Question about Konica Minolta Bizhub 222 Black and White Copier
Change pc drum - Konica Minolta Bizhub 222 Black and White Copier
  • Konica Minolta Master
  • 6,696 Answers
Will require a tech as certain counters are replaced as is the developer and certain procedures are done after the image unit is re assembled.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 18, 2016
Change pc drum konica minolta di3010f
the drum, cleaning blade and developer are all replaced at the same time, no but you can damage the drum and or sensor
Nov 20, 2013 | Konica Minolta Di3010 Di3010f Drum Unit...
Change pc drum
Press bediener - details - stop 00 - stop 01 - enter 00000000 then touch end. Go to Counter- Counter Reset (higlight the six box) - function - f8 - press the start key (wait) go back to counter - pm - highlight ic life or pc life - press cancel button.
Hope it can help you.
May 29, 2013 | Minolta bizhub 350 Black and White Copier
I have a message, please change the pc drum. how i can fix it?
This message means the pc drum life is over. You should call service center to replace the drum and reset the message (if you are not a technician).
Oct 05, 2011 | Konica Minolta Bizhub 362 Copier
On my bizhub 250 copier, there is a message stating " Please change PC Drum" My question is, How do I change PC Drum?
This is a service technician performed function. The PC Drum unit is changed by removing the whole imaging unit and then removing the drum section and changing it out. At the same time the developer needs to be cleaned from the developing unit and replaced with fresh developer. The drum counter is then reset using the service mode and then the new developer must be calibrated using the F8 mode. So in this machine's case, this is just not a pull out the old unit and plug in a new one.
If you find the "right" service guy, he can come in and reset the drum counter and do the f8 without changing either the drum or the developer. This can sometimes get twice the life out of the unit. Copy quality can degrade a bit towards the end of the second cycle.
If you just reset it your looking at around $100. If you do everything that is called for then the cost is more like $350.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 20, 2011 | Minolta bizhub 250 Black and White Copier
How do I change drum sounds (programs in Drum module) from Sonor?
I like CSI--at least the original. Have you tried going to the "change" function and changing the sound? That's all I can think of.
Apr 26, 2010 | Cakewalk Studio Instruments ( Windows...
Dirty print - dark streaks across top of document
Check the PC drum,if dirty clean.Has toner spilled from the I/C inside of the copier?Clean.Is the PC drum charge voltage terminal in good condition?Check and change if necesary.Is the grid voltage terminal in good condition?Check or change if necessary.Are the fusing rollers dirty with foreign matter?Clean or change.Clean the mirrors,lens and original glass.
Aug 06, 2009 | Canon imageRUNNER 2200
In minolta bizhub 350 pc drum change
Two Options:
1) Reset the PC/life; I/C Life and DV counter and run F8.
2) The same than before but change the PC drum.
by : George Rivas ( OSI )
Feb 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
"Please change PC Drum" message appear on printers LCD
If your print job prints ok, ignore it. Just bear in mind you'll need a new drum soon. The drum is a light sensative roller that ink from the toner cartridge adheres to where the laser hits it. When it is no longer magnatized enough to hold the toner you'll see your print jobs start to lose that toner color. Just pull the drum out, buy a new one and put it in. Just don't expose the drum to light very long.
Oct 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Hello, Our Minolta Dialta Colour Copier/Printer CF 2002 has come up with a "C-0208" malfunction right after the maintenance contract expired... Can anyone help, please?
C0208: PC Drum Charge Corona malfunction. The SCD signal is detected for a continuous 0.7-sec. period while the PC Drum Charge Corona is being energized.
Relevant Electrical Parts - Image Units C/M/Y/Bk, High Voltage Unit (PC Drum CH.) HV1 IO Board (PWB-IO)
Steps (in this order) - Check the Image unit contacts and correct
or clean as necessary.
Check the HV1 contacts and
correct or clean as necessary
Change Image Unit.
Change HV1.
Change PWB-IO
Aug 13, 2008 | Minolta Office Equipment & Supplies
Develop ineo 161
open then close the front door -> the display show " CHANGE DRUM ? YES/NO " -> press yes on the board
Mar 13, 2008 | Konica Minolta Di1610 Copier
Konica Minolta Bizhub 222 Black and White Copier Logo
53 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
