Kenmore 4174452400 will not spin the light is lite up
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Mar 22, 2010 | Kenmore 43142 Front Load Washer
It started out not spinning. The lights would
kenmore portable washer will fill with water when button pulled out it just hums and occasionally tries to start.
Jan 30, 2010 | Kenmore 2.1 cu. ft. Portable Top Load...
Light socket burning out
Due to not screwing bulbs in tight enough , and/or too high wattage lite bulbs ( 40 watt recommended ) .
Jul 31, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Washer won't spin with a heavy load
motor controller likely bad - but check the lid switch first.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore Washing Machines
Kenmore 46462 powers off during spin cycle - no lights
i cleaned out the pump under the front bottom panel
Feb 03, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
