Question about Sony KP-41T65 41" Rear Projection Television
Sony TV KP-61HS30 all of a suddon the picture went black volume ok
SOURCE:
easyab
  • 132 Answers
SOURCE: KP-61HS30 Sony TV turn pink and green text is bowed
Check out CONVERGENCE GALLERY . If you see your symptoms you have a problem in your convergence amplifier circuits. Typical Sony Convergence repair requires disassembly for replacement of 2 ICs, sometimes a fuse or 2, then TV is like new.
It is much more complicated than changing batteries on your remote. Many consumers try unsuccessfully to do a convergence repair. I recommend finding someone competent to do it for a reasonable price. Typical repair shop charges may be from $400 to $650.
If you are in the Calgary area, call me. More reasonable rates.
easyab
Posted on Oct 15, 2008
electronick
  • 505 Answers
SOURCE: Sony KP-61HS30 green problem....
Unfortinately its likely a bad green CRT. If it stablizes over time, then no adjustment will help you. CRTs are expensive so its best to turn it on 30 minutes before you need it.
Posted on Dec 07, 2008
  • 3 Answers
SOURCE: sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Posted on Jun 22, 2009
  • 178 Answers
SOURCE: I have a KP-61HS30 and the picture is blurry or
This is the stk392-??? ic's are bad. the repair can cost about $250 to 300 to fix by a pro. If you are a diy er you can replace the ic's on the board i have written an article on how to do this.
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Posted on Sep 02, 2009
SOURCE: SONY KP 43T75 TV PICTURE WORKS SOUND IS ON FULL
the remote control buttons were stuck
Posted on Oct 09, 2009
Is the sony KP-61hs30 a HD television?
Hi, Although it is a rear projection TV it will work with HD content.
You will still need a set top box to decode HD programs. This is an old TV with tubes inside and a CRT screen. They will fail and it's getting harder to get parts for. My advice go get a flat pannel TV.
Good luck
Feb 04, 2016 | Sony KP-61HS30 TV
Kp 61HS30 TV Had the tv since 2002. been a great tv. Just recently it started making a noise when you turn it on. Noise fades away after about 10 seconds. Noise kind of sounds like a dvd player trying...
If you locate the audio board, check for dried up electrolytic capacitors and dry joints around the output IC itself.
That should fix your fault.
Nov 27, 2010 | Sony KP-61HS30 TV
My Sony kp-61hs30 has no power. no blinking
Check fuses on power/delection board. Besides normal looking fuses there are micro fuses that are small and are yellow or blue in colour
Jan 07, 2010 | Sony KP-61HS30 TV
I have a KP-61HS30 and the picture is blurry or double
Sep 02, 2009 | Sony KP-41T65 41" Rear Projection...
Will not power on, red light flashing six times
the problem is in the power supply most likely. The overvoltage protect circuit is causing you not to be able to turn the tv on. This is common to all tv's. Solution unfortuantely is get another tv unless you know someone who can either work on or replace the internal power supply
Jul 01, 2009 | Sony KP-61HS30 TV
My TV will start to turn it self on and off rapidly
http://www.nodevice.com/manual/sonymans/manual3447pdf/get4963.html
online pdf manual
Please rate my help++++Thanks for using FIXYA
Apr 11, 2009 | Sony KP-61HS30 TV
SONY KP-61HS30
Sounds like it needs convergence chips. This repair requires test equip. and soldering/desoldering tools. Most repair shops charge between 200.00 and 400.00 to do this repair on your model of tv. Hope I have been some help
Mar 03, 2008 | Sony KP-61HS30 TV
Problem
Hi three months ago my kp-61hs30 tv looks like 3d picture and technician man replaced the two convergence Ic's but last night my tv looks like 3d picture and it look like is the picture goes down
i don't know why happened again
Oct 30, 2007 | Sony KP-61HS30 TV
Sony tv kp-61hs30
Sounds like a convergence problem. Common in this set.
SONY KP-61HS30
When one or all the colors are bending severly, then the convergence circuit is not functioning correctly and must be repaired. Only one color bending means just the convergence ICs and all colors bending means convergence ICs and voltage supplies. Convergence issues are the most common problem with rear projection (w/picture tubes) televisions. The cure is replacing the convergence IC's. Sometimes the pico fuses need replaced as well. If you have the experience to use a soldering iron and a basic understanding of electronics, then, you may be able to do this job. If not then call a servicer in your area. Go to the Sony website, Sony.com, and you can locate one in your area.
Jan 07, 2007 | Sony KP-61HS30 TV
Sony KP-41T65 41" Rear Projection Television Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
