Question about Vehicle Parts & Accessories
Where is the valet button on the 474p remote car start? We can't get our 474p to do anything
3 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: I hooked up my alarm
Thanks for writing to Fixya.com .
This sounds like a bad fuse. The fuse is likely under the dash below on the driver side. Look up under the dash below the steering wheel and confirm location. The fuses will either be plugged into the module or as in line fuses coming out of the unit.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on Mar 27, 2010
SOURCE: How to reprogram Python 4Button Remote 474P ?
I had the exact same thing happen with my 4-button 474p remote. WITHOUT REMOTE START the correct sequence is:
1. Enter car - Leave door open.
2. Turn key to "on" position.
3. Within 5 (five) seconds press the Valet button 7 times then hold down. (Programs to channel 7)
4. Watch alarm light - It should now flash 7 times.
5. While still holding down the Valet button - Press the "lock" button on the remote and release. Should get a "chirp"
6. Now release and repress the Valet button once, holding down. You'll get the "chirp". Release Valet button.
7. Turn key "off". Exit vehicle and test remote. All 4 buttons should now work.
Posted on Oct 14, 2012
Remote locks don't work
no, that is a switch to detect the hood being opened. The valet switch is a small button or switch and could be anywhere inside the car. Most installers place them near the driver. Check in the center console, around the drivers side kick panel, under the dash, etc.
Jan 06, 2014 | 4Button Remote 474P
Need program to add additional key fob to my Python 474P model on a 2005 Kia Sportage
To program additonal remote; open door, turn ignition on. Press and release valet button one time then, press and hold valet button. While holding valet button, press lock button on new remote. Turn ignition off. Test system.
Sep 29, 2012 | Remote Start System
Mar 09, 2012 | 4Button Remote 474P
Where did they put the valet/program buttom on my 2004 Rendezvous?
This is somebody else's so;ution, but it might give you an idea on where to start. I always thought the valet switch was just a key that you gave to the valet. But inn this case out of my legue, my old dodge pickup doesn't hAVE AND MOST LIKELY NEVER WILL HAVE A VALET SWITCH. So check this so;ution oout and see if it gets you going in the right direction.
There should be a key specifically for a valet.
1) Open one of your vehicle's doors and turn the ignition, using the car key, to the "Run" position. Check to see that the dome light comes on. Make sure that you have the dome light set to the position where it powers the light when the door is opened, as there are usually three settings: one for "On," one for "Off" and one for when a door is opened.
2) Press the valet remote push-button to access the channel that you want to program: once for "Arm/disarm," twice for "Trunk Release" and three times for "Remote Start." The valet push-button is usually located under the driver's side panel, and it must be pressed within 15 seconds of opening the door. The push-button may also be installed underneath the kick panel.
3) Press the valet push button once again and wait to hear a chirping or a honking sound. If you do not hear either of these sounds, your vehicle might have a jumper installed that has turned the valet programming feature off. Refer to your vehicle's instructional manual to learn how to set the valet programming feature to the "On" position. Keep holding the valet button pressed as you continue onto the next step.
4) Push the button on the remote that you wish to assign to a particular valet channel. Press the button on the hand-held valet remote that you wish to assign to a particular valet channel. If you wish to program multiple remotes, repeat this step for each of them. If you program four or more remotes, the old programming will be erased.
5) Let go of the valet push-button and exit your vehicle. Your handheld remote is now ready to use.
Tips & Warnings- Some valet remote channels require different programming individually, so refer to the owner's manual or to the link provided in the "Resources" section of this article, for specific instructions.
- Valet remote programming methods may vary, depending on the vehicle's make and model.
  • By avatar11.jpgBraunson Y309 days ago
    Braunson Y Level 2
    • 467 Solutions
    • 282 Score
Dec 19, 2011 | Viper Security and Remote Start System...
I had to replace the battery in my car and now my remote will not do anything lock or unlock the doors start the vehicle or pop the trunk what do i do?
Reprogram the remote: turn ignition on, press and release valet switch one time. Press and hold valet switch. While holding valet switch, press lock button on remote. The alarm should chirp to confirm entry into the programming mode (when you press and hold the valet button) and when you press the lock button. Turn ignition off. Test remote.
Jan 24, 2011 | 791XV The 791XV is a 2-way Security and...
Trying to program 474v remote for viper car starter
Super easy
1. Make sure car is disarmed
2. Get in car turn key to IGN position
3. Push valet button one time and let go
4. Push and hold valet button.
5. While holding button push either lock or unlock on keypad of new remote.
6. Siren or horn should sound.
7. Let go of valet button and turn key OFF
8. Test remote
9. Smile and grab a shake ;)
Apr 01, 2010 | Viper Security and Remote Start System...
Vehicle Parts & Accessories Logo
23 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
