3000. is what percent of 24000. - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
3000 is 12.5% of 24000.
Posted on Sep 14, 2014
Isuzu rlt engine idles ok cold but rough when it warms up and stops
Hi,it might be you maff sensor,you can check this by waiting for the car to warm up when it starts to run bad stop engine take the plug connector of the maff sensor,if when you do this the car runs better (it wont run like it dos e when the maff sensor is working properly,but will run,)then replace the maff sensor.
please dont drive the car with the maff sensor off for a long time as this will also couse damidge.
hope this was some help.
Apr 30, 2015 | Isuzu Cars & Trucks
Ge 24000 throws beaker not breaker on unit cord
bad breaker or exceeding its amp rating. a 2 ton window units pull alot of amps on start up.
Aug 13, 2014 | GE 24000 Btu Room Air Conditioner EnerStar...
Fit my Acer Aspire 3000 ?
akku Acer Aspire 3000 100 percent compatible with you Compaq Presario CQ61. I bought two Acer Aspire 3000 batteries from http://www.pcakkus.com/acer-aspire-3000.html two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Nov 30, 2012 | Computers & Internet
The car gives you the oil life percentage but at what percent do they recommend you change the oil?
Most vehicles do not speak to percentage but to driven miles In your owners manual there is a page that has the manufacturer's recommended oil change schedule, and those pages generally say 2000-3000 miles on the first change, then 7500 there after. The percentage usage is a reminder that you are getting near the 2000-3000 mark, but this can be reset by a push of a button.
Jan 24, 2011 | 2011 Chevrolet Malibu
What is the recomnded service for a 2003 dode ram 1500 with a 4.9 engine
oil change every 3000 miles check all fluid levels at 24000 miles change trans.fluid and filter,fuel filter,air filter. at 30000 miles pack front wheel bearings service cooling system,replace spark plugs,inspect wires and pvc valve. lubricate the chassis every 6000 miles. hope this will help!!!
Apr 05, 2010 | 2004 Dodge Ram 1500
When i try to boot my laptop the percent hits 90 and freezes
boot into safe mode, (repeatedly press F8 at power on)
Then try a regular boot.
if that doesn;t clear the stuck driver, then you may need to look at the system restore option
in safe mode, you can reset the computer back to the last few days.
look in accessories\system tools\system restore
Jan 05, 2010 | Acer Aspire 3000 Notebook
Hdd problem
the normal thing it will be to read minus 5 percent from it ...I mean 160 ....to see 150 just about ..the rest it is use for system requierments..and stuff , so ..if you are running like this ..it means that you format it like this ..or you left a part of the memory unformated......or ...there is another possibility if it has any jumpers settings on it ...like at the old ide hdd it might be limmitated from there ..or maibe has other limmitations .
there is possible to be setted to use a percent from each partition for different porpouses ..like system restore ..or else...and it will not show all in the partition propieties..
anyway ...its not a reading problem
Mar 24, 2009 | Acer Aspire 3000 Notebook
Tcp port 24000-24100
Hi Sorry to hear you are having problems,
MacOS 10.4 has a firewall built into it ( Of course all MacOS X versions have firewalls ) that can have ports opened on it. You say it was working fine yesterday, did you change anything ?
Fastest and easiest way to open ALL TCP/IP ports is to turn off your FireWall for the time you are playing then re-activate it when you're done.
This can be done in the sharing pane of the System preferences, choose firewall and turn it OFF.
You could of course open just the ports 24000-24100 in the same preference pane...
But chances are it might be something else if you did not modify your system since yesterday.
Are you on the same network as yesterday? Are you able to play on another network ?
Mar 01, 2009 | Apple Mac OS X 10.4 Tiger for Mac
Open ports 24000-24100 on Mac OS X v.10.4.11
System Preferences --> Network --> Sharing --> FireWall --> New --> Port name = Select "Other" and call it (for example) scrabulous --> Add the port numbers 24000-24100 in TCP and UDP ..
Dec 23, 2007 | Apple Mac OS X 10.4 Tiger for Mac
20 people viewed this question
jasbo
jasbo
