Question about CrimeStopper SP300
Cut antenna wires
I reconnected the wires but the alarm wont respond now
Wires has been cut under dash of a 1997 ford escort need help rewiring so car will run
HOW CAN THE WIRE BEEN CUT,
DO YOU HAVE TILT WHEEL, REMOVE STEERING COVER OD THE IGNITION STEERING AREA, LOOK AT THE WIRES, DO THEY LOOK LIKE SOME ONE CUT THEM OR THEY CHANGE COLORS DO TO A ALARM SYSTEM, IF THEY CHANGE COLOR, COULD BE THE AFTER MARKET ALARM RELAY THAT WONT ALLOWED YOU TO START, IF YOU DO NOT KNOW WERE IT IS, IS OK, OPEN THE CONNECTION AND REMOVE THE WIRE COMING FROM ALARM TO IGNITION SWITCH WIRE, FIND THE OTHER END OF THE IGNITION WIRE THAT WAS CUT OUT , SEPARATE FROM THE OTHER WIRE ALSO FROM THE ALARM, AND RECONNECT BOTH IDENTICAL COLOR WIRE TOGETHER AND IT WELL START, UNLESS YOU HAVE A SECURITY LIGHT ON THE DASH, CHECK THIS OUT FIRST., PROGRAMING MAY BE NEED IT OR OTHER PROBLEMS ARE THERE.
May 24, 2014 | Cars & Trucks
There is a non-factory anti-theft device keeping my truck from starting. How do i remove it
I would before you do that call a few places that install after market alarms---cutting may not solve the issue and could just make things worse--see if you can locate the unit (brand on the remote??) for a brand or model number.
Cutting without knowing may be foolish.
Dec 05, 2012 | 1997 Ford Expedition
Hi, I have a 1995 Toyota 4runner... That said, I'm
Well if they were able to cut this wire, I am assuming they were able to get into the car? But if your dad can open the hood and take the negative wire cable off of the battery then he can bridge the wire that was cut, hopefully.
He will need a small wire clamp kit that they can get at an AutoZone or Atuo Parts store. After he fixes the wire that was cut, he will need to disconnect the positive wire cable from the battery and then reconnect both of them. that should keep the alarm from going back off, however it may reset the system. Either way if he has the spare remote they should be back in business and can get your care moved and the alarm to work again.
Good Luck!
May 29, 2012 | 1995 Toyota 4Runner
02 courier immobiliser wont let van start what will i do can i bypass this
Apparently, this is the type of bypass where you have to cut a wire at the immobilizer plug at the ignition switch, usually the PATS ignition wire. If the immobilizer is malfunctioning and you cannot start your vehicle, even with the key, You will have to remove the steering column shroud and /or dash and reconnect the wire that was cut.
Jan 25, 2011 | Code-Alarm Code Alarm Transponder
I cut the wires leading to the antenna and i lost my power locks power windows alarm and radio pre sets wha do i need 2 do
check your fuses, you must have blown one or more!!never cut wires while your battery is connected and never reconnect your battery while wires are cut and exposed!!
Sep 27, 2010 | 1995 Nissan Maxima
I'm trying to remove my 02 lancer ls car alarm. I've removed the box and all the wires that was connected to the box but my car still will not start. I've even replaced the starter and it still won't...
The alarm had a wire to not let the car turnover/crank, is that what you mean, or the car turnsover/cranks, but wont run. If it wont turnover, usually its a larger wire that was cut and the alarm wired in, you will need to get this wire reconnected again. I dont have a diagram here to tell you the wire color, but usually its a 10-12 gauge wire. So if you have a 2 wires the same color, and its cut, connect them back again.
Sep 05, 2010 | Mitsubishi Lancer Cars & Trucks
Car wont start after both alarms were removed
Try to remove the After Market alarm only. The other might be the FACTORY alarm. Might want to leave the factory one in the vehicle.
Mar 17, 2010 | 1997 Honda Civic
Alarm has been disconnected then after reconnection without alarm kill switch is turning bike over which seems to bypass start switch
Check starter wire from handle bar back,you have cut wire during install and reconnected to a hot at all time wire
Jul 16, 2009 | 1997 Yamaha YZF 600 R thunder cat
I have a viper 5900 car alarm installed with remote start.
Look under dash for a small black box with wires coming out of it, about 2 or 3 inches rectangular.. there should be one or two screws on it. Look to see if it says which direction to turn for sensitivity. As far as not receiving, you need a new antenna, this is covered under warranty through DEI either bring back to where you purchased or look online and see where the closest dealer is to you...
Jan 28, 2009 | 5900 SST 2-Way Security System / Remote...
I cant cut off my alarm and car wont start
is ti and aftermarket or factory system, if aftermarket look for little black button under dash or button on antenna, turn key on and press for one full second, if aftermarket unlock door with either trunk or passenger side and try again...
Jan 25, 2009 | Vehicle Parts & Accessories
CrimeStopper SP300 Logo
18 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Frank Mangiapane
Level 1 Expert
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
