Question about Michley Lil Sew Mechanical Sewing Machine
Take up lever fell off
A small screww came off then the take up level fell off
Presser foot lever fell off . How to fix it
Most likely a piece has fallen off that held the lever in place. You should probably take it to a Bernina service repair.
Apr 21, 2016 | Bernina Sewing Machines
Cannon insert needle-assembly seems jammed
the old needle broke off and is in the bar. theres a hole on the needle bar the allows u to stick a needle in and lever out the old broken needle. make sure the screw is loose. u can also rap the needle bar with a screwdrive handle to losen the needle. it should drop out, handy to have a small hemostat to grap the needle.
Apr 28, 2013 | Juki DDL-8700
Mechanism that snaps the presser foot on and off fell apart, need a diagram to show how to put the little black plastic part back on and where the black spring that fell out goes
Assuming you have all the parts, the spring goes inside the little hole in the back of the mechanism.
You then position the lever behind it, line it up with the bar that holds the lever, and put the lever pin back in.
This is very tedious, and can be frustrating. You might consider paying for a new one.
Apr 10, 2013 | Dual Sew 3400 Mechanical Sewing Machine
I have a singer inspiration 4210 and I'm trying to change the presser foot, I followed the instructions but pressing down on the screww does not snap the foot in place, I have tried using various...
I think you have to position the new presser foot under the shank then drop the presser foot lever down as if you were beginning to sew. This should snap the new presser foot right on. Be sure the little bar is positioned under the hook.
Jun 03, 2011 | Singer Inspiration 4205 Mechanical Sewing...
The thread is loaded into the bobbin however it keeps looping around the thing that the bobbin sits on.
On bobbin holder is a small screww to set the bobbin tention, must be set (tighten) if too loose it will glog up if too tight it will break the thred. wcbotha@yahoo.com
May 11, 2010 | Brother LS-2125 Mechanical Sewing Machine
You'll need a 2.5 mm hex key metric (you can buy a complete set in Radio Shack for about $10 if you don't have metric). AND you will need to cut down the shorter end of that key about half way (total remaining end will be around 8 mm), as there isn't room for the whole key in that tiny space.
Open the light bulb door, it should be easy to see where it goes but you may need two pairs of hands.
If you take it into a Bernina dealer, they should do it for free as it takes like one minute! Hey...you can ask for nothing! Those guys have all the right tools but there's no mystery, so don't listen to any nonsense.
Jan 10, 2009 | Bernina Bernette Deco 600
Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
Jan 02, 2009 | New Home Sewing Machines
How do I disassemble my Brother CS-8150 to get inside to find a nut that fell in there?
If you or someone you know is mechanically inclined, you will need to take five screws out of the back including a hard to find one under the foot raising lever (lower the foot), then one form the front that is under the thread cartridge, and you will have to remove the bobbin winding plate cover which is held by one small screw, and then remove a small screw from the support bar.
Nov 10, 2008 | Brother CS-8150 Computerized Sewing...
Viking sewing machine
Wow, that is good detail on the tube that fell out. If it is a brass colored tube that is open on both ends then you need a new crank slide. You may also notice that the take up lever can be moved up and down about a quarter to half of an inch. That sleeve can't be put back so that it will stay, and installing a new crank slide is probably something that you will want someone to show you how to do, not read from a manual.
Is the small white wheel near the drive belt? If so, it is to hold tension on the belt. Let me know and I will look in one and can tell you where to hook it.
Sep 13, 2008 | Husqvarna Viking 1
My feed dog fell down and I can't get it to stay up.
Something I read made me realize that the owner's manual assumed you were looking at the machine from the back rather than from the front. I had been moving the lever in the wrong direction.
Aug 21, 2008 | Sewing Machines
Michley Lil Sew Mechanical Sewing Machine Logo
Top Michley Sewing Machines Experts
Robin Hill
Robin Hill
R.A. Ellis
R.A. Ellis
Tom Chichester
Are you a Michley Sewing Machine Expert? Answer questions, earn points and help others
