Question about Samsung HLP5067W Television
I have a Samsung HL-P5067W/HL DLP TV. I t is slow starting. Sometimes during startup the lamp light will come on, you can hear a relay click and the TV goes to stanby then lamp light goes on again and eventually the bulb lights ,color wheel is turning and picture shows up on screen. Any ideas what the problem is. The bulb is approx. 2 years old. The set is 7 years old. Thanks for any help.
  • 149 Answers
SOURCE: No picture, new lamp
Did you reset the hours on the lamp with the menu options on your set? Sometimes, if you do not do that it can mess with the tv performance thinking that its over hours. It needs to be reset to 0 again...
Posted on Sep 24, 2007
  • 8617 Answers
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Posted on Mar 26, 2008
SOURCE: Samsung DLP won't turn on-rapid clicking sound, lamp light blinks
it was bad bulb
Posted on Mar 04, 2009
  • 1039 Answers
SOURCE: Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
Posted on May 02, 2009
  • 17 Answers
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Posted on Jul 11, 2009
I have a Samsung HL-P5067W/HL DLP tv. When I turn it on cold the lamp light blinks on and off. The fan makes a high pitch sound a relay clicks the TV goes back to standby and the lamp light starts blinking...
This sounds like a lazy lamp--that is getting hard to start. Try a new lamp first. If you are inclined to do so--get a bard bulb and install in the old lamp housing and save some money. Get a real PHILLIPS bulb--it will last a while--compared to cheap generics that are good for maybe 6 months !!
Feb 18, 2014 | Samsung HLP5067W Television
Samsung dlp slow to light up when first turned on
if your TV is slow to light up when first turned on its more then likely your bulb. When your bulb start to go bad it will take the TV longer to come on. Try using the bright feature in the menu. If that brightens your TV up then its your lamp going bad.
Thank You for using Fixya and please rate me.
Feb 07, 2011 | Samsung HL-S5087W DLP TV
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it : That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here: .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
Lights Flashing ???
Check the lamp cover to see if its properly engaging the lamp switch in the down position. You may have to short the switch out altogether. Its a known issue.
Dec 15, 2009 | Samsung HL-P5067W 50 in. HDTV Television
DLP tv broke was told to replace lamp we did still not working
Was the original lamp noticably burnt out? What is the make / model and what was the original symptoms/problem?
Sep 20, 2009 | Samsung HL-P5067W 50 in. HDTV Television
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Jun 15, 2008 | Samsung DLP HL-P5663W 56" TV
Can some one help with my startup?
Any good tv shop that services dlp displays should be able to get you a lamp. Sorry, but they are not cheap....accordianman
Oct 19, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLP5067W Television Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
