Question about Polaroid iF045 Waterproof Digital Camera - Blue
Camara will not connect to computer with usb - Polaroid iF045 Waterproof Digital Camera - Blue
I connect the usb into the computer but the camara isnt charging
USB is to download pictures and not to charge batteries - read manual
Jul 03, 2012 | Disney Pix Micro Digital Camera
Trying to copy photos to a folder using Microsoft Scanner & Camera Wizard. Camara is on and is connected to my PC with a USB cable, but the computer can not detect the camara.
First, check both ends of the USB cable to be sure that the ports and the plugs are properly seated so that the metal pins are able to transfer data. Restart Windows with the cables plugged in, and the camera should be recognized. You also MUST have the camera turned ON in order for the computer to read the fact that it is connected. If these suggestions fail, check your Microsoft Computer Management program to be sure that PlugnPlay devices are automatically recognized by your system.
Have fun with your photography!
Sciencewoman
Mar 31, 2011 | Samsung SL202 Digital Camera
How i can connect my nikon coolpix s4000 digital camara to my PC
First install the software of the camera to your computer it should be on the CD that came with the camera, then connect the camera via data cable USB and make sure the camera connectivity setting is USB connection. After that open the software and you should be able to see all the data inside the camera's memory and transfer it to your computer.
Sep 07, 2010 | Nikon Cameras
How do I use camara card to up load photos from camara to pc
Plug the card into a card reader (either built-in to the computer or connected via USB or FireWire). The card will then appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, or you can use any of a variety of photo cataloging programs.
Jun 10, 2010 | Kodak Cameras
How do i connect to computer
Check the camara out. If it has a usb or mini usb, then you can connect it to the computer. If not, then I guess you can't.
May 09, 2009 | Canon ES8600 Camcorder
Not showing up on computer that its plugged in
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 17, 2009 | Kodak EasyShare V1003 Digital Camera
DCR-HC32E
You need a FireWire cable and a computer with FireWire port. I have same camara - it comes with a base unit into which you have to plug in the camara. From that base unit connect the firewire cable (4pin) and take that to your computer which may have a firewire port (either 6pin or 4 pin) - depending on what kind of firewire port you have on the computer, you have to get appropriate cable ... it is my understanding that the camara doesn't come with this cable. I purchased a firewire cable with 4 pin connecter on both ends to connect to my IBM laptop with Vista on it. It works great after all this setups. It does not work with a USB cable for some reason.
Jul 13, 2008 | Sony DCR-HC32E DV Digital Camcorder
Usb pc camera problem
Install your Usb pc camera under "administrator" user account means that all privileges should be i you so that you can install any driver and software to your pc. may this helpful to you.
In installing disconnect the pc cam to the computer and install the driver. after installing the correct driver connect back the pc camera. the computer will install it for you.
Dec 17, 2007 | Radio Shack VGA PC Camera Webcam
Polaroid iF045 Waterproof Digital Camera - Blue Logo
48 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
