I have a Daewoo. The screen is blank with a red tint. I have sound and can change channels through the cable box but no picture. I 've tried every choice on the menu box. Any suggestions?
    Top Expert:
  • Televison & ... Master
  • 75,599 Answers
The fault is with its video output stage circuit card. This card can be located at the back of the CRT itself, will be plugged directly to its back. Check all the solder terminals to this board, for any loose solder points. Re-solder all the suspected solder terminals, by applying a little more solder to each of it. The fault is technically called 'one color predominant screen'. If you wish to get some details; check the site linked here.Viewing it in "Mosaic" will make surf easy.
Gopakumar Gopalan Google
Posted on Feb 13, 2014
  • 3 Answers
SOURCE: TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Posted on Aug 20, 2006
TVtechmaniac
  • 140 Answers
SOURCE: Black box in middle of screen
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Posted on Sep 16, 2007
SOURCE: Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Posted on Oct 17, 2008
  • 441 Answers
SOURCE: black square in the middle of screen
your closed caption is on, this might be set on the cable box or the tv, look in the audio or set menu. If you dont have the remotr you should be able to navigate the menu on the tv with the onset controls
Posted on Jul 10, 2009
Testimonial: "wow its been over a year but what john said was exactly the problem. 20 seconds of figuring out where the closed caption settings were in the menu and problem solved."
  • 188 Answers
SOURCE: philips 21rf vardan tv
Check option code's.
Posted on Jul 29, 2009
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
Picture blank
Maybe it needs to be replaced with something more up-to-date.
Jun 26, 2017 | Sharp LC32D62U 32 in. LCD HDTV
Was watching tv( Toshiba Regza)and the screen went blank.
I have the same television and ocasionally the sound shuts-off, but I still have a picture.
What type of cable system do you have? What kind of converter box? I am trying to find out if it is the TV or converter box. I change the channel a couple of times and the sound usually comes back.
Feb 17, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Red Vertical Burn Line on LCD Screen
Try changing the picture setting on the television rather than from the picture box.
Sep 09, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Vizio flat screen has very red tint when using HDTV component cables
Ummm... i have the same problem and its EVERY type of cable that causes the red tint. its the tv itself. replacing all the darker colors with red. explain that?
Jun 11, 2008 | Televison & Video
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Mysterious black box?
Sounds like something is imposing Picture in picture on your scrren with no source attached to the other picture. Could be cable or Sat or some other device, or TV PIP.
Mar 19, 2008 | Daewoo DTQ-19P2FC 19" TV
Sound stays on & picture goes to blank screen
I do not see any reference on this problem and I even checked with Sony. If you are on a cable box, I suspect that is the problem.
Oct 25, 2007 | Sony KP-43T70 43" Rear Projection...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
