Question about ASUS G73JW-XA1 17.3-Inch Gaming Laptop - Black (Republic of Gamers) PC Notebook
Asus g73jw black screen on boot up
Cant access safe mode or bios(attempting to do so shuts down computer), lights still work and fan goes full blast after 5-10 second delay. previously had kernel state based blue screens. on last boot up before issue, computer hardlocked on desktop with only bootup programs running.
    Top Expert:
  • ASUS Master
  • 26,637 Answers
That sounds like the GPU is cooked. The CPU is heating up trying to drive the GPU that is not responding.
Posted on Feb 13, 2014
  • 33 Answers
SOURCE: The bios update failed on my 4g asus eeepc
What you need to do is to get the manual for the motherboard os you can reset the BIOS. On the other hand, you may not be able to preform that. This model is like a netbook and try this, remove the battery and the power cord. give it 15min. put the battery back in and reboot the system and than the power cord. that should help. if not, than a tech person is your next step.
Posted on Jul 17, 2009
JulesPCaut
  • 702 Answers
SOURCE: AMD Puma-based Asus M51Ta stalls at power up, screen is blank.
Have you tried booting and pressing F2 to get in the bios?
If that works you can check the boot devices and order of usage. Make sure the HDD is first.
Apart from that you can reboot and press F8 to get in the Windows boot menu, where you can try the Safe Mode.
If all this fails, the Windows configuration is somehow corrupt. You can try booting from a Windows CD and run the Repair option in the setup.
Posted on Oct 20, 2009
dwane4444
  • 219 Answers
SOURCE: my asus Eee pc 900hd will not start up it goes to
Try starting with "last configuration that worked"
Posted on Oct 30, 2009
parrotheadpc
  • 2600 Answers
SOURCE: black screen folowing options. safe mode etc. asus Eee pc 904hd
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Jan 18, 2010
madhatter639
  • 260 Answers
SOURCE: I have Asus Eee pc 901 installed with Windows xp
It sounds like you may have 2 problems. 1) as you've state you have a virus; this being the case I suggest reinstalling your operating system. 2) if it's blue screening at BIOS then you most likely have an issue with your memory\RAM. The virus shouldn't be causing it to blue screen while in the BIOS; although it's not unheard of. When you reinstall Windows you will lose everything. You can restore; if you have a recovery partition, by tapping F8 while booting up. It should go to a black screen with white text. If you see Utilities or Recovery, then select that and press enter. If you don't have a recovery partition then you will have to use a recovery disc to reinstall. If you don't have a disc or a CD\DVD ROM then you will be better off taking it to a repair shop where they should have what is needed to reinstall your operating system.
Posted on Mar 13, 2010
Testimonial: "great advice"
My asus PC1005HA will not re boot after I upgraded BIOS
closed the unit down
now press the start button and hold down the delete button to get it to start in bios
check the boot sequence there
adjust as required and save
Aug 17, 2017 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My screen goes blank after all disk top come up can you help i have a travelmat 2300 acer lap top
Looks like an issue with either display or system is overheating. Please try the below steps.
1. Shut down the computer
2. Keep on tapping F8 key as us press the Power button to turn on the computer.
3. Choose safe mode using the arrow keys on the keyboard and hit Enter Key
4. Stay on the safe mode to see if the screen is going blank, if not
5. A system restore should help to fix the issue. Let me know!
Thanks!
Anil.B.R
Oct 02, 2013 | Acer TravelMate Computers & Internet
Bios locked on start screen. admin password needed
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select safe mode with command prompt Then type at the C:\> prompt: type
DEBUG
and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type:
o 71 ff
and hit Enter. Finally type:
Quit
and hit Enter one last time to quit DEBUG back to the C:\> prompt.
Now you're ready to reboot your PC, and press the appropriate key or key
combo (look it up in your motherboard manual if you don't know it) to access
your BIOS Setup. Youll notice the password is gone. If this fails try typing At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of ten
If this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password http://www.tech-faq.com/reset-bios-password.html At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410 http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. Hope this helps.
Dec 29, 2012 | ASUS X401a 14.1-Inch Laptop Black Intel...
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
My samsung n145 plus netbook was shut down during windows updates. Now when it's powered up all I get is the blue light to indicate this and nothing on the screen. It just stays black.
If it was shut down whilst in the middle of installing updates then you might have a corrupt start up file . Try to boot into safe mode --tap the f8 key while your computer is booting then on the menu select safe mode or safe mode with networking . If you can boot here go into administrator account and try to to do a windows restore .if successful you can then re-download the windows up-date and install it properly.. If you cant access safe mode then you might have to repair the boot records which is too technical to explain in detail here .
I hope this helps
Andrew .A
Apr 12, 2011 | Samsung Computers & Internet
Asus aspire laptop has black screen w 2 windows 1 has @ top says administrator:cmd.exe the other says safe mode in all corners how can i fix this
Your computer has booted into Safe Mode. A simple restart should fix and boot it back to normal. If it boots back into Safe Mode, Shut it down, then turn it back on while holding the Escape key. On the screen that comes up use the arrow keys to select Normal Startup, and press Enter.
Mar 23, 2011 | ASUS Computers & Internet
Dell Inspiron 1545. When booting to vista the screen goes black. When booting to safe mode the screen works normally.
Please reinstall the Video Driver and check if the same issue persists. If the issue started within last 90 days, you can try the System Restore
Jul 01, 2010 | Computers & Internet
Goes On ..Then Goes Black Screen I have 2 GX280s. One failed the other day after 2 years use. The BIOS screen appeared then it all went black. About every 10th attempt to get it going, it works and boots...
have you tried booting in safe mode? When it starts press F8 and select "Safe Mode" or "Last Known Good Configuration.". On that 10th try you do get it to come up make sure you install all updates for your computer. Then you can put int he Optiplex disk from Dell and run some diagnostics.
May 28, 2009 | Dell OptiPlex GX280 PC Desktop
Can't get pass the background screen when pc load
The sequence is:
a) The Dell bios splash screen is displayed,
b) the screen will go black,
c) the disk activity light will flash for about 5 - 7 seconds, then will remain off.
d) you force a power off,
e) wait a few seconds,
f) then turn the machine back on.
g) The bios splash screen is displayed,
h) then a black screen with white text is displayed, reporting that Windows was not shut down nicely and would I like to boot into safe mode or safe mode with networking, or others.
g1) If you choose Safe Mode, Windows will boot up successfully. If I restart, the computer will usually (probably) boot into Windows fine.
g2) If you choose Boot Normally, the computer will usually (probably) enter the black and hung state.
see if that helps and the if possible do a do a system restore to when the system was working correctly.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
ASUS G73JW-XA1 17.3-Inch Gaming Laptop - Black (Republic of Gamers) PC Notebook Logo
128 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
