Question about Sherwood Amphos Watch Dive Computer
1. How do I turn ALE "on". It is fixed in the "off" position and I cannot set alternative time?
DID BUDWEISER CHANGE THERE NAME TO AMERICA
Budweiser American Ale was an American-style amber ale produced by Anheuser-Busch under its Budweiser brand. Introduced in September 2008, and discontinued in 2011, American Ale was meant to appeal to beer enthusiasts who were looking for a more complex flavor than the popular Budweiser lager.
It had 5.3% alcohol by volume and was widely available across the United States. A 3.2% alcohol by weight version was available in select states as determined by local laws.
May 18, 2016 | Wine & Spirits
87 Chevy pickup 305 has very high idle but runs great other than that. I've try tuning it down by turning the distributor had it sounding nice but no power on take off any thoughts
With the later model cars and trucks that are computer controlled, fast idles often means that there is some sort of vacuum leak in the intake side of the engine. Turning the distributor will slow the idle, but it also changes the engine timing, and this will result in the loss of power you are experiencing. The catch-22 of this is that now, until you can find and fix the source of the intake leak, you won't be ale to effectively reset the timing to the correct position.
Dec 29, 2014 | Cars & Trucks
Mp220 absorber full check printer 5b00
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The LED lights in green to indicate that a function
is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Times LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print See APPENDIX 1, SERVICE TEST PRINT.
2 times Green EEPROM information print See APPENDIX 2, EEPROM INFORMATION
PRINT.
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting
5 times Orange Destination settings Proceed to the step 5), and follow the
Destination settings procedures.
6 times Green Print head deep cleaning
7 times Green CD-R test print Not used in servicing.
8 times Orange CD-R print position correction
(horizontal)
9 times Green CD-R print position correction
(vertical)
10 times
or more
Return to the menu selection
Feb 05, 2014 | Canon PIXMA iP3300 InkJet Photo Printer
1997 cadillac deville wont turn over. my new batt. is drained, what do i do?
check the drive belt condition and tension first as the initial tension setting may now be loose.
May 17, 2013 | 1997 Cadillac DeVille
What is the difference between an ale and a lager?
ale is brewed with ale yeast, lager is brewed with lager yeast.
Feb 03, 2013 | Wine & Spirits
How do I replace the Alternator on a 98 Saturn Sl1
Remove the plastic inner fender shield by turning the screw counterclockwise, then pulling the plastic free from the pop rivets. Set the shield aside. Disconnect the alternator's primary charge wire. Press the tension pulley firmly to release the tension on the primary drive belt, then slide the belt off of the alternator's pulley wheel. Unbolt the alternator from the mount by reaching into the engine compartment through the wheel well and turning the two mount bolts counterclockwise. Manipulate the alternator out of the engine compartment through the wheel well. Reconnect the primary charge post nut, securing the output wire back onto the alternator. Position a new alternator into the mount and secure it by turning its bolts clockwise. Replace the fender skirt shield by pressing it back onto its clips or pop rivets, then turning its screws clockwise. Replace the wheel and Reconnect the battery's positive terminal. Here you can find the Wholesale Alternators parts http://www.autopartspoint.com/products/alternator.html
Aug 26, 2011 | 1998 Saturn SL
The key won't turn off completely to remove from ignition unless i remove the pos battery cable first
DONT REMOVE POSITIVE BATTERY CABLE FIRST YOU WILL SHORT OUT THE PCM AND THE ALTERNATOR.IN CASE YOU CANT TURN OFF CAR ONE TIME DEAL DISCONNECT NEGATIVE BATTERY FIRST. BUT FIRST TURN OFF RADIO BEFORE REMOVING BATTERY CABLE.YOU NEED TO FIX IGNITION SWITCH LOCK CYLINDER DONT KEEP DISCONNECTING BATTERY WHILE ENGINE RUNNING BECAUSE YOU WILL DAMAGE PCM.AND SHORT OUT ALTERNATOR VOLTAGE REGULATOR.
Jan 18, 2011 | 1998 Mazda Millenia
I replaced the ale and battery and the red battery light stays on
You need to take the car by a PepBoys or other repair shop, where they will check your battery and charging system for free. It sounds like you may have a bad alternator.
Nov 23, 2010 | Pontiac Sunfire Cars & Trucks
Can't get the timer to turn on
Woods timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
You posted under Woods 59383.
Plug timer into wall after setting timer.
Maximum load 500 watts, used for indoor or outdoor
Set current time, rotate dial until current time lines up with black triangle.
Around outer edge of dial are segments.
Pull up all segments for times you want timer OFF
Leave segments down for times you want timer ON
Locate switch on timer.
Push switch so the V shape is down.
Plug into wall outlet, plug Christmas lights into timer
Drink ale and eat turkey legs.
Add a comment if this is not your timer, or if you need more help.
Nov 23, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Low tire pressure warning light stays on
I brought my RX350 to the dealer for this problem before. They told me to inflate my tires to 36psi for winter time although the recommended pressure is 30 psi
Dec 03, 2008 | 2008 Lexus Rx 350
Sherwood Amphos Watch Dive Computer Logo
573 people viewed this question
Top Sherwood Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a Sherwood Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
