NAD 3150 cuts out
NAD 3150 : amp runs fine but will randomly cut out (i.e. go silent), while all lights are still on (not protection light though). A slap or two (sometimes three) on the side of the unit makes it start working again. What is causing this problem / how can I fix it myself? Any info or links much appreciated!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
Hello. Slapping and it working is a tail sign that there is a loose connection, bad solder point, loose wire. When a circuit board gets hot, solder joints separate and an opening occurs in the circuit. Open it up and get a visual. Look for cold solder joint, make sure all the connectors are secure. Good Luck
Posted on Feb 13, 2014
  • 4234 Answers
SOURCE: Nad C370
Since the problem seems to be sensitive to the volume level, I would be looking at the output wave form for any DC current. Although the protection circuit should detect any DC present, it is possible that some is leaking through. Also, verify that the speaker impedence is correct. If the amp is seeing too low an impedence load, it will work too hard causing excessive heat which will shutdown the unit as well.
Keep me posted.
Dan
Posted on Nov 05, 2008
VOTIT
  • 2071 Answers
SOURCE: Peavey TNT115 AMP cuts out
The problem is in amplifier section caused by change value resistor or leak capacitor or cold ,loose or crack solder joint parts this the common problem of over heating and shuts out the amplifier caused by abnormal distribution of current,try to check all the capacitor and resistor and replaced the defected parts ,so your receivers works normal again.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 07, 2009
SOURCE: Technics SUA 900mk2 amp cuts out at high volume.
check speaker wiring its not gone loose
Posted on Sep 05, 2009
petraman7
  • 1175 Answers
SOURCE: hello i own NAD 3150,
HI...
It's either failed power supply capacitors or one or more power transistors in the output amp have gone bad
Posted on Oct 07, 2010
rajsun22
  • 73 Answers
SOURCE: Running four S70 Siroccos off the amp, everytime
You are overloading your amp. IMO 640A cannot handle heavy loads.
Better change the speaker combo and connect something that puts right load on the 640A. Else, get a meaty amp from CA.
Posted on Mar 04, 2011
Testimonial: "Cheers, I did wonder whether it was all to much for it to handle - and now I know. Many thanks."
I OWN A NAD M 25 ---7 CHANNEL AMPLIFIER. I AM USING 4 CHANNELS TO BIAMP MY SPEAKERS. ONE OF THE UNUSED CHANNEL IS SHOWING A RED PROTECTION LIGHT.THE BIAMPED CHANNELS ALL WORK FINE ...I HAVE CHECKED ALL...
The manual would suggest you have a problem.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-M25-Amps-manual/id/8043ci561/t/2/
Try unplugging all of the speakers and see if that amp is still distressed. If it looks clean and happy start adding speakers until it returns (or not).
Jul 03, 2011 | NAD M25 Amplifier
Hello i own NAD 3150, its not working, all the indicator lights ( power, protection and soft clipping glows)
HI...
Oct 05, 2010 | NAD Audio Players & Recorders
I have a JBL1004 amp in my ski boat. I killed the battery listening to the stereo and caused the battery to lose a cell and drop to 10 volts. The stereo cut out as one would expect. I have replaced the...
if the protect light comes on then you might not have enough voltage running to the amp so you would need to add a second battery just for that amp.
Jul 26, 2010 | JBL GTO1004 Car Amp
NAD 3150 doesn't play any sound
I, too, have the 3150 and have experienced problems with it. With me the INPUT knob is touchy and needs micro turns sometimes to get both channels to come through. Also, it sounds like the pots are dirty as I get a scratchy sound while adjusting the knob. I have been told that these units are great middle of the road audiophile units. Actually, for the price of a used unit you can't do better. I just had an NAD 2400 THX amp delivered today and am using the 3150 as a preamp. My girlfriend is not feeling well and sleeping in the bedroom, though, and I can't listen to it :( The few minutes I heard of Steely Dan's Cousin Dupree made me bout **** myself (until I got the dirty looks). Sorry I wasn't more help! Goooooo NAD!
Jun 30, 2009 | NAD C325BEE Amplifier
Cuts out when volume increased
it went to protection mode check your cables first and then check your speakers-and confirm no cable touch each other(try with another speakers had same rating)(watt)--means how much power can get.
Jul 28, 2008 | NAD C320 2-Channel Amplifier
Protection light coming on and amp cutting off
yes make sure there both connected properly, check the fuses, the protection light usualy comes on when there is too much power and the amp protects itself from blowing
Jul 16, 2008 | Car Audio & Video
1200 watt legacy amp not working right
your amp its protect by releas of [powerout]one this releys is dead you mast chenche
Apr 14, 2007 | Pyle Dryver PLAD213 Car Audio Amplifier
106 people viewed this question
 Grubhead
Grubhead
