Question about Humidifiers
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
    Problem Solver:
  • 9 Answers
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Posted on May 06, 2014
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
  • 41697 Answers
SOURCE: I bought a HoMedics Ultrasonic Cool Mist
If you can hear the fan (?) running it probably isn't shorted. Could the water you are using be clogging the unit somehow?
Posted on Nov 14, 2013
There are no instructions in the box of the cool mist humidifier i purchaed today.
Either call or go back to the Walgreens where you purchased the Humidifier. They will either take one from another box or make a copy of it for you.
Feb 06, 2011 | Walgreens Cool Mist Humidifier Humidifier
I do not see visible vapor
Apperently, it doesn't produce mist.
From the product page "Provides invisible cool mist for easier breathing with 20 percent quieter operation".
Jan 11, 2011 | Vicks Cool Mist V3500 Humidifier
WHY DON'T MIST COME OUT OF MY HUMIDIFIER
with cool mist humidifiers your not suppose to see any mist. if it's a warm mist there should be. but by your model number i'm finding that it's a cool mist. that's why your not seeing any mist.
Aug 15, 2009 | Vicks Cool Mist V3500 Humidifier
New filter,still no mist and water level does not drop
make sure that the filter is VERY snug into the bottom of the humidifier, and that the tank is on correctly. We had the same problem :)
Jul 01, 2009 | Vicks V3100 1.2 Gallon Humidifier
We have a Sunbeam Cool Mist Ultrasonic Humidifier that we bought just over 2 months ago. Up until a couple of days ago, it was producing mist and running just fine. I cleaned it with the brush and got the...
I have this same problem. And cool mist humidifiers DO produce mist. I have had my humidifier for a while now (6 years) and have never had any problems. But after the most recent cleaning, it worked at first, but now seems to not be working anymore... Am also wondering if there is anything I can do to remedy the situation?
Mar 17, 2009 | Sunbeam 701 Humidifier
The humidifier has stopped producing mist
boogiecheck is right, the one pictured uses natural evaporation( no white dust) I just ordered one from abdistrsupport@gmail.com and mine works great. I own 3 total.
Dec 07, 2008 | Venta - Airwasher LW44 Humidifier
Produces a ton of white dust... Why???
Your V5100N ultrasonic humidifier generates a fine mist by vibrating the water at an exremely high speed. The water doesn't actually evaporate until after the water mist is in the air. As the tiny water droplets evaporate in the air, the calcium and other minerals settle on your floors and furniture.
Humidifiers that evaporate the water in a filter wick, or with heat, do not generate dust because the water evaporates inside the unit and the calcium is trapped inside.
You can avoid the dust problem with your humidifier by using distilled water. Distilled water is available in most stores that sell bottled water in gallons...but be sure to choose "distilled" water, not "purified" water. Try the distilled water in your steam iron also...if you have one. It will last longer.
Feb 29, 2008 | Vicks V5100N Humidifier
Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Jan 28, 2008 | Crane Cow Humidifier
Humidifiers Logo
983 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
