Question about Lasonic Ghetto Blaster i931 Boombox
Green lights for power and equalizer stay on when I turn it off.
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Behringer power amp epq2000 limit lights is staying on
i have the same problem... no solution found for mine...and you?
May 13, 2012 | Behringer Epq2000 Professional Power...
Behringer epq2000 power amp, limit lights stays on and no sound.
have the same problem... no solution found for mine.. and you?
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Lasonic Ghetto Blaster i931 Boombox Logo
27 people viewed this question
Top Lasonic Audio Players & Recorders Experts
stynger007
Level 1 Expert
Joseph Hoffmann
Are you a Lasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
