Question about Milescraft Crown45 Crown Moulding Jig for Miter Saws
Mastercraft angle finder manual - Milescraft Crown45 Crown Moulding Jig for Miter Saws
Where I can find a Mastercraft Maximum Spin Saw Kit Manual ?
Try Googling (Mastercraft)(model)(manual) without parens OR contact Mastercraft directly.
May 15, 2018 | Mastercraft Saws
Demonstration of how to use the angle finder
Make and model of angle finder may help you get an answer.
Apr 19, 2018 | Cameras
Manual for mastercraft garage opener 046-0266-0
Try Googling (mastercraft)(046-0266-0)(manual) without parens.
Dec 12, 2016 | Building Materials
Mastercraft 55 6802 6 compound mitre saw parts manual
Request the parts manual directly from Mastercraft.
May 27, 2013 | Saws
Battery compartment in my angle finder overheats and battery indicator comes on a brand new set of batteries . why is that? i put a fresh set of batts.and when i turn it on the batteries on the right get...
There is an electronic component that is defective and it draws a lot of current (more than the normal rating) this makes the batteries over heat, if it's new ask for replacement of the tool.
Cheers!
Jan 12, 2011 | Bosch DWM40L Miter Finder Digital...
Unable to make a straight cut with saw. Tried adjusting tension, lowered blade, made sure blade aligned properly and did not feed too quickly. HEEEEEELLLLLLLLLLLPPPPPP! Thanks in advance.
Hello, I think that the problem you are having is called "drift" . each blade will cut different than the last. The way I was taught to cure this goes as follows.
-take fence off off table(or just move over)
-get a good square piece of material appx. 1x3 and mark a straight line about 1/2" from edge the full length of the board.
-with out the fence cut the board along the line appx. 1/2 the length.
-shut off saw WITH board in it.
-use a angle finder along the edge of the board, set angle finder
-remove board and put the fence back on.
-now slide the angle finder up to the fence, you should see that the angle is different than the fence (this is the DRIFT ), adjust the fence to the angle finder( I know that the smaller saws usalley don't have this adjustment ) you will have to find a way i.e. shim etc.
This is a very common problem but once you get the idea it is a easy fix
Remember: A guy taught me and I taught you, pass it along thats what we do.LOL
Hope it helped.
The Shop Dog
Oct 23, 2010 | Ryobi 9 in. Benchtop Band Saw
Mastercraft Prostar 197,2005. Electrical problem?
Try your tether , plug and unplug it a few times , sometimes they stick, get corroded from the water..
Aug 22, 2009 | Garden
Skil 2100daf angle finder
I was trying to reset the zero on my angle finder. It's a Powerfist Digital Angle Finder, the same as the Skil 2100.
After turning the unit on, if I press the Miter and Hold button together and hold them, the unit goes into 'calibration' mode. (The display flashes 0.0). If you do nothing, it will always stay in this mode forever after that.
You can then reset your unit - it takes time however and patience.
With the aid of a large protractor, draw angles on a large sheet of paper (I used a couple of 11 X 17" pages) from 0 degrees all the way up to 220 degrees.
Turn on your angle finder and make sure the numbers are flashing 0.0. This will be your 0 degree reading. Hold the finder closed and press the Hold button once.
The display will now read 10 degrees. Open up the finder until it matches your 10 degree marks on your paper and press the Hold button again.
The display will now read 20 degrees. Open up the finder until it matches your 20 degree marks and press the Hold button again.
Continue setting your angles in this fashion up 'til you reach 220 degrees. The next button press will close the calibration cycle and the numbers will stop flashing.
Your unit is re-calibrated. Now, if it's off - you've only yourself to blame.
Apr 23, 2009 | Skil 2100DAF Digital Angle Finder
Milescraft Crown45 Crown Moulding Jig for Miter Saws Logo
64 people viewed this question
Top Milescraft Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Milescraft Saw Expert? Answer questions, earn points and help others
