Question about HP 5188-2545 Compaq Motherboard Hp/compaq Desktop Emery-ul8e Sata Asus P5lp-le E
I have an HP Media Center PCm7360n. It doesn't seem to boot up. No "beeping" sound, fans stay in high speed, black screen. Could this be a motherboard problem?
Video card is a Radeon 2600 Pro. Hard drive is a Model 6L300S0 Maxtor DiamondMax 10 SATA.
  • HP Master
  • 10,263 Answers
The coin battery on the motherboard is drained. That will cause it not to boot. Replace the battery and reset the time and date and you're good to go.
Posted on May 07, 2014
I have an HP Media Center PCm7360n that does not seem to boot up. Upon startup I get a black screen, no "beeping" sound and fans stay in high speed. Could this be a motherboard problem?
yes i had one ...same issue......open the side of the PC (WITH POWER OFF) make sure the SATA lead is secure to the hard drive...i know it sounds dumb but my HP PAV Media Centre did the same thing, and that was the prob, the SATA Cable and DATA RIBBON moved a fraction even though it was connected it wasn't reading the DRIVE....try that.
Feb 13, 2014 | HP 5188-2545 Compaq Motherboard Hp/compaq...
I have a a1630n and suddenly when I turn it on, the fans run fast and screen stays black. No beep. let it sit over night and on the first boot up the screen will go to the windows xp logo and than go...
Alot of problems with the HP.
First thing is make sure when you changed the battery you would need to check the jumper that allows you reset the BIOS and let you use the computer.
The other is the fan speeds it normally should go a little high not so high but in your case the CMOS battery that was installed could cause some things not to work especially if it supports PCI-E. The motherboard in your system must have a dual video connector. One is on the board and one is on the PCI-E. Make sure the monitor is plugged into the right port. It should work after that. If not remove the PCI-E card and see if it works with the onboard connector.
Nov 21, 2010 | HP Pavilion a1630n PC Desktop
Not sure if it is MB or CPU when i try to turn on computer the only thing that happens is i hear a beeping sound. beep...beep...beep... continually. it wont go to the post, nada. the fans run and i have...
Continous beeps usually mean the motherboard or the power supply, Try another power supply first and see if it will boot, if not the motherboard is faulty, if the prossesor was faulty you would no beeps the fans would run but nothing on the screen. hope this helps.
Aug 24, 2010 | Computers & Internet
Hey i have a hp media center m7000 everything is plugged in and every time i turn it on only the fans seem to be going the screen wont come up, the mouse wont light up or the usb internet connection wont...
You have a very tough problem. You need to remove the outside metal to get to the motherboard. Look carefully to see if a card has lifted out of the board connector. See if the fan on the CPU is plugged in and running. If not, your CPU is probably fried. If it looks good, try removing the RAM chips and boot up to see if you get a beep code. This is good if you do. Put the chips back in order and take out an external video card. See if you get beeps ( you may not have this card, it may be built in) See if a lot of dust has collected everywhere and clean it up. try tightening up whatever you can and try booting again with your finger holding down a keyboard key. This should cause an error and a beep code. If it does, try booting normal, going into setup with either esc del or F10. If you get to post you have won.
Aug 22, 2010 | HP Media Center m7250n (ED842AA) PC...
Computer beeps and fails to start
If there was recent hardware added to it or RAM then try removing it and boot up. You can try resetting the RAM. You can also check all cables and power within the case to make sure everything is connected properly. Listen for the fan on the PC, if the fan doesn't start up then it could be an overheated mother board. Beeps can mean a number of different things. If there's no error on the screen then it probably isn't getting further then the BIOS. I hope that helps.
Apr 06, 2009 | HP Pavilion a1410y (RB042AV) PC Desktop
Hp pavilion f1903 flat panel
The problem is with the inverter board. It is pulling down the main power supply and cycling it on and off (crowbaring). If you disconnect the power supply cable to the board, the power supply will stay up and the power on lamp will cycle as normal. There seems to be a problem with one of the high voltage transformers on the board. I will let you know if I can find a suitable replacement of if there is a way to get an inverter board inexpensively. Good luck!
Apr 23, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
My monitor screen stays black when i turn my pc on help
have heard some beep,eihther long beep or short beep? if you heard a short beep replace your memory and when it is long beep replace your video card but if no beep,there is a problem in your motherboard
Nov 01, 2007 | Fujitsu Siemens Siemens Business Line 19P4...
HP 5188-2545 Compaq Motherboard Hp/compaq Desktop Emery-ul8e Sata Asus P5lp-le E Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
