Question about Top Knobs Hardware & Accessories
How to disable push button lock on door knob - Top Knobs Hardware & Accessories
5 Suggested Answers
  • 229 Answers
SOURCE: If I am inside and push the button to lock or
is that the driverside only? most like ly a loos connecter attaching the door wire harness to the power conrtol bezel. Pop it off and check the connection
Posted on Apr 23, 2010
  • 141 Answers
SOURCE: drivers side rear door not locking. push the
pull the door panel off an look to see if the striker rod for the lock is connected to the lock...u may want to have a service station look at it since pulling a door panel can sometimes be complex...u can easly break the plastic paneling if u have not removed door panels before
Posted on Jul 15, 2011
  • 963 Answers
SOURCE: I have a BE365 Lock on my door. When I go to lock
How do I enable the alternative setting (Code Turn)? (BE365 Deadbolt only)
1.) Enter your current 6-digit programming code
2.) Push the button
3.) Press 7 on your keypad
Posted on Nov 09, 2011
logosc75
  • 625 Answers
SOURCE: When locking doors they unlock
What's the year, make and model of the vehicle? Are you saying that the door locks cycle...like the door is open when you try to lock it?
Posted on Dec 16, 2012
How do I unlock my 2008 Chevy Silverado Truck?
Slim Jims won't work on the door. There is a tool called The BigEasy unlock tool. You sneak it between the jam and door frame and hook it on the lock knob and pull it to unlock the door or push the power lock button to unlock the door.
Oct 12, 2014 | 2008 Chevrolet Silverado 1500 2WD
Door will unlock without entering code
"Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial? "
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Feb 15, 2012 | Schlage BE365-PLY BE365PLY626 Satin...
How do you replace a keyed door lock set> There are no screws visisble to disasemble
Don't know why this is postedin the Chainsaw forum but here goes. Look for a small hole or slot in the hardware of the door lock, sometimes on the underside. This is usually where a tab of the lock hardware inserts into a slot of the decorative cover. Gently pry the cover off at this point and you should expose the inner lock, with two longer threaded bolts going through the door to the lock mechanism on the other side. Sometimes this can also be done with a very small allen screw that holds the lock cover to the lock mechanism.
Aug 31, 2011 | Garden
I have a BE365 Lock on my door. When I go to lock the door it wants the code punched in and the knob turned. When i unlock it, it just wants the schlage button pushed and knob turned. HELP
2.) Push the button
Nov 16, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
Hi i have a weiser GA331P privacy door knob set in my bathroom door, and i have noticed that it can be pushed in and in the locked postion and when the door shuts it stays locked. I am concerned thay...
the weiser set should have a tiny hole in the knob or rosette around the knob. A paperclip or such can be pushed into the hole to unlock the door. That is the primary difference between a privacy lock and a security lock. Farmerbear at FixYa
Oct 19, 2010 | Garden
Trunk does not open with button inside car. Does open with key remote. Is there a bad fuse somewhere and if so which one?
Your Valet cancel switch is set.
Open your glovebox and you will see a pushbutton on the the left side, if memory serves. When this button is set, the power button will be disabled, but the key fob button will still work.
This is for when you Valet your car, you push the cancel button in the glovebox, lock the glovebox, then give the Valet your Valet key, which will not open the trunk or the glovebox. Voila, no Valet rummaging through your trunk :)
Often full gloveboxes will be the cause of the button getting pushed accidentally.
Sep 26, 2009 | 2005 Lexus ES330
Automatic door lock stuck
try pulling up on the knob while pushing button lock solenoid is stuck
May 25, 2009 | 1996 Honda Accord
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Oven door won't unlock
I fixed the automatic oven door lock on my oven. While the door was open, I pushed the button on the upper left hand side a couple of times (the one that senses when the door is closed.) Then I was going to call the repairman when the door closed! I had to run the self clean cycle again to get the lock light to go off, but it worked!
Nov 25, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Hardware & Accessories Logo
206 people viewed this question
Top Top Knobs Hardware & Accessories Experts
Scott Jelt
Scott Jelt
Rob Benoit
Rob Benoit
Level 1 Expert
woodzowl307
Are you a Top Knobs Hardware and Accessory Expert? Answer questions, earn points and help others
