Question about Safe International Home Security
Opening a Melnik safe
Know the combination but don't know where to start the dial has two markings besides the #'s A straight heavy line and a cross type mark. Which mark is the start and end ? Also the com has 4#'s is it LRLR or something else?
SOURCE: know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
Posted on Mar 18, 2009
SOURCE: sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Posted on Apr 09, 2009
loxmith
  • 21 Answers
SOURCE: Safe SENTRY S3877 can not open the door
here is the number for customer service, 800-828-1438
Posted on Jul 24, 2010
SOURCE: sentry 2260 fireproof safe
A good locksmith should be able to help you
Posted on Aug 09, 2010
SOURCE: Need assistance opening my Sentry
Locksmith instructions for sentry safes
on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking sentry safe open.
Posted on Sep 18, 2010
I forgot yo open a security box. Please let me know how.
1 You will need to find out the combination. The first thing to do is to move the entire dial that is in the lock to the right. This will let you know that all the wheels are disengaged. 3. You will need a stethoscope. Each time you turn the dial, you reach the point of the combination number you can hear a click here. You should make notes considering the numbers you can read on the dial each time you hear two clicks. This will help you know the length of the combination. You must use a stethoscope to listen carefully and precisely where the clicks sound. 4. Repeat the process. Then repeat the process considering the number of clicks you hear in the process, repeat several times to make sure you're right about the number of click. This information should be represented in a chart in order to know the numbers of the combination to open safe. You have to start testing the clicks generated by the box when the dial is turned, the dial should be at zero.
5. Combine data to open safe. With the data obtained when listening to the clicks generated by the dial, you should start making combinations and test them in the safe until you get the perfect combination that will help you open the safe. Example if when turning the dial you could hear 3 times two clicks, ie the combination of the safe must have 3 numbers. Consider the exact numbers you could see on the dial when you heard the clicks. Then you must have something like this in your notes (2, 65, 34). Start combining them and try in the safe until you find the right combination, start making patterns and discard. Then those copied in your notes will be the secret code numbers that will open safe. It is very important that you have been very careful when listening to the clicks and that this process has been done several times to be sure that these numbers are correct. Now you can make patterns, considering the numbers that you raise in the example, such as: 2.34,65); (34,265); (65,2,34) and so on until finding the correct one. That is why you need to write down all possible combinations and tosa trials. Remember the success of, without opening your safe, without a locksmith, and also considering that you do not have the possibility to call a manufacturer. Be: • Listen carefully to the sounds of the clicks you hear in the safe. • Avoid other sounds that may distort your ability to listen carefully • Record exact numbers where you clicked • Be patient and test your combinations. You must have on hand the instructions of the manufacturer of the safe, if you do not have it, look on the web since surely the manufacturer has a page where you can find this information. You could also call the manufacturer and prior identification will give you the key to your safe. Otherwise and if you've tried all the possible combinations and you just can not do it, call a locksmith. You no longer have a bad life and recover your valuable items, open safe can generate waste of time but if you strive you will stay with great satisfaction.
Aug 13, 2017 | Cell Phones
Can u assist me with opening my safe
Our tech team at Quality gun safes wall safes and floor safes store in Burlingame Ca produced this video
Nov 04, 2014 | Sentry Fireproof Safe
Have older sentry combination safe, i have combination but don't know procedure to open
left right left right 4,3,2,1 start from zero, count the first time the number passing
Nov 07, 2011 | Sentry FIRE-SAFE Combination Safe DS3431,...
Safe open but in locked position
I can't tell you how to set a new combination, without you having a tumbler key.
BUT I can tell you how to figure out the old combination.
First remove any armoured plate that covers the back and unscrew the cover plate. You will see wheels with slots cut in them. These are the tumblers. Now just like you know what the numbers are rotate the dial three times counter clockwise...then looking in through the back cover , slowly turn the dial clockwise ... look for the tumbler that is turning and stop where the slot lines up with the drop arm. Now look on the dial and write that number down. Now start on the second number by turning the dial counter clockwise until the second tumbler is lined up with drop arm. and so on
With a little patience you will figure it out.
I hope this helps you.. If you have any questions please ask.
Good Luck,
RSMITH972278
Oct 05, 2009 | Locks & Locksmithing
Harldline safe not opening
Sure blame the poor kid.
Think about it, what good would a safe be if by pressing a few keys the combination was changed?
As with any combination safe you need to clear the combination by turning one, two or three times in the opposite direction before entering the combination.
Now say your sorry to your kid.
Jul 24, 2009 | Safe International Digital Electronic Safe...
Brinks fire resistant safe model 5059 instruction manual
Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Apr 30, 2009 | Computers & Internet
Know combination, but cannot open sentry safe 1250
Feb 28, 2009 | Sentry Fireproof Safe
Need assistance opening my Sentry 1250 safe. I have combination but do I start at 0 and pass the first number then stop 2nd time around at first number then go straight to the other 2 numbers?
May 06, 2008 | Sentry Fireproof Safe
Home Security Logo
94 people viewed this question
Top Safe International Home Security Experts
Computer Repairing
Computer Repairing
Theo Nikolaidis
Theo Nikolaidis
Andrew Taylor
Andrew Taylor
Are you a Safe International Home Security Expert? Answer questions, earn points and help others
