Question about 2001 Volkswagen Cabriolet - All Cabriolet models - Silverguard Plus Car Cover
2001 volkswagon caberet dies when you put it into gear
    Genius:
  • 1,098 Answers
Mrs. Melissa. A possible cause on this problem you do have is not a major one. Actually you will need a good mechanical knowledge person,to follow what I advise you to do for first step,to see the difference. Do not try it yourself. First the air intake flex hose connecting the Air filter with the engine throttle ( for acceleration ) has to get removed. on doing so,then has to check the throttle body where the air gets into and on opening the throttle,by just turning the ignition switch and the person who is on the drivers seat to put his foot on the acceleration pedal fully down,in order to cause the throttle to open fully. the good mechanic to try cleaning the throttle area by using a special cleaning stuff called ( carburator cleaner spray) I personally use this spray which is made in USA from Master. on doing the cleaning has to be careful not to force the throttle otherwise you will damage the it. on cleaning the side wall and the throttle itself,just release the accelerator pedal and switch the ignition off, put the intake hose back on place,start the engine and let it idle for few seconds and then try engaging the gear and see how it works. Good luck
Posted on Feb 13, 2014
2001 XV 1600 Road Star Silverado lurches forward and dies when put into gear
Hi, Tom and the usual suspects are:
1. Clutch not properly adjusted.
2. Clutch plates rusted together.
3. Hydraulic clutch needs bleeding.
4. Faulty clutch slave cylinder.
5. Faulty clutch ramp mechanism.
6. Broken clutch rod
7. Clutch pack loose on the main shaft.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Re dies when put in gear Road Star Forum Yamaha Road Star
runs at idle but dies when in gear
Yamaha XV16AL Service Manual
OEM parts for Yamaha
YAMAHA XV1600A Owner Manual
Aug 11, 2017 | 2001 Yamaha XV 1600 Wild Star
2001 escape vehicle dies when put into reverse
If it also dies in drive it is a TCC (torque converter control/lockup) valve that is stuck or the TCC solenoid. If it drives forward, then it is internal problems. Planetary gears/sun gears that have broken.
Apr 12, 2015 | 2001 Ford Escape
2001 Hoda Accord Idles Rough and dies when put into gear?
Check the fuel filter. It might not be a bad idea to do a tune up.
May 01, 2014 | 1994 GMC Sierra
2001 Honda Accord idles rough and dies when I put it in gear
change your fuel filter and check your fuel pressure, check air filter,
May 01, 2014 | 1993 Honda Accord
Truck dies when you put it in gear
Did you change the fuel filter and check the fuel pressure at the regulator?
Use a bottle of yellow HEET dry gas / fuel dryer to remove moisture in your fuel tank.
Jan 19, 2014 | 2001 Chevrolet S-10
Difficult to put into first gear. 1987 volkswagon cariolet
if it's a standard. the syncro for first gear in the transmission is bad. every gear has a seprate syncro which why the clutch is in puts the gear in sync. so it wil go into gear. they tend to go after years of use. first gear or reverse are usually the first to go because they get the most use
Aug 16, 2009 | 1987 Volkswagen Cabriolet
98 volkswagon jetta runs fine but shuts down when going to drive
need more info.does it stumble then die.had anyone look at it recent?does it change with ac on?
Aug 04, 2009 | 1998 Volkswagen Jetta
2001 Volkswagen Cabriolet - All Cabriolet models - Silverguard Plus Car Cover Logo
51 people viewed this question
Top Coverking Vehicle Parts & Accessories Experts
David Harrelson
David Harrelson
Lawrence Oravetz
Nicola Conroy
Are you a Coverking Vehicle Part and Accessory Expert? Answer questions, earn points and help others
