Question about Coffee Makers & Espresso Machines
Saeco 7p diagrams
Water not getting hot
2 Suggested Answers
PlatoAu
  • 67 Answers
SOURCE: configure the saeco coffee vending machine type AD 7P PLUS
Hope this is what you're after
http://pdf.archiexpo.com/pdf/saeco/7p-plus-11410-3425.html
Posted on Apr 10, 2009
Saeco 7P Not Dispensing Product
Rick:
Here are some possible causes:
- for the top five selections (the ones that use espresso), the first sound you hear after making a selection should be the grinder starting. If no sound, check that grinder is receiving 120V.
- do the bottom 2 selections work (the ones that don't require espresso)? If not, inspect the ribbon cables leading from the selector circuit board in the door. The is a sharp edge on the door hinge which could damage these cables.
- if the selector circuit board was ever removed, it may not have been replaced so that pushing the buttons on the door actually depresses the microswitches on the board. To test, verify that you can feel a click when you push each button.
- it might be a circuit board issue. Having two machines allows swapping of circuit boards between machines. Hopefully, you can come up with at least one set of functional boards.
- Good Luck!
Dec 05, 2011 | Coffee Makers & Espresso Machines
Saeco coffee vending machine 7P is reading OUT OF SERVICE 06, it is not blocked have checked everything.
7p wouldn't be displaying 06. My guess is you have a Saeco SG200. 06 means the cup dispensers jammed. Remove all cups and switch the machine on. if the cup dispenser make a clicking sound the the cames in the cup dispenser is jammed and needs to be freeed. if it works theres no clicking noise, switch machine off, and reload the cups in the tube that arn't directly over the cam hole. if this is an ongoing issue, tell me what colour are the cams (theres 5 and there black or white) and describe the cup that your using.
Mar 16, 2011 | Kitchen Ranges
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Amtrol water heater WH-7P gets barely warm water
From what you are saying it sounds like an issue with either a circulator pump or a zone valve. It depends on what type of system you have ... if you have a circulator pump that only runs the Amtrol then that is probably bad. If you have a zone valve system then it is probably the zone valve if you still have heat for the rest of the house. If you have no space heating then it is probably the circulator pump.
Nov 04, 2009 | Water Heaters
I have Saeco Royal Coffee Bar. Hot water and
Hi
You may have a flow meter that is bad. If its white plastic check for corrosion at the wire terminals. If your have corrosion change the meter and you should be good to go.
Apr 10, 2009 | Saeco Royal Coffee Bar Coffee Maker,...
Configure the saeco coffee vending machine type AD 7P PLUS
Apr 05, 2009 | Saeco Royal Professional Espresso Machine
Saeco Incanto expresso machine is producing thin, watery and cold coffee. I have walked through some troubleshooting with a Saeco rep and no better results. The top warming plate stays hot. Water flows...
It sounds like the heatingellement of the boiler is broken.Pump works. you also , if i am right get no hot water if you try that.
You can get the part on line. which will be cheaper than doing it through saeco
Try this link SAECO PARTS
Placing it is not too hard as long as you work methodical.
Apr 28, 2008 | Saeco Incanto Classic Espresso Machine
Coffee Makers & Espresso Machines Logo
16 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
