Question about Tascam Cd-rw900sl Cd Recorder/player
What does "eject error" mean? - Tascam Cd-rw900sl Cd Recorder/player
    Scholar:
    New Friend:
  • 134 Answers
Your MD Recorder/Player has a stuck disc or cannot eject it properly. Basically it is not handling the disc safely and it may get snagged or damaged as a result of a physical mechanism which is not working correctly - out of allignment or worn out by people shoving discs into the machine or just plain old age on these units.
Posted on Mar 16, 2014
What does a Canon iPF750 Hardware Error 03800500-2F42 mean?
When the result of non-ejection detection is
as follows:
Complete non-ejection of one line in 1
chip.
(In either A line or B line, a complete
non-ejection of 1280 nozzles)
?Error code assuming broken flexible cable
or contact failure (heat enable line)
manual page 62
Jan 02, 2018 | Canon Office Equipment & Supplies
What does error code E-01 mean? CDs won't play and cannot eject trunk unit.
thats what i do with mine ,the phone thing but error E 1 means that a cd is jammed in the unit,happens to me all the time as i only use it for jaguar meetings .Now what you do is to pull out the cartridge and remove all the CDS then re insert it and press the eject button again and it might if your lucky retrive the cd in the player and return it to the cartridge ,.then refit all the others till it happens again
Apr 29, 2015 | Jaguar XJ8 Cars & Trucks
6 CD cartridge will not eject
If you are getting power to the unit and you hear it clicking and making a sound when you hit the eject button, the this means that a CD is jammed in the track and while it was changing it got stuck and now causes you to see an ERROR message.
What you do is while hitting the eject button, wiggle the CD MAGAZINE up and down and side ways. This will cause the CD to fall into place and your magazine will pop out.
KennyV
Jun 03, 2010 | 1997 Lincoln Continental
E-9101 and EJECT
E-9101 error is for Mechanical time out, it means your player can not read the disc within the given time period.
You may have to clean your player, there may be dust, dirt or other particle into insertion slot.
djajay@inbox.com
May 14, 2010 | Pioneer CDJ-800 Turntable
CD disk error
ok error code 1, look for this error code on your owners manual, toyota cd players give 3 error codes, this mean error code 1, error code 2, and error code 3, they all have different meaning please check owners manuel to see what does error 1 mean i will try looking for you
May 26, 2009 | 2007 Toyota Camry
Jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
Nov 07, 2008 | JVC KD-LX111 CD Player
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Error C:32:11 what can i do
This error means that the heads are not turning. This unit requires service. This is not a homeowner repair.
Dan
May 06, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
Alpine CDM-9803 Cd Player
You need to visit Alpines' site to download the owner's manual for your unit. In the mean time here is some info from the troubleshooting guide for your error code.
• Mechanism error.
1. Press the "eject" button and eject the CD.
If not ejecting, consult your Alpine dealer.
2. When the error indication remains after ejecting,
press the "eject" button again.
If the error indication still does not turn off after
pressing the "eject" button for a few times, consult your
Alpine dealer.
Note
When the "- - - E" is displayed:
In case that the disc cannot be ejected by pressing the "eject"
button, press the RESET switch (refer to page 4) and
Good luck.
Feb 08, 2008 | Alpine CDM-9803 CD Player
Rpd 552 cd reader problem
Message Possible cause Recommended action
E-01 Dirty disc. Clean the disc.
Scratched disc. Replace the disc.
Up-side-down. Check the disc.
E-02 Focus error. Try ejecting and re-inserting
under normal temperature
conditions.
E-03 Data and focus error. Under normal temperature
conditions, eject and
insert clean, undamaged
disc properly.
E-04 Mechanical problem. Eject and re-insert.
Oct 17, 2007 | Blaupunkt RPD 552 CD Player
Tascam Cd-rw900sl Cd Recorder/player Logo
175 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
