Question about Fujitsu lifebook t tablet t731
I have a t731 and have never used the webcam until today and it displays it upside down????
Tagital tablet 10.1 screen backwards and upside down how to factory reset
power off the tablet
then press power and volome down simultaneously
until you see the reset menu select reset with up down keys
acknowledge with power to reset
Sep 16, 2016 | Tagital Tablets & eReaders
How do i unfreeze my tablet
Hold down power button until shuts off. If freezing continues then has a virus. Go to app store and download avast and do a full system scan. If can't do that then do a factory reset. Back up everything on computer first. Hold down home button, power button and volume down at the same time when powered off. After boot screen release only the power button. When a screen loads use volume keys to navigate to factory restore and press power button then wait till done. If volume down doesn't work then use volume up instead.
Jul 24, 2014 | Visual Land ME-107-8GB-WHT Tablet Computer...
Webcam effects oovoo
In settings detect your cam.
May 02, 2014 | Irulu Tablets & eReaders
My nextbook display is upside down,,,the power button and camra is at the bottom
If the auto rotate system is on it will switch the controls so try restarting it and then if it still does that go the the programs settings and see if u can fix it.
Jan 20, 2014 | Nextbook NEXT2 Touch Screen Android Tablet
Screen display upside down
I think you should go to the settings and make sure rotate is not turned off. Also, try to calibrate your screen again.
Jan 20, 2014 | Nextbook Tablets & eReaders
Kindle 2 screen upside down
The orientation might be upside down. press the 'Aa' button (to the right of the spacebar). Choose your desired screen orientation.
Feb 12, 2012 | Amazon Kindle 2
My laptop screen is flipped upside down and i need to know how to reset my laptop!
No reset is necessary to fix this problem. Screen rotation is a typical feature on many laptops.
To rotate the display on the screen 180 degrees, simply press CTRL, ALT & down arrow on your laptop's keyboard.
Jun 14, 2011 | ASUS R1E-B1 Tablet PC
I have a Android 2.1 Tablet PC X220 flytouch2 with GPS and Webcam and for some reason the power saver display option is basically turning off the screen instead of dimming it. so my problem is i can not...
Have you tried plugging it into the charger? If it's plugged in, the screen should dim but not turn completely off for at least 10 seconds. If it doesn't work, try covering the light sensor on the front of the tablet, so that the screen will brighten until you can change the backlight setting in Menu -> Settings -> Display.
Apr 30, 2011 | Coco 10"2 Touch Screen Android 2.1 Tablet...
Rotate windows on a toughbook
Is it just that the window is upside down??
1. Try pressing Ctrl + Alt + arrow (left, right, up or down) to rotate the screen.
2.Press the hotkeys and arrow keys until you have the desired rotation. This works with most video drivers on Windows XP. If this doesn't work let us know.
Dec 09, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Fujitsu lifebook t tablet t731 Logo
23 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Michael Vincent Cruz
Tony
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
