Question about TOP FIN Automatic Feeder
Feeder Does Not Release Food Automatically - TOP FIN Automatic Feeder
How can I fix my broken pet feeder?
Unlikely it is worth repairing if it is out of the one year warranty, as the replacement parts (if available) could be close to the replacement cost.
Jul 10, 2014 | Petmate Le Bistro Portion-control...
Should I change my birdfeeder food between summer and winter?
In the winter months there are no insects for birds to eat, so it is more important that they have an abundance of food in the feeder. As for what kinds of food, it can be the same seeds that you offer the birds in the summer.
Dec 25, 2012 | Birds
Which dog bowl should I buy in order to keep the feeding area clean?
You should pick the elevated dog bowl for cleaner feeding area. You clean the surface of the feeder table rather than the floor. In addition, the elevated dog bowl can minimize the behavior of dogs that like to splash in their water bowls.
Sep 02, 2012 | Alessi Pets - Others
Can I buy an automatic fish food feeder?
Sure - you can buy automatic fish food feeders to dispense food while you aren't there. Depending on your budget you can buy dispensers that give out food according to electronic timers, and release different types of foods at different times.
Aug 26, 2012 | Aqueon Fish
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
I don't quite understand how to use the nuby feeder set. i bought it to introduce my daughter to solid foods. Do i just put the food in the bottle i don't know.
If your baby is under 6 months, she probably doesn't need to start solids yet. But if you want to start then, she may have trouble keeping the food in her mouth because her tongue thrusts the food forward. In that case, she may find taking pureed food or cereal easier from the 'baby food bottle' than from a spoon. Follow the guidelines that come with the feeding set. She may find it easier if you mix the baby food with formula or breast milk to make it more runny at first, but you don't want it to come through the nipple too fast, or she'll cough/choke. Once she's 6 months old, she will thrust her tongue less and should be able to transition to the spoon.
It is a good idea to introduce only one food at a time and give it a few days to make sure she doesn't have any reaction.
I hope this helps!
Mar 31, 2011 | Luv Nuby Infant Infa Feeder Feeding Set...
We were trying to locate problem wih sticking carraige when the document feeder was lifted to far and the left side hing sprung so that the cover would not close fully. Is this repairable. I am sure the...
When carriage mechanism fails it need to be repair by a technician.Most carriages systems fail due to bad internal parts,most common the belt that move the carriage.
Mar 01, 2011 | HP OfficeJet 5505 InkJet Printer
HP Laserjet 4200 with optional Envelope Feeder will not automatically pull #10 envelopes from Envelope Feeder?
Use a damp lint free cloth and clean the feeder rollers.
Print out a configuration page to make sure that the printer recognizes that the feeder is installed.
Usually the envelope feeder problems stem from age and/or dirty rollers.
Make sure that your software app sees that the feeder is attached.
Feb 08, 2011 | HP LaserJet 4200 Printer
Driver installation progam says "print head needs alignment" but doesn't say how to do it.
Canon i860
Align printhead automatically:
1) Be sure that the printer is powered on and letter size plain white paper is loaded in the sheet feeder
2) Press and hold the <Resume/Cancel> button, and release it when the Power lamp blinks four times.
The alignment pattern sheet should now be printed out. Wait for the pattern sheet to finish printing.
The printer should stop prompting you for this procedure.
Feb 27, 2010 | Canon i860 InkJet Photo Printer
WON'T SEND FAX FROM FEEDER.
u can try the following steps >
unplug the power cord from the back of the unit [without turning off the unit ] > press and hold ok and cancel key together > while holding these keys down plug in the power cord back into the unit . do not release the keys > wait for a few seconds it will make certain noises an wud turn off automatically .
turn on the printer again it will go into allignment phase > let it finish.
after its done > try to make a copy from the feeder .
Note - In case [ok and cancel key ] combination doesnot work < u can try # and 6 key combo as well with the same procedure.
THANKS
Mac
Mar 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
TOP FIN Automatic Feeder Logo
95 people viewed this question
Top TOP FIN Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a TOP FIN Fish Expert? Answer questions, earn points and help others
