Question about Sony Playstation 3 (PS3) Console
Can i make the mane power override the stand by power on my ps3?
My ribbon went out and I was wondering if can use the switch in the back for my mane power.
    Problem Solver:
  • 19 Answers
Yes you can. However! ! I DO NOT recommend it. It is not good on the hard drive to shut the system down that way. I would order a new ribbon cable for the power button. They are not hard to replace and only a few screws holding the cover down to gain access to what you need.
Posted on Jun 19, 2014
Had my finepix f450 apart and now that its back together the on/off power switch wont work but it'll power on on cradle it. so it must be something i did putting it back together.any ideas
OK - so I've taken mine apart to see what may be causing this. The problem is most likely that you put the camera back together with the power switch set to off. In this position the metal slider that activates the power switch touches the fragile plastic tongue of the actual power switch and will sheer it off when the case is pressed together. However, the slider won't touch it when the camera power switch is moved to its 'on' position during re-assembly.There is no easy fix other than to either replace the module containing the switch or if you're a tinkerer de-solder and disassemble the switch and refashion the tongue that depresses the micro-switch by using maybe a piece of nylon from a small tie string (Ty-wrap) or alike. It's a fairly small switch, however. Finally, perhaps you could obtain a replacement switch from the manufacturer or an electronics supplier. By default, this switch will be on so removing it from the cradle should turn the camera on and inserting into the cradle should turn it off. So, if you can find a free or cheap cradle connector you could use it as a makeshift power switch or you can always bring the cradle along to turn it on - the camera's power timeout will then turn it off automatically ;) Hope this helps.
Feb 08, 2010 | Fuji FinePix F450 Digital Camera
Sound but no picture!
I had thesame problem and I took off the battery, disconnected all power to the unit, and then unscrewed all the screws located under each grey circle as well as the one under the "warranty void if removed' sticker. There I found the ribbon that went to the monitor had been pulled from its place from what appeared to be twisting the screen in the wrong direction. Upon carefully lifting the motherboard I found the slot the ribbon went into, worked it back into the slot, put all back together and it works fine. Good luck!
Jul 01, 2009 | Protron 7" Portable DVD Player
The power switch came off of my subwoofer.
Same thing happened with me. Did you ever find a solution?
Nov 28, 2008 | JBL S120PII Subwoofer
IBM Selectric III Typewriter Ribbon help
There are two different ribbons for the selectric III one has the ribbon lift guides built into the ribbon the other the guides are part of the typewriter. The first is a General Ribbon T=387 the other is a G.R. T-385.
Hope this helps;
DickyO
Sep 01, 2008 | Lexmark Wheelwriter 15 Series II...
PS2 slim, Bad Power switch is there a bypass to turn the unit on ?
Ouch you got good news and bad..
Bad first. Your PS2 will not work without that ........
But The Good news im sure you might know somebody that has a junk ps2 if you can get your hands on it there is your fix... Sadly Sony wont send you one . try turning the cable around and useing the good end.. ill shoot you a vid that might help
Aug 04, 2008 | Sony PlayStation 2 (PS2) Console
Beeping sound when powering unit on
Have you simply pushed the carriage back to the middle? If it is like the ML100 (it looks the same) you can just push it over ...with the pwoer off. Then put in you new ribbon. And this time, when you turn it on, it is the new ribbon that hits a switch on the underside of the keyboard, located to the upper left. If you do not have a ribbon installed, it will travel all the way to the left, and beep, beep, beep, beep. ,,,, The switch is hit with the ribbon housing.
Jun 25, 2008 | Brother ML-300 Typewriter
Onceturned on, the green light goes on, the touch screen flashes white, then it all turns off.
You might only have a loosen screen ribbon cable.
If not careful while taking out the top screen ribbon you can damage it causing blank screens and finally the DS wont work.
The solution to a broken top screen ribbon is to replace the whole screen in DS lite or buy the ribbon cable in the DS fat and replace.
If the broken top screen ribbon is caused by broken hinge then you should replace the shell also to avoid other broken screen.
May 22, 2008 | Nintendo DS Lite Console
Ps2 disk tray wont open, power light is on, eject light is off
if the ribbon cable that goes to the lens came out its gota go back it. has a plastic tab on the top that lifts up and down to lock it in place....
If its the eject/reset button the ribbon might not be in all the way
Dec 30, 2007 | Sony PlayStation 2 (PS2) Console
Sony Playstation 3 (PS3) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
