My intermec ck60 handheld is stuck on starting windows screen and will not reboot what can I do to fix it
3 Suggested Answers
thesuperdude
  • 97 Answers
SOURCE: Connect MC9090-G to an Intermec 2100 Access Point
Make sure that the ESS ID and security features match the ones on the AP.
Also, from the MC9090, you will need to click on the radio icon, select options and in the top drop down menu, choose regulatory. select the country where you are and uncheck the box named enable 802.11d.
This should have the terminal connected on to the network.
Posted on Mar 26, 2009
  • 61 Answers
SOURCE: Keep getting error Cannot execute btcc.exe
If your device is registered at Intermec.com you should be able to dowload a firmware flash for the device. Follow the instructions and reflash the device. If this does not work the bluetooth radio could have malfunctioned.
Posted on Apr 05, 2009
Reset intermec cn70
There are 3 ways to reset the device:
Warm Boot - When an application becomes unresponsive.
Press the Yellow Power button (also referred to as the IO Button) and select the reboot option.
Cold Boot - When device itself becomes unresponsive, will loose any cached data.
Press the Yellow Power Button (also referred to as the IO Button) to suspend the device. Remove the battery pack and press the reset button in the battery compartment (Round rubber button). Replace the battery pack and press the yellow power button or IO button. The blue Intermec startup screen appears.
Clean Boot - When device itself becomes unresponsive and cold boot fails, device will be restored to factory state, all data and installed applications will be lost except for data stored in Flash Storage.
- Firmware 1.50.19.0013 and prior -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) and volume down button (the lower
button on the right side) together until a message box appears on the screen stating the clean boot. Press the volume up button (the upper button on the right side) to confirm the clean boot.
- Firmware 1.62.27.6 and later -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) for 8 seconds. Message box will appear stating to release the power button. Press button number 1 then button number 2, confirm again by pressing button number 1 then number 2 again. Message box will state that the device is clean booting.
Jun 20, 2014 | Intermec CN70 Handheld Mobile Computer...
Need to disassemble CN50 to retrieve SIM card
hi
Page 60 has the answer, it may be very stiff, gently tug it with some small pliers.
http://www.milesdata.com/documents/INTERMEC/CN50/-intermec-cn50-user-manual.pdf
Mar 06, 2013 | Intermec CN50 Handheld Mobile Computer...
CK71 stuck on Launching OS
Hi
Please try to Install OS through Intermec Smart System from intermec.com - downloads
and try to install OS via WIFI connection
Note : Make sure about WIFI Connection & Battery Charging power of device
Regards
Aug 22, 2011 | Intermec CK71 Handheld Mobile Computer...
Hi, my intermec ck3 has intermettent signal problem hope that you can give me some tips to solve this. Many thanks..
it could be a couple of things such as the environment it is being used....porr signal is usally caused by the WIFI network it is connecting to or the environment.
May 13, 2011 | Intermec CK3 Handheld Mobile Computer -...
Feb 11, 2009 | Intermec Computers & Internet
Intermec CK30 Won't Display Desktop
The ck30 does not have a desktop. Press the green then orange key to access the system menu. Alt then escape will bring up the task manager.
Nov 27, 2008 | Intermec CK30
Intermec 751B problem after clean boot with iconnect
I had same problem with my Intermec CN3e after updating firmware OS. I also have updated the SSPB version (see it on intermec web site) and problem has been solved.
Nov 18, 2008 | Intermec 751 Barcode Scanner
Intermec CK31 handheld - Configure to read bracket symbol
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Mar 10, 2008 | Intermec CK31 Portable Terminal
23 people viewed this question
k24674
