Question about GE GTWN2800DWW 3.9 cu. ft. capacity top load washer
LOUD BANGING WASHER SOUNDS UNBALANCED WITH CLOTHES IN IT AND NOT WHILE ITS EMPTY BUT TOOK THE FRONT PANEL OFF AND THERE IS A BLINKING LIGHT BY THE MOTOR
    Master:
  • GE Master
  • 753 Answers
The light blinking is normal if the it is .5 seconds and and .5 sec off. Means it is in standby. The washer must be level front to back and left to right, do not wash heavy single item like rugs. If you was towels or sheets you may have to untangle then in order for them to be evenly distributed around the tub. Also, make sure you have the washer settings set for fabric softener added. It will then fill for the final rinse , instead of a spray rinse. Good luck.
Posted on Feb 13, 2014
SOURCE: GE front load washer
Remove the front lower panel (3 screws on lower lip - lay on floor to see). Panel come right off. there is a round "dial" to the front housing. Put down a bath towel on the floor and unscrew dial - then pull it out.
Posted on Aug 28, 2008
SOURCE: the washer makes loud banging
It could be that your machine is not level,
Posted on Feb 04, 2009
SOURCE: GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Posted on May 07, 2009
beltronic205
  • 1474 Answers
SOURCE: Washing machine is leaking water out of the bottom
Leak could be a few things, Pump depending on what side its on /bangs, are they electrical ?
Posted on Sep 30, 2009
  • 151 Answers
SOURCE: tub bangs loudly
there may be 3 to 4 load springs on the underside of the machine that attatches to the tub. if one of these breaks which often do on my machine. They will cause the machine to become unbalanced and bang.
Posted on Dec 23, 2009
Amana washer ntw4700yq1 bangs when entering spin cycle, why
sounds like the clothes load is unbalanced and uneven try sorting out the load and balance it out if it keeps banging side to side try checking the springs inside the washer (careful when opening your clothes washer please! or allow a pro to open your washer and inspect it for any spring weaknesses)
Dec 16, 2017 | Amana Washing Machines
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Zannusi banging
It sounds like it's unbalanced. Try redistributing the clothes and/or washing smaller loads. If that doesn't fix the problem, you may need to call out a technician.
Dec 31, 2012 | Washing Machines
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
On wash cycle it makes a loud banging noise
Hello, The banging noise is from loose lower front weight mounting bolts or a loose bolt securing the driven pulley. Check the motor adjustment bolt for tightness. The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on upper hose hitting the top cover or a plastic injection mold standoff on the outer tub bearing housing may possibly be interfering with the driven pulley. Also, check the drive belt for a weak spot on the belt. Usually felt on the backside of the belt as a "flat" spot. Check the belt for a weak seam and replace it.
It may also occur due to the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Thanks
Jun 14, 2010 | Maytag Bravos MTW6600T Top Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
Loud banging noises
Hi!
The reason of this noise is from loose lower front weight mounting bolts or a loose bolt securing the driven pulley. Check the motor adjustment bolt for tightness. The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on upper hose hitting the top cover or a plastic injection mold standoff on the outer tub bearing housing may possibly be interfering with the driven pulley. Also, check the drive belt for a weak spot on the belt. Ussually felt on the backside of the belt as a "flat" spot. Check the belt for a weak seam and replace it.
It may also occur due to the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 06, 2009 | Washing Machines
Loud noise
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE GTWN2800DWW 3.9 cu. ft. capacity top load washer Logo
131 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
