Question about KitchenAid JAVASTUDIO KCM534 14-Cup Coffee Maker
Error 4 on coffee maker - KitchenAid JAVASTUDIO KCM534 14-Cup Coffee Maker
It has error 8 on it what do u think?
Jura Capresso Impressa E8 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura Capresso Impressa E8 Espresso/Coffee Maker, error 8 related issues. Get free ... We have just done a full disassembly, cleaning, and relube of our Jura Z5 ...
Bosch Benvenuto B30 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Bosch Benvenuto B30 Espresso/Coffee Maker
Jan 14, 2016 | Coffee Makers & Espresso Machines
Our Jura coffee machine S9 model has error message Malfunction 4 appearing, have turned machine off from power swith and left off for 30 secs, still has same error message.
Hi, Printed below is the fault for Error 4:
STEAM: Temperature sensor notify “value above tolerance”
I hope this helps.
Alison, Uno Coffee Company
Feb 11, 2010 | Coffee Makers & Espresso Machines
Error 4 message, won't turn on
Error 4 is a stuck button. You try using a hairdryer on the panel and the some ice. The expansion and contraction may cause the button to unstick itself. You might be able to remove the panel and manually unstick the button.
Dec 21, 2009 | KitchenAid KCM511 Coffee Maker
Franke safira reads Malfunction 4
error/malfunction 4 usually means thermistor/sensor on steam generator block has failed ie open circuit /disconnected......................small metal encapsulated device clipped or screwed to block,2 wires to harness plug...
Feb 24, 2009 | Franke Saphira Espresso & Coffee Maker
I have Err 4 on my coffee maker... help
If “Err4” appears on the brew
timer display:
A button is jammed. Unplug the
Coffee Maker, press each button
several times, then plug the Coffee
Maker back in. (If the Coffee Maker
has been stored or used in a cool
environment, warm the unit to
normal room temperature before
doing this.) If “Err4” appears again
on the display, repeat this procedure.
• If “Err1”, “Err2”, or “Err3”
appear on the brew timer
display:
Press the On/Off Button to reset the
Coffee Maker. If the error codes
reappear, there is a problem with the
Coffee Maker electronics. Please refer
to the Warranty and Service section
beginning on the following page.
If the problem cannot be fixed with
the steps above, please refer to the
Nov 25, 2008 | KitchenAid KCM511 Coffee Maker
I have an err4 on my kitchenaid coffee pot. I have unplugged it several times and pushed each button each time but it keeps popping up with the error. It turns on every time I plug it back in before the...
Had the same problem after cleaning. ERR4 is the result of moisture in the electronics. FIRST UNPLUG COFFEE MAKER. Get a long philips screwdriver and remove the 4 screws at the bottom of the coffee maker. Pull the bottom off and carefully unclip the front panel. The circuit card is simply clipped in so it removes nicely by unclipping with your fingers. Now take a hair dryer and dry out the circuit card. Carefully plug the maker back in and verify that the LED nolonger reads ERR4. Reassemble and your back in business!
Sep 07, 2008 | KitchenAid KCM511 Coffee Maker
Error 2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If the code does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Jul 26, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
Kitchenaid 14 cup programable kcm534er has an error code 4 what do i do
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in place. Please be sure to check all of your buttons and see if any are stuck depressed into the machine.
If this is not the case, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Jul 04, 2008 | KitchenAid Pro Line Coffeemaker Coffee...
Coffee pot
ERR 4 simply indicates that the computer is recognizing a stuck button (a button have been depressed for more than 10 seconds time). Please double check to make sure that no buttons are still depressed into the machine.
May 27, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
KitchenAid JAVASTUDIO KCM534 14-Cup Coffee Maker Logo
15 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
graybeard32301
Ismael Rodriguez...
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
