Irc7065 error e0061-01
After making more than 50 copies the error code wa coming
When I attempt to access some web addresses, i.e. https://eds.ospi.k12.wa.us/ the login page briefly displays and then goes to a YAHOO page with this message "The requested URL...
your system must be bad .I copied and pasted the url that you asked about and it came up just fine to the login page .I use google chrome
Aug 09, 2017 | Computers & Internet
Error code (E2-E3)in toshiba washing machine AW1190S
Try replacing lid close sensor...mine one has E2 due to broken wire...
Feb 03, 2013 | Washing Machines
Error 2,156,50 canon mg 2120
because I can not always quick scan shows me the error 2156.50
Jan 17, 2013 | Canon PIXMA MG2120 Photo All-in-One Inkjet...
F2-40 repeatedly on a new Sharp MX4110 machine
during setup the machine do,nt install toner during calibration 25-2 steps: 1. Execute Simulation 25-01 and verify that the TCD_K value is less than 26. 2. Execute Simulation 7-1 and highlight [DV Check Disable]. 3. Open the Doc Feeder. 4. Place a piece of white paper in the lead edge area of the platen glass covering about 1-2 inches of the lead edge area of the copy. This will prevent jamming in the Fuser Unit. 5. Run 50 sky shots. 6. Check Simulation 25-01 and note the TCD_K value when it stabilizes. 7. Repeat steps 2 through 6 until the stabilized TCD_K value of Simulation 25-01 is 40 or higher. 8. Execute Simulation 7-1 and verify that [DV Check Disable] is not highlighted. 9. Hit CA and make sure machine comes to a ready state. 10. Turn Machine off/on. Make sure it comes to a ready state. 11. Make a copy and check the copy quality. 12. Run Copy Quality adjustment 12a according to the service manual if necessary. Note: TCD_K value of 26 or less will cause the MFP to display F2-40 error code. Remember that the TCD_K Value is inversely proportional to the Toner Concentration. If the TCD_K Value is stabilized at 40 or higher, then the F2-40 error code will not appear. Once you recover from the F2-40 Error Code, the MFP's Process Control will take over and regulate the Toner Concentration.
Sep 13, 2012 | Sharp "MX-4100N Copier, Printer, Scanner...
I have a sharp arm237 the error code is h2-01.... I cleared the melted peice of injet paper my daughter used from the heat roller. I still have the error but can't figure out how to clear it.
double check to make sure all paper is removed.
On the key pad press P * C * it will bring up another screen enter 14 and press the copy button it will ask you if your sure you want to clear the error select yes and press copy button machine should restart if error code comes back you will need a tech to come out and check the fuser and connections
Aug 22, 2010 | Sharp AR-M237 Digital Copier
Error 50 afte paper jam
The following is an extract from the Brother Service Manual that covers your machine:
"Error Code 50 & 51: The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses."
The manual lists seven different causes, best case being the need to clean part of the mechanism, the worst case being replace the whole main electronics board !
Unless you have very good skills for dismantling such a complicated machine*, your choices are take it to a Brother Service agent who will probably charge you more than a new machine, or bin it - sorry !
* If you want to have a go at dismantling it, the service manual can be bought on eBay for about £5. If you don't want to spend that much, I can supply you a .PDF file copy for £1 - just post back here and I'll sort it out.
Feb 20, 2010 | Brother DCP 115C All-In-One InkJet Printer
Unable to print mcf-215
plz press menu then start-bk-copy then fourtimes arrow up quickly after another. machine turns to maintanence mode. press start bk copy: what two digit error code does the machine display?
If it starts with a 4 you do need a new printhead!
Mar 28, 2008 | Brother Multi-Function CenterĀ® MFC-215C...
HELLO SHAH JI
Check All the doors are not ajar/open ! Make sure they all close smoothly and properly.
Maybe door switch is bent
Jan 07, 2008 | Sharp AL 1215 Black and White Copier
Using Job Accounting with Excel
Try unticking the collate box on the print window. this can cause 50 jobs to be sent rather than 50 copies of the same job.
Hope this helps
Mar 27, 2007 | Canon ImageRUNNER 3570 Copier/Printer
24 people viewed this question
jasbo
jasbo
