Question about KitchenAid Architect Series Double Drawer Dishwasher Panel Ready Kudd03dtpa
Procedure for replacing upper drawer lock/latch on kudd03dtpa0 on kitchenaid dishwasher
KitchenAid kuddo3dtpa0 upper drawer latch/lock failed. Have part. Need procedure for accessing failed lock and replacement o0f same. Questions: 1)Can the latch/lock be accessed by removing the upper drawer module, or, 2) Does the entire unit require removal from under the counter? Thank you very much. Pat Duncan
  • Sky King
    Sky King Feb 14, 2014
    Regarding the above question on the failed "latch/lock" on the upper drawer. Turned out the problem involved a mis-positioned hose pack for the upper drawer that was preventing the drawer from being fully engaged in the 'full in" position. Repositioning of the hoses solved the problem. Thanks to all who took time to review/consider my problem.
SOURCE: Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
Posted on Nov 02, 2008
SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Posted on Jan 16, 2009
SOURCE: how do i unlock kitchenaid 2 drawer dishwasher
Did you find the answer?? Its on here....someone nicely posted it. What you have to do is hold down the ProDry button for 4 seconds and it will unlock. Apparently, this is a child-lock mechanism.
Posted on May 01, 2009
SOURCE: Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Posted on Jun 12, 2009
techbuster
  • 5081 Answers
SOURCE: KitchenAid dishwasher KUDS25SH - Can't operate because child lock
If holding the "Energy Saver/Dry" button does not solve the control board problem then most probably the control board would have failed and needs to be replaced .
To identify it we need technical expertise in handling the circuit boards and knowledge on usage of multimeter is must.
Posted on Nov 08, 2010
My top drawer of kitchenaid dishwasher lock light is on. I can't get it off?
It's a child lock. To turn off the child lock on a Kitchen Aid dishwasher, locate the Energy Saver/Dry button. Press and hold this button for at least four seconds.
Jun 20, 2016 | KitchenAid Dishwashers
My kitchenaid DW kudc101xwho will not stay on. Runs a few min and shuts off. Is this the control panel or the timer?
May be this is the reasons.
a) May be your door latch is opening due to pressure inside the dishwasher. The door latch opens and the dishwasher will stop. Quite common problem on KITCHENAID. KitchenAid door is a heavier door compared to sister product WHIRLPOOL. If door latch problem then has to change the door lock along with the top latch.
Sep 25, 2014 | KitchenAid Dishwashers
Replace check valve kitchenaid dual drawer dishwasher
look under the sink for the valve its huge an inline with the waste tube
if not then its here
https://www.youtube.com/watch?v=rOio5HaWeFU
Aug 17, 2014 | KitchenAid KUDD03DTSS DUAL DRAWER...
How to remove the upper rack on kitchenaid dishwasher
The upper rack has a captive washer with a lug that stops the top drawer from falling out. Use a torch, identify the captive washer that is connected to the rear wheel on each side if the drawer, remove these and the draw will come out
Jul 15, 2014 | KitchenAid 24 in. KUDP01FL Built-in...
Upper drawer dishwasher won't drain
First =check for a plugged drain line
Second = check for plugged screens in the unit.
It could also be your pump. The vanes are only plastic and they sometimes just give out.
Jan 07, 2014 | KitchenAid Kitchen-Aid KUDD03DTSS...
Kitchenaid dishwasher wont stay closed
you might need a new Latch, Drawer (left Hand) part number 8194053 okay
Feb 07, 2013 | KitchenAid 23 in. KUDD01DPPA Stainless...
Our kitchenaid drawer type dishwasher is open the locked light is on and we can not get it to clear or run
switch it of and leave for say 10mins and switch back on and see if it resets,if not push and hold the on/off button for about 30 secounds it should reset if not then the drawer switch is broken and needs replaced.adrian,,,,,,
Aug 20, 2010 | KitchenAid Dishwashers
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
KitchenAid Architect Series Double Drawer Dishwasher Panel Ready Kudd03dtpa Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
