Question about Sony KP-51HW40 51" Rear Projection Television
Sony TV KP-61HS30 no picture volume ok - Sony KP-51HW40 51" Rear Projection Television
techman
  • 3130 Answers
SOURCE: Ghost PIcture
Uniontrip, im afraid you have a problem some other 3 illion other rear tube projection set owners face or will face in the near future. Its called a convergence problem. You see there are Two IC's inside this set that correct the alighnment of the three picture tube alighnment to each other to get a steady straight picture. To fix this problem, both IC's should be replaced together as a whole, even if its only one IC bad now, you can bet your bottom dollar, down the road, the other will go bad as well. If you have any solid state repair experience and know how to unsolder and solder printed circuit boards, this is not really a difficult job to do, as they are two black IC's standing up against a metal heatsink and the lettering on them will start with STK###-###, the # being other numbers. Now since these are solid state sets and they really have noi USER replaceable parts inside them, it is always best for the non experienced to refer to a trained repair technician to do this sort of repair. Most of the time, a repair such as this, should not exceed a couple to a few hundred bucks. Good luck. Please do not forget to rate this thread.
Posted on Oct 16, 2006
  • 192 Answers
SOURCE: SONY KP-61HS30
When one or all the colors are bending severly, then the convergence circuit is not functioning correctly and must be repaired. Only one color bending means just the convergence ICs and all colors bending means convergence ICs and voltage supplies. Convergence issues are the most common problem with rear projection (w/picture tubes) televisions. The cure is replacing the convergence IC's. Sometimes the pico fuses need replaced as well. If you have the experience to use a soldering iron and a basic understanding of electronics, then, you may be able to do this job. If not then call a servicer in your area. Go to the Sony website, Sony.com, and you can locate one in your area.
Posted on Jan 07, 2007
easyab
  • 132 Answers
SOURCE: KP-61HS30 Sony TV turn pink and green text is bowed
Check out CONVERGENCE GALLERY . If you see your symptoms you have a problem in your convergence amplifier circuits. Typical Sony Convergence repair requires disassembly for replacement of 2 ICs, sometimes a fuse or 2, then TV is like new.
It is much more complicated than changing batteries on your remote. Many consumers try unsuccessfully to do a convergence repair. I recommend finding someone competent to do it for a reasonable price. Typical repair shop charges may be from $400 to $650.
If you are in the Calgary area, call me. More reasonable rates.
easyab
Posted on Oct 15, 2008
  • 135 Answers
SOURCE: sony tv kp-61hs30
Sounds like a convergence problem. Common in this set.
Posted on May 25, 2009
ctc1234
  • 26 Answers
SOURCE: will not power on, red light flashing six times
the problem is in the power supply most likely. The overvoltage protect circuit is causing you not to be able to turn the tv on. This is common to all tv's. Solution unfortuantely is get another tv unless you know someone who can either work on or replace the internal power supply
Posted on Jul 01, 2009
Is the sony KP-61hs30 a HD television?
Hi, Although it is a rear projection TV it will work with HD content.
You will still need a set top box to decode HD programs. This is an old TV with tubes inside and a CRT screen. They will fail and it's getting harder to get parts for. My advice go get a flat pannel TV.
Good luck
Feb 04, 2016 | Sony KP-61HS30 TV
KP-61HS30 is too green
JUST GO IN TO SETINGS AND TEREN THE COLOR DOUWN OR TREY THE BRITNES
Apr 08, 2014 | Sony KP-61HS30 TV
Kp 61HS30 TV Had the tv since 2002. been a great tv. Just recently it started making a noise when you turn it on. Noise fades away after about 10 seconds. Noise kind of sounds like a dvd player trying...
If you locate the audio board, check for dried up electrolytic capacitors and dry joints around the output IC itself.
That should fix your fault.
Nov 27, 2010 | Sony KP-61HS30 TV
My Sony kp-61hs30 has no power. no blinking
Check fuses on power/delection board. Besides normal looking fuses there are micro fuses that are small and are yellow or blue in colour
Jan 07, 2010 | Sony KP-61HS30 TV
I have a KP-61HS30 and the picture is blurry or double
This is the stk392-??? ic's are bad. the repair can cost about $250 to 300 to fix by a pro. If you are a diy er you can replace the ic's on the board i have written an article on how to do this.
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Sep 02, 2009 | Sony KP-41T65 41" Rear Projection...
Will not power on, red light flashing six times
Jul 01, 2009 | Sony KP-61HS30 TV
My TV will start to turn it self on and off rapidly
http://www.nodevice.com/manual/sonymans/manual3447pdf/get4963.html
online pdf manual
Please rate my help++++Thanks for using FIXYA
Apr 11, 2009 | Sony KP-61HS30 TV
Problem
Hi three months ago my kp-61hs30 tv looks like 3d picture and technician man replaced the two convergence Ic's but last night my tv looks like 3d picture and it look like is the picture goes down
i don't know why happened again
Oct 30, 2007 | Sony KP-61HS30 TV
Sony tv kp-61hs30
SONY KP-61HS30
Jan 07, 2007 | Sony KP-61HS30 TV
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
