Question about Sony ICF-SW1000T AM/FM/SW Radio
Where I can find the neoprene square belt driving cassette
AIWA AD-F800 Replaced belts, old ones totally degraded. If I insert a cassette it will play but only play for 2 seconds (good audio out) but then it stops?
It is important to thoroughly degrease the pulleys before fitting the new belts and it also helps to remove some of the polished drive surfaces with some fine Scotchbrite.
It can also be the perfect time to apply a little light machine oil here and there with a precision oiler.
Finding new belts can be a problem. Most people left to their own initiative will select a belt that fits, often using the old belt as a pattern or by measuring. Unfortunately it is rare the correct size of belt will provide enough friction to drive everything successfully. As a general rule the square or round section belts of the right size must be stretched considerably in order to do the job. Even flat neoprene belts must be stretched by a large amount to fit and drive.
In the absence of knowing the correct size it is well to measure and guesstimate a suitable size smaller and then fit progressively smaller until satisfactory operation is achieved.
Apr 01, 2017 | Aiwa Audio Players & Recorders
Perhaps, my message has already sent, but I am unable to check. I purchased a set of two new belts vor my Harman Kardon TD420 tapedeck but don't know how to install them. The larger belt (square) is...
Older cassette decks used belts from the motor to the capstan, another from the motor to an idler assy. or tape reels (FF & RR) and another belt driving the mechanical tape counter.
Sep 08, 2013 | Harmon Kardon Harman Kardon Td 420
Where do i buy drive belt FOR SONY CASSETTE DECK TC-K8B
Any spares shop can make a match but otherwise this is for the round or square belts only You can fit a round belt in place of the square type it does not matter. I had some reel to reel machines and in desperation I went to a Hydraulic cylinder and pump spares shop and got an "o" ring of the correct length and thickness Remember that the new belt must be SLIGHTLY shorter to give grip on the pulleys. I have several units cassette and open reel that I was forced to fit this type and some some are running now over ten years everyday
May 02, 2013 | Audio Players & Recorders
RUBBER DRIVE BELT FOR A360 FOR TEAC CASSETTE DECK
Drive belts on tape decks are mostly universal. You only need to measure the diameter of each belt in mm and then enter the result in Google as "Cassette drive belt ??mm".
Mar 13, 2011 | Teac W-865R Single Cassette Deck
Cassette will not exit, nor play and does a clicking soud
Cassette will not exit,eject nor play and does a clicking sound, one side of cassette door will not close.
Jun 15, 2010 | Sony TC WE835S Stereo Dual Cassette Deck...
NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Dec 25, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony WE605S won't play in back direction any more
if the square belt kinda serpentines in and around a couple pulleys (or did originally) then it did not get put back on correctly. try to think of another way it could be threaded through the pulleys.
Jan 24, 2009 | Sony DECK, MECH WITH AUTO REVERSE Single...
I have a sony shelf system with combination cd and cassette - bel
Sorry, we have no belt listing for your specific model, but we do likely have what you need........
If you still have the old belt intact:
> Lay it out flat on the table
> Pinch it at both ends & straighten the belt but don't stretch it.
> Measure the length & then double it and choose or we will recommend
a size about 3-5% smaller.
Old belt too far gone to measure:
> Just use a piece of string and thread it temporarily in place of where the belt goes.
> Then measure the length of the string and Email us the exact length (inches). Along with your EXACT model number.
If your belt has a round or square cross section, please give us the thickness as well. We can assist
you in choosing a belt usually 3-5% smaller than the length you measured.
....from the turntableneedles.com site
Jan 18, 2009 | Sony CASSETTE DECK Single Dual Cassette...
Sony PMC-DR50 Shelf System - need help installing new belts
look at the front side of a motor,you will see two screws,remove it,and that's it,change your belt.
Jan 21, 2007 | Sony PMC-DR50 Shelf System
Sony ICF-SW1000T AM/FM/SW Radio Logo
44 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
