Question about Crosley Cr6008a Record/cd Turntable Belt Drive -cr6008abk-
Crosley cr6008a cd door wont open
I press the open/close button and the screen says "open" and the cd rack doesnt come out.
  • 183 Answers
SOURCE: Crosley Dryer Won't Stop When Door Open
Yes, however befor replacing just check it is not jammed on be abiuld up of fluff around microswitch Regards Advisor
Posted on Aug 30, 2007
djnick989
  • 1067 Answers
SOURCE: crosley songwriter cd recording problem
maby the formatt its wrinting on is ther any options in menu of it to set the output formatt to mp3
Posted on Jan 22, 2008
  • 133 Answers
SOURCE: Crosley Radio CR246 CD door will not open
Try checking these:
- the CD door motor rubber drive belt (if there is one), it could be either loosened or broken, if so, it needs to be replaced
- the door open/closed sensor switches (contacts), they could be oxydized or damaged, they are located somewhere under the CD tray, possibly at the front end of the unit (depends on brand and model), you need to clean these with some fine sandpaper
It could be something else like the door motor driver IC, the power supply for the motor, a bad capacitor in the motor drive section, a loose connection or a broken wire somewhere, but hopefully, it's just a bad rubber belt or a dirty contact.
regards
3rq8 (Triarcuate)
Posted on Aug 08, 2009
earlnuton
  • 39 Answers
SOURCE: I have a Crosley CR
get a new one problem solved
Posted on Dec 20, 2010
  • 298 Answers
SOURCE: cannot open cd area when
There are two likely causes:
  1. a CD is not located properly in the tray and is causing the drawer to stick. Solution - try to very gently insert a very thin blade at the bottom of the CD tray and prise it open - but don't force it if it won't budge. If that doesn't work try sliding the blade in at the top of the tray to press the CD down.
  2. If a jammed CD is not the cause then it is likely to be the rubber drive belt that operates the tray has broken - they are not normally accessible so take it to a repair shop
Posted on Feb 10, 2011
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer ยท CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
My Marantz CD 53 CDplayer door is not opening. what is the solution
You probably have a broken belt on the cd tray so it's neither open or closed, if the laser's ok thats why it wont play
Mar 31, 2014 | Marantz Audio Players & Recorders
CR 248 cd tray will not open
It possible that a belt has broken or come off. You need to look inside. If you need a new belt just measure the diameter in MM and search Google for the nearest size to your measurement.
Dec 28, 2012 | Crosley CR248 Turntable
The gears are jammed, or the timing gear is out of sync, and possibily a bad loading belt.
May 20, 2012 | Philips Audio Players & Recorders
I have a Crosley Range that is self cleaning oven. Lost the manual..do I just press the CLEAN button for the oven to be cleaned?
You also have to close the oven door lock or Clean just wont happen. When the Clean light turns off, you are done.
Mar 05, 2010 | Kitchen Ranges
Try checking these:
regards
3rq8 (Triarcuate)
Aug 08, 2009 | Crosley CR248 Turntable
Front door won't open
open the player wit the door ejected then clean all dust particles inside it especially below the door and on the way where the door closes ... and then also clean the rubber belt & near by which is connected to dc motor... and clean the lens also... remember clean only wit dry clothes...
if the door doesnt open means just hit on upside surface lightly after pressing eject button only...
Feb 03, 2008 | Technics SL-MC700 110-Disc CD Changer
CD Rom Driver door won't open without using the straightened out paper clip or pressing the driver door button upwards of 15, 20 or maybe 25 times. It will eventually open after repeatedly pressing for...
If this happens with all your CDs and everytime, I would suggest you should replace your CD Rom Drive with a new one. After use of some years CD Rom Drives have such problems. Otherwise a software might locking your drive. you should find a tool which unlocks the drive and then press the eject button.
Oct 06, 2007 | Acer Aspire M1640 Refurbished Intel...
Crosley Cr6008a Record/cd Turntable Belt Drive -cr6008abk- Logo
23 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Rob
Rob
Level 1 Expert
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
