Question about Canon PIXMA MP510 All-In-One InkJet Printer
Cannot scan pdf - Canon PIXMA MP510 All-In-One InkJet Printer
  • Michael Grey
    Michael Grey Feb 13, 2014
    Hi quan duong, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    What software program?
How do I scan multiple documents and email them as one attachment
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
Aug 07, 2013 | Canon MP Navigator EX for Windows
Canon MX860 won't scan to a pdf
Scan and create PDF documentYou need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
From your computer SCAN your document then click on File - Print and select thePDF writer as the printer device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click onthis link :-http://www.cutepdf.com/
May 18, 2012 | Canon Office Equipment & Supplies
I have Mustek 1248US. Can it scan to PDF?
Scan to PDF is controlled by your software. What OS and software are you running? Under Windows, Nuance's PaperPort, http://www.nuance.com (or OmniPage which includes PaperPort) or Abby Fine Reader Express, http://www.Abby.com , both will let you scan to PDF. Open the software and set the options for scanning to PDF. Then press the scan button in the software. (Depending on the OS and Mustek driver, you may get this to work by pressing the Scan button on the scanner itself. This depends on installing a monitoring program that may be included in the drivers. This "listens" for the button press and then launches the desired software.) Other third-party software may also do this.
If you are using something like Windows Fax and Scan, you'll have to do two steps. Scan and then convert the file from an image to PDF. (There are dedicated programs that convert image files to PDF or you can do this is Microsoft Office or other office suites with the appropriate add-on.)
I hope this helps.
(I have an older scanner with Windows 7; I can only scan to PDF with third-party software.)
Mar 14, 2012 | Mustek Scan Express 1248UB Flatbed Scanner
I can"t scan to PDF
Hi
Use the Scan to PDF software to direct convert your scan page to PDF, download the software to click hear
and simple to install to this software, after installing you get the shortcut in your desktop double click that one and open your scaner is automatic install there put the document in scanner and click scan after scanning click save to PDF and give the save file name and save.
Nice one may it is resolve you problem.
Cheer
Jun 23, 2011 | HP Scanjet G2710 Flatbed Scanner
How do you setup your scanned documents to show up on my desktop as a pdf file?
  1. You can use A-PDF Image to PDF (free download here) to scan a document into PDF format and email it with only 2 steps:
    Click the "Scan paper" icon to scan documents from scanner
    Click the "Build to One PDF And Mail" icon to create a PDF document contains all of the scanne
    d documents and email them.
Jun 20, 2010 | Office Equipment & Supplies
Scanning document in PDF format
To scan in PDF, you must have a PDF scanner please download and install a program like scantoPDF or others that you can use, like, NitroPDF, or Adode Professional, Either that or you can simply convert the JPG, to a PDF, with a printer, a virtual printer that "Prints" PDF, as PDF is a printing format, and it is done in software. So there is Print2PDF, PDFPro, and many others that will scan and print also you can get a PDF plugin for MS WORD as well.
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=scan+to+PDF
above is your link for scan to PDF & Below is the Print to PDF.
http://www.google.co.nz/search?num=100&hl=en&q=print+PDF&aq=f&aqi=g-c1g1g-c8&aql=&oq=&gs_rfai=
May 24, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Symantec scan engine able to scan pdf malicious scripts?
Scanning a malicious PDF can be done with Symantec.
See http://support.symantec.com and search for Malicious PDF...
there is a support document for this.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Jan 19, 2010 | Symantec AntiVirus Scan Engine
How do you scan to PDF on a Konica Minolta Bizhub 353?
Touch [Fax/Scan] to display the initial screen for fax/scan operations.
Touch [Scan Settings] to specify detailed settings for scanning
In Scan Settings >File Type , select elect the file type for saving the scan data. The following file types are available (PDF,Compact PDF, TIFF, JPEG, XPS, Compact XPS).
Touch [PDF] or [Compact PDF]
In addition, the grouping of the saved data (single PDF or multi-page PDF) and the encryption settings (encryption level, password, document permissions, and other detail settings) can be specified.
You should check the user’s manual for images and more detailed info on how to operate the machine.
You can download it from here:
http://download6.konicaminolta.eu/konmin/servlet/KonMinMaster;jsessionid=9D04D81DD26189D21B3B2B8B32D2B06F.node02?path=../search.jsp&mode=show&document=32545
Jul 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
15 people viewed this question
old marine
old marine
