle backwards (very easy to get wrong, happens all the time), then the timing could be out, which isn't so easy, but as its new I'd be very suprised if this was the fault. Just check needle, make sure top and bottom threads are threaded correctly and have another go. Also, remember to turn flywheel towards you.
Jul 14, 2011 | Singer 7444 Mechanical Sewing Machine
Bernina 2500DCET serger keeps breaking the centre needle thread for no apparent reason .Already had machine serviced,new needle plate didn't solve anything either. Any ideas
I have found with any serger I have used that you have to cut the looper (bottom) threads before re threading the needle threads. You then rethread the loopers.
If you don't do this, the needle threads keep breaking. Hope this helps.
Mar 01, 2009 | Bernina 2500DCET
2000ats - not serging
Make sure the tension disks are clean and not binding.. You can use a piece of yarn dampened with alcohol and floss the disks.
Threading order is:
1) Upper Looper first
2) Lower Looper
3) Right Needle -- exception: if you are doing 3 thread using left needle only
4) Left Needle
Sep 17, 2008 | White Sewing Superlock 2000 ATS Mechanical...
Babylock Eclipse SX won't catch the overlock stitch
  • the factory default settings are 4,4,4,4 and M
  • Change the needles
  • use a can of air spray ( compressed air can sold in computer stores) to ensure there is no fabric or dust under the needle plate
Jun 28, 2008 | Baby Lock Eclipse Serger
The serger is not sewing right. Everytime I sew the thread from the top needle goes into the fabric, but the other threads do not. It does not come unthreaded just is not catching somewhere. I have...
The machine was threaded incorrectly at first, but after changing the needle I was threading it correctly. The problem ended up being the needle depth. When I inserted the new needle, I did not have pushed up into it's slot quite far enough. I pushed it up all the way and retightened the screw. Now it is serging like a dream!
Apr 17, 2008 | Singer 5050 Mechanical Sewing Machine
Left thread needle
change the knife blades
Mar 12, 2008 | Baby Lock Eclipse Serger
Open Questions:
See all Brother 1034D Mechanical Sewing Machine Questions
Brother 1034D Mechanical Sewing Machine Logo
66 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
