Question about Dell Inspiron Computers & Internet
Zalman m500wl I have a problem regarding cursor tracking in M500WL zalman mouse. Right and left click works fine, scroll is good too, but I cannot move the cursor. I already tried to change mouse settings, I was looking for some drivers (not found), changed usb settings in BIOS, edit registry, restarting computer, etc etc. I have a Windows 8 x64 on Dell. Any ideas? Thanks for your answers!
SOURCE: Wireless Mouse gets stuck
Take a eraser and use it to rub the contact points on your batteries clean. This seems to be the issue where your sensiativity will change by it self the the mouse has a 20 - 30 pause to reset it's self as if you just stuck a different battery in it.
Posted on Jan 13, 2008
  • 324 Answers
SOURCE: left click for mouse does not respond - right click very slow
Hey, pufpuf!
It's kind of hard to tell without actually looking at it,but
as skotkoir sez, replacing it with a good used on is probably the better way to go. Sounds like you have one of two problems. Either there is something (foreign objects, food, soft drink residue) that is binding up the buttons and/or making them sticky; or something has broken in the assembly. Not much that you can fix.
Posted on May 08, 2008
yooperbud
  • 8637 Answers
SOURCE: bluetooth keyboard and mouse not working with computer
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Posted on Jan 23, 2009
  • 25 Answers
SOURCE: Technika optical wireless mouse not working
Make sure the mouse is linking to the wireless receiver on you have plugged into the computer (there should be a reset button on the mouse to establish a new link).
Posted on May 14, 2009
romsky79
  • 822 Answers
SOURCE: IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Posted on Jun 02, 2009
My cursor disappeared on my Samsung 303C12. Is there a way to turn the cursor on and off?
It sounds like you turned off your track pad. On some laptops there is an indentation on the pad to turn on and off and some have buttons on the laptop. Did you go into your track pad properties to see if it is on? You can do this by clicking on the mouse on the lower left corner of your laptop or by going into control panel. I hope this helps.
Sep 16, 2014 | Computers & Internet
Connects and clicks just doesnt move the curser
I presume you can see the motion sensing red LED or laser beam shining under the mouse. If not, that has gone bad, and it would probably be more economical to replace the mouse than to attempt a repair.
If the light is on under the mouse, try cleaning the lenses (both LED and photoreceptor) with a cotton swab dampened with isopropyl alcohol (rubbing alcohol). Don't scrub, just wipe the optics gently until clean.
Nov 11, 2017 | Belkin Mini Wireless Optical Mouse...
This is a problem with a iHome Laser Mouse product. ihome 3-Button Laser Mouse Model Number- iH-M120LB Serial Number:0906001183 I am having trouble using the left click button on the mouse. I...
When you change the left mouse pointer to be the right mouse pointer in the settings of the mouse, then if the right mouse button stops working, it is a software problem and reinstalling drivers is the way to go. If on the otherhand the left mouse button still does not respond, then there is a problem with the switch in the mouse. This is hardware related. Either clean the mouse or buy a new one.
May 11, 2017 | iHome 3 Button Fast Track Laser Mouse...
I have an hp g60-535dx. my touch pad has been working 100% up until today when it just stopped working. i can turn it on and off but clicking right or left buttons doesnt work nor can i move the cursor...
HI
I would go to device manager
scroll down to find the touch pad
uninstall it
then restart laptop
hopefully when you restart windows will find new hardware
and reinstall the touch pad correctly
good luck
if not go to website and download another driver for it
www.hp.com
Feb 23, 2011 | Computers & Internet
How to ouse the mouse?
The mouse is used by people to navigate around the operating system like Windows.
There are a number of buttons on the mouse, Left Click, Right Click, Scroll Wheel and Wheel Click.
Your index finger operates the Left Click and you middle finger operates the Right Click and Scroll Wheel.
The mouse, when moved in turn moves whats known as a cursor on the screen, it's that arrow.
Think of the cursor as your pointing finger.
Hope that helps!
damnor01
Jan 08, 2011 | Computers & Internet
Hhow to save a pattern in fl studio and reuse the same in another
Open up the piano roll window for the sample you have selected. Use the highlight tool, which looks of a dashed square, to select the entire pattern by dragging your cursor from the top right corner of the piano roll diagonally to the left bottom corner of the piano roll. If you can't see all of the bars used, then try sizing the track in the piano roll closer together by placing your cursor on the square directly to the right of the horizontol scroll bar. Hold down the left click and move your mouse down to track the piano roll closer or move the mouse upwards to span it more. Select all of the bars used in the piano roll and click the down arrow in the very upright corner. Select Edit > Copy. This will copy all of the bars in the current piano roll. To paste the pattern simply click the down arrow again in the upright corner and select Edit > Paste in any piano roll.
Jan 20, 2009 | Image Line FL Studio 5 Producer Edition
Pairing my Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Trouble pairing my bluetooth Macally BT micro mouse
Computers & Internet Logo
Alun Cox
