Question about JVC KD-G720 CD Player
Screen scrolls demo mode won't stay on clock
Screen won't stay on clock scrolls demo mode
F&p OB60SL11DEPX1 built in oven. Bought this as an off the floor demo. Just installed it. All the functions, clock etc work but elements not heating up. Troubleshooting says it might be in demo mode!!
It could also be a faulty circuit breaker. If one of them trips internally it may not trip the handle or indicate one is tripped. This situation allows only 120 volts to reach the oven instead of 220. That's why the clock functions but not the elements. To turn off Demo Mode:
1. Press SETTINGS 12 times. "Demo Mode" and "ON. Press (1) to OFF" will appear in the display text area.
2. Press the "1" keypad to change the Demonstration Mode setting to Off.
3. "OFF Selected" will scroll in the text area. Demo Mode has been turned Off.
Oct 22, 2016 | Ovens
Sony CDX-S2210 CD Player stuck on demo mode , cant adjust volume eq, skip track or anything
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Jan 28, 2010 | Sony CDX-S2210 CD Player
How do you set the clock on a jvc kd-g230 car radio
There is a misprint on manual concerning setting the clock. This is the case for similar JVC mobile head units.
The proper way to set the clock for this unit is:
1.)Hold down 'SEL' button count to 3 seconds
2.)Immediately after release of 'SEL' button hit the '>>|' button
This will allow you to enter 'PSM' menu. Every time you press '>>|' it will cycle between, 'CLOCK HOUR','CLOCK MINUTE', and 'Demo' Mode.
3.)Adjust settings by using the 'turn knob' and make sure 'Demo' mode is set to 'Demo Off' for the clock to stay set.
Nov 17, 2009 | JVC KD-G230 CD Player
Setting the clock of JVC KD-G125 does anyone know what and how?
to adjust the PSM (preferred setting mode) items, press and hold the select button (SEL) for 5 seconds..you should see one of the items DEMO (default item) displayed on the display window..press the Up/Down or Forward/Reverse buttons (^ or >>| or |<< ie.. it is the one you use to change the radio stations) to scroll to the PSM items DEMO-->CLOCK H-->CLOCK M-->L/O MODE-->AMP GAIN...when the PSM item you want to adjust displays on the window, CLOCK H for hours or CLOCK M for minutes for this case, use the control dial (volume knob) to change the setting...after adjusting the correct setting..press the SEL button again to end the procedure
Sep 06, 2009 | JVC AM FM CD DET FACE CAR STEREO
How do i take unit out of demo mode and set clock?
hold your sel. buton you use to get to bas, mid, and treble, and hole it down for a while till a new menu pops up. scroll using up/ down buttons till you see demo and left right changes the setting for it
Apr 27, 2009 | Car Audio & Video
Displaying time ALL the time
It sounds like its stuck in "demo mode" Look for a user menu for making clock changes,illumination etc...and turn off the scrolling demo mode...
Mar 21, 2008 | JVC KD-G110 CD Player
RCA,RP9328A,Audio System
I did the following to set the clock:
1. Press the Timer/Clock button until "CLOCK" shows, blinking, on the display.
2. Press Set/Demo. The hour indicator on the clock should start blinking.
3. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
set the hour.
4. Press Set/Demo. The minute indicator on the clock should start blinking.
5. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
set the minute.
6. Press Set/Demo twice. (Pressing once moves to the timer set mode.)
Feb 09, 2008 | Audio Players & Recorders
Sony demo
Had the same problem. The display of the home cinema system kept showing "sony demo". I went to the system menu and reset all settings to factory!
Nov 20, 2007 | Sony CMT-M100MD\W CD Shelf System
Demo Mode
press and hold the mode button for more than five seconds. Then use the knob to scroll to "Default". This sets the stove to normal operation.
Dec 09, 2006 | Bosch HGS435UC Gas Kitchen Range
JVC KD-G720 CD Player Logo
24 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
