Question about Hitachi Gst Hitachi L32S02A LCD Multisystem TV
Lost Picture My sister accidentally sat on the remote last night and the picture disappeared as well as the sound. How do I get my picture and sound back?
The TV was on & I muted it & put the remote in my lap. I must have moved & accidentally pressed a button & the picture disappeared. We have sound but no picture
Remove batteries from Remote. Remove wall plug to television and count to 10. Replace remote batteries. Plug television back in.
If it still does it, check Input, and check brightness settings.
Oct 13, 2016 | Televison & Video
Last night my tv worked just fine this morning I go turn the tv on and there's no sound but there is a picture on my 50" Hisense flat screen tv
Check all sources , ie cable box, dvd player or video game. If all have no sound check mute setting in menu or on remote. iI just cable box or sat receiver or evan att uverse box turn them of then back on. the uverse box you may have to remove power. If still no audio request service. The problem is likely the main board or speakers .
Oct 02, 2013 | Televison & Video
I have no sound but perfect picture TCL l32m61az can you help
Remove set and a cable or sat box or a receiver if in line , remove all from power for several minutes and then power back, a reboot may help and cannot hurt.
Dec 12, 2012 | Televison & Video
I cant get a picture on my tv. DM Tech LM37xty
Either bad main logic board or bad lcd panel. If bad panel, it's not worth repair. Can find main board at Encompas Parts.
Nov 16, 2011 | Televison & Video
I accidentally pushed the aux button last night. Now the sat button won't come on and I can't access the dish receiver with the remote.
Hi my nameis Mike Houston of DISH Network and I see you pushed the AUX button and the SATbutton will not light up. There is an easy fix to this, first replace thebatteries and try the Sat button. If the Sat button will not light up pleasereaddress the remote, I will send the link to help with these steps. http://www.dishnetwork.com/SupportSection/remote-setup
May 21, 2011 | DISH Network IR Remote Control
The tv is jammed. Remote is fine but have pressed the wrong button
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux modes. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with!
-Kirstie DISH Network
Oct 01, 2010 | DISH Network IR Remote Control
My car has a remote starter and last night while it was parked in the garage it started all by itself
is there any chance the remote could have been pressed accidentally? maybe it was in your back pocket and you sat on it? or perhaps a child was playing with it? if not,there is a possibility the remote starter module in your car could have picked up a "phantom" start command signal caused by radio interference.
Feb 17, 2010 | Vehicle Parts & Accessories
When I turn on TV I get a message no video input. We never use video with this tv. Only have it for looking at satelite. The other main tv is working fine. I pressed all the buttons but nothing works.
Sounds like the input accidentally got changed. On the remote that came with the TV, push the INPUT button until you get your satellite picture again. If your SAT. remote is programmed to your TV, push the TV button, then the input button until you see your picture. If this doesn't work then the sat. cable is not securely attached or no longer works.
Aug 30, 2009 | Philips Magnavox 27MS343S 27" TV
Hitachi Gst Hitachi L32S02A LCD Multisystem TV Logo
13 people viewed this question
Top Hitachi Gst Televison & Video Experts
slammit
 Mikey
Mikey
ray gallant
Are you a Hitachi Gst Televison and Video Expert? Answer questions, earn points and help others
